Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 02-01-2004, 02:38 PM   #1
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
blue ridge pearl-sold
Default 2000rs ecu question
I just got done labeling my ECU i/o signals using a listing with pin locations, I have about 5 or 6 wires left that are not on the list that go to the engine or somewhere else, What are they??
imprezaclipse is offline   Reply With Quote
Old 02-02-2004, 11:17 AM   #2
Puckaveli
Member#: 1518
00 2.5RS
I'll ask you this; where are they? What pinout #?
Do you have the bulkhead harness laid out out in the car? If it's laid out follow the wires and see where they go.
Puckaveli is offline   Reply With Quote
Old 02-02-2004, 05:05 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
I did this part in a different fashion. I never actually labeled the wires on my EJ22 ecu. Instead, I identified which wires I would need using the I/O Signal pages and marked them. When I was ready to merge the harnesses I saved the wires I had pre-determined and removed the rest. This does take some work on your part and it is possible to overlook something and pull out a wire that you actually needed. i found that there were only 11 wires at the ECU that needed to be saved.
-Jon
Old 02-03-2004, 06:02 PM   #4
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
They are: b136 pin 27,b135 pin 11, b135 pin 12, b135 pin 13,b135 pin 6,b135 pin 25, b134 pin 12, and last but not least b134 pin 24. I just double checked my I/O list,none of these are on there.
Old 02-03-2004, 06:05 PM   #5
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
Yea that sounds about right,but these mystery wires are getting me, Where do they go and what do they do? Since subaru did not list them on the I/O sheet, are they not important or something?
Old 02-03-2004, 06:18 PM   #6
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Use your wiring diagrams. If they aren't listed in the I/O Signals section, then browse through the wiring diagrams and find them in there. I just casually glanced through and found b136 27 in the I/O Signals and b135 11 and 12 in the 2500cc engine electrical system. I'd write them all out but they are too hard to trace in the pdf and I'm not going to print them.
Keep looking, they are there .
-Jon
Old 02-03-2004, 06:34 PM   #7
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
oops ya That one is listed,searching for others.....
Old 02-03-2004, 09:14 PM   #8
imprezaclipse
Member#: 47103
2000 2.0rs,04 usdm
After looking over the diagrams I've found them,one was the power steering oil press switch! I don't know why subaru left that one out of the 2000RS I/O list but it's on my 2004wrx list so they will be getting spliced. Two others were simply grounds,another two go to a check connector (don't need?).
please help ej20g swap in 2000rs ecu not gettingpower GregBolby Subaru Conversions 3 07-23-2009 08:00 PM
06 sti into 2000rs wireing question FDrif73r Subaru Conversions 12 10-31-2008 04:58 AM
2000rs SUSPENSION QUESTION FOR PROFESSIONALS. topguneagle1 Brakes, Steering & Suspension 35 10-26-2006 07:36 PM
Swap into 2000RS, Couple Questions. boofer Subaru Conversions 10 07-26-2005 06:18 PM
2000RS ecu IdenityCrisis Mid West Subaru Owners Club Forum -- MWSOC 2 06-12-2004 08:16 PM
