Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 02-01-2004, 02:57 PM   #1
Gman094
Member#: 14092
2005 Legacy GT
w blue
Default Stage 4 base map...very rich...?
Well last night the JMS guys installed my vf30 with sti injectors and walboro fuel pump on my 02. Loaded a base TXS map with TMIC and took it out for a spin and was running rich beyond belief. Would do fine below 3-4k but once i tried to go WOT, it just sputtered and felt like it was breaking up. We tried a really rich and really lean map and still had problems. any suggestions?
Gman094 is offline   Reply With Quote
Old 02-01-2004, 03:09 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
What kinda intake are you running? What gear are you setting your a/f ratio in? Have you tried running the stock map for a little while at parcial throttle to let the long term fuel trims adjust? Have you thought about adjusting the 0% column values? Do you wanna come down to tampa and let me drive your car? Have you ever been in a turkish prison? <burp>
Old 02-02-2004, 10:09 AM   #3
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
Hippy you're a nut! Gman094 at the top of the base map from txs it will tell what AFR the map is tuned to. I think the stage 4 is 10.5:1 or something like that.
wrx plus is offline   Reply With Quote
Stage 4 base map EA704life UTEC 2 03-11-2009 06:43 PM
XTM map upgrade from cobb stage 2 base map?? hella_sti AccessPort 0 03-26-2008 11:36 AM
Stage 1 Base MAP ON TOP of Real TIme MAP? jeraljay AccessPort 3 08-20-2007 09:27 PM
vf39 and stage 4 base map Rickyh Engine Management & Tuning 7 10-12-2004 11:26 PM
utec stage 4 map and stage 4 tmi map the same? datdudedennis Engine Management & Tuning 4 03-19-2003 12:37 AM
