Welcome to the North American Subaru Impreza Owners Club Saturday December 20, 2014
Old 02-01-2004, 01:34 AM   #1
SmoknWRX
Member#: 44983
2003 impreza wrx
aspen
Unhappy Knock At Low Boost....help
OKAY GUYS, HERE ARE MODS.....INTAKE,UP PIPE, TURBOBACK EXHAUST WITH NO CATS, AND UTEC STG2 MAP.
HERES THE PROBLEMS, 2 WERE RESOLVED TONIGHT
1. INCONSISTENT IDLE
2. between 4-5k rpms and 20-40% throttle the car begins to sputter and some times results in the car to jump back and forth. after logging it i noticed the injector duty was jumping from 20-40% to 70% and back down in the matter of split seconds.
THESE PROBLEMS FIXED BY THE REMOVAL OF MY MAF SENSOR
3. heres the big problem.......its really cold outside and yet i cant run more than 14 psi without knock. turbo xs said that with my mods i should be running 16.5-17 psi. my friend is running the exact same setup and is peaking at 18.5psi. what the heck is going on??
right now ive turned the boost down to 12 psi and still see knock after full aceleration thru 1st and 2nd gear and let off the throttle right after my shift into 3rd. so its still knocking right as i back off the throttle in the begining of 3rd.
i have not altered the fuel/timing map since i uploaded it from TXS.
and why cant i get full boost in all gears?? would adding a MBC that totally bypasses the use of the stock solenoid help me out?
if your still reading this thank you for staying with me through all this typing, hahaha. if u can help me out any itd be awesome, thanks!!!!
SmoknWRX is offline   Reply With Quote
Old 02-01-2004, 05:10 AM   #2
eightballrj
Member#: 18520
2005 L GT Limited
woh woh woh... so you are boosting with no maf in??? NOT GOOD! Maybe I am misreading but if I am reading that correctly then you dont need to be doing that... But to comment on you problem #2, When I had a bad knock issues, I did a compression test and came out with 163,161,162,83 in cyl 4. So, maybe check compression... Good luck!
RJ
eightballrj is offline   Reply With Quote
Old 02-01-2004, 11:24 AM   #3
wrxracer3
Member#: 51897
03 WRX
You took the MAF off?! Put your stock intake back on and put the maf back on that. see if that helps.. And like eightballrj said i would do a compression test.
wrxracer3 is offline   Reply With Quote
Old 02-01-2004, 03:39 PM   #4
SmoknWRX
Member#: 44983
2003 impreza wrx
aspen
with a utec u no longer need to run a MAF. the car runs better with out it
Old 02-01-2004, 03:50 PM   #5
TexRex2002
Member#: 36303
06 Evo IX
wow. You may want to check up on that...
TexRex2002 is offline   Reply With Quote
Old 02-01-2004, 04:25 PM   #6
Big Turkey
Member#: 32118
Insane!!! What have all the UTEC tuners/owners been thinking?! They need to get on the ball!
Hey SmoknWRX, let us know how that turns out for ya.
Big Turkey is offline   Reply With Quote
Old 02-01-2004, 07:13 PM   #7
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
Removed your MAF? Hey isn't that the thing that measures how much air is flowing into the car so the ecu knows how much fuel to give the motor? and you don't need it?
wrx plus is offline   Reply With Quote
Old 02-01-2004, 07:15 PM   #8
wrx plus
Member#: 42253
2003 RWD WRX
Put your MAF back on and look for a vacume leak.
Old 02-01-2004, 07:18 PM   #9
wrx plus
Member#: 42253
2003 RWD WRX
That's so stupid that it's funny, and kinda sad.
Old 02-01-2004, 08:23 PM   #10
eightballrj
Member#: 18520
2005 L GT Limited
while wrx plus could have combine all that into one post... The UTEC support for MAF to MAP has not been released yet and therefore you DO YES DO!!! need the MAF sensor unless you have a beta version of the UTEC that we dont all know about.
Now back to the superbowl...commercials
RJ
knock at low load? austria impreza Engine Management & Tuning 9 10-10-2009 03:25 PM
Engine knock at low RPM's rek888v2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 01-02-2006 11:30 AM
Steering column knock at low speeds Jitenshakun Canada Region Forum 10 01-14-2005 11:03 AM
Knock at low rpm and throttle PharmCo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-02-2004 11:28 PM
Knock At Low Boost...help SmoknWRX Engine Management & Tuning 7 02-02-2004 08:59 PM
