Old 01-31-2004, 09:08 PM   #1
eddieman
Member#: 40230
2001 Forester
black
Unhappy Valve Cover gasket
Hi Everyone , any one knows where to buy a valve cover gasket for a 97 Turbo Legacy EJ20 DOHC engine . i swap a engine from a EJ25 to a EJ20T, and now is leaking oil from my valve cover, so i pull it out and figure it out that i can't find this valve cover gasket in any local shop, they never seen this before. i did order a 2002 WRX valve cover gasket coz i think is the same , but it won't fit. Plz help. and one more question, how do i post a pic in a forum, cozi want to post the gasket. Thx so much
eddieman is offline   Reply With Quote
Old 01-31-2004, 09:56 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
A picture won't help too much since they're all the same shape. I would say try a phase I EJ22 gasket off a USDM Legacy turbo...If that doesn't do it, you should look to one of the down under forums like MRT's discussion forum to try and get one from someone down there...
Old 02-01-2004, 03:24 PM   #3
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
ej22t is SOHC. go for the 98 DOHC ej25, probbly be spot on.
h
supermoose is offline   Reply With Quote
Old 02-02-2004, 04:34 PM   #4
eddieman
Member#: 40230
2001 Forester
black
I ask the company sold me the engine, they told me is a JDM 91-95 Legacy turbo, i did try to order 98 dohc gasket, but it won't fit i think subaru turbo cars usually use direct ignition. is there any place selling JDM parts. Thx
Old 02-02-2004, 11:19 PM   #5
supermoose
Member#: 9093
swap starr
in the meantime u can madly liquid-gasket it
h
brand new valve cover gaskets/valve cover bolt grommets ('92 legacy L) shoodoggy Legacy Specific Parts 1 01-19-2010 01:13 AM
valve cover gaskets... whos done it? bjsid Normally Aspirated Powertrain 5 09-07-2003 09:13 PM
where to find 94 wrx valve cover gaskets!?!? czo79 Factory 2.0L Turbo Powertrain 8 05-28-2003 10:25 PM
2 things here. cooling fans/ valve cover gaskets solarsvx South East Region Forum 1 01-21-2003 02:27 PM
valve cover gasket replacment biggreen96 Service & Maintenance 0 02-11-2002 08:50 PM
Message Board Statistics All times are GMT -4. The time now is 05:15 PM.
