Old 02-01-2004, 03:09 PM   #1
Brighton34
Member#: 54071
09 Forester XT
Default break upgrade
I have a '96 Brighton. Isn't all I need is a hub to do a conversion?
Brighton34 is offline   Reply With Quote
Old 02-02-2004, 12:52 AM   #2
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
if your talking about the rear disc brake upgrade. you will need the e-brake cables off a 2.5 or turbo legacy, the hubs,the rotors and the calipers....i think that is all...maybe? i just ordered the conversion and it should be here on yues. if you have any more questions you can pm me.
scoobydorift is offline   Reply With Quote
Old 02-02-2004, 10:48 AM   #3
Subie FI
Member#: 17253
2014 BMW 328i Wagon
Alpine White
Take a look at the following links:
http://wac.addr.com/auto/obs/disc/disc.html
http://forums.nasioc.com/forums/show...hreadid=373634
That should get you more than enough info. What you really want is the complete knuckles and calipers from an older car. Try to get the e-brake cable with them as it saves a bit of hassle later.
If you have any questions, PM me as I just did this to my car at a local install day. Also, I'm a regular at the Tuesday night Novi meets.
Are you Jeremy's (WRX34) brother??
Leo
Subie FI is offline   Reply With Quote
Old 02-02-2004, 01:20 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you can also get the parts from any impreza with ABS...so not only legacy turbo and RS
Old 02-02-2004, 08:38 PM   #5
Brighton34
Member#: 54071
09 Forester XT
Thanks alot guys for the information, I'll look into it.
Subie FI: Yeah, Jeremy is my older brother. I might have met you before but I can't remember.
Allan
Old 02-02-2004, 10:24 PM   #6
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I'm seeing you all over the place first midwest forms then here
its brake BTW not break
subie disk brakes are intresting drum brake with in the rotor drum being the e-brake. and disc brake being with foot pedal
is it disc or disk?
scobaru is offline   Reply With Quote
Old 02-06-2004, 08:30 AM   #7
WRX34
Member#: 13364
1996 GM8 caged,
99 V8 RSTi, 11' FXT
It's also forums not forms j/p
<Swears he's gonna smack his lil bro when he gets home! LOL jk...he's gonna be a 1st time import car learner on this beast, so I'm cuttin him slack and givin him credit for wanting to do this! Thanks for any help and so far looks like it shouldn't be too bad on the brake conversion!
BTW it's disc
WRX34
WRX34 is offline   Reply With Quote
Old 02-06-2004, 12:21 PM   #8
BlkTS02
Member#: 50142
2002 2.5TS
MBP
How long did it take you?
I just pre assembled the rear knuckles / parking brake, and when I put the rotor on, there's some rubbing. Did you have this also?
BlkTS02 is offline   Reply With Quote
Old 02-08-2004, 04:53 PM   #9
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Do you need RS front brakes?
garface is offline   Reply With Quote
Old 02-08-2004, 06:42 PM   #10
Subie FI
Member#: 17253
2014 BMW 328i Wagon
Alpine White
BlkTS02:
Too long, but we weren't in a hurry. Also, I don't have a lot of experience doing this kind of thing so I wanted to make sure I was doing it right. I would guess it only took about 6 real hours when you minus out dinner, screwing around, looking for tools, figuring out that the e-brake adjustment was completely out of whack, and a stuck bushing .
As for the rubbing, when everything was done, both rear pads were dragging on the rotors. Nothing bad, but every revolution you could hear a spot of dragging and I could see the pads were scraping the surface rust off the rotors in some spots without the brakes being applied. But by the time I was home (about 40 miles) everything was bedded in properly and the rubbing was gone. FYI, I used the pads and rotors that came with my set-up because there was hardly any wear and only a light bit of surface rust.
Leo
Old 02-08-2004, 06:51 PM   #11
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Thanks for the info, but I was actually referring to the drum / parking brake rubbing slightly. Am I correct in assuming that after it's bedded properly it'll be ok?
Old 02-09-2004, 10:21 AM   #12
Subie FI
Member#: 17253
2014 BMW 328i Wagon
Alpine White
My bad, I thought the caliper pads were rubbing. If its just the drum brake rubbing that means its not centered exactly. Take the rotor off and shift the e-brake drum pad assemblies around a bit. That should do it.
It shouldn't matter that much because the e-brake mechanism is self-adjusting, ie it will recenter itself every time you use the e-brake. Just so I'm clear, it won't affect how well the e-brake holds (thats what the adjuster nuts are for) , it just centers mechanism so it grabs evenly.
Leo
Old 02-10-2004, 10:31 AM   #13
BlkTS02
Member#: 50142
2002 2.5TS
MBP
thanks for the help, hopefully everything will go well during the install...
Old 01-30-2005, 07:30 PM   #14
elcorazon01
Member#: 73988
So I have a question regarding the e-brake aspect of the swap. I also have a 96 Brighton and it is a coupe. Do I need the e-brake cable from another coupe or can I use a RS 4 door e-brake cable. My instincts say no because the 4 door cable has got to be longer, but that is why I'm asking. Any info would be great. Thanks a lot everyone.
Andy
elcorazon01 is offline   Reply With Quote
Old 01-30-2005, 09:12 PM   #15
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
wow this thread is old you can use 4 door or coup E brake believe or not but the coupe and sedan are the same lenght
Brake Supersticky: brake upgrade FAQ, tech in, Brembo info, and other upgrades: Butt Dyno Brakes, Steering & Suspension 28 11-29-2015 12:57 PM
The OFFICIAL Brake Upgrade / Big Brake Kit FAQ ! Butt Dyno Brakes, Steering & Suspension 55 06-10-2015 06:44 AM
1996 Impreza Brighton Suspension Upgrade - Lessons learned OddBallRacing Brakes, Steering & Suspension 17 05-10-2007 01:29 PM
Brake Upgrade or Turbo Upgrade?? Boosted1456 General Community 39 09-10-2006 12:25 PM
FS: 1996 Impreza Brighton with Upgrades elcorazon01 Private Vehicle 'For Sale' Classifieds 1 01-23-2006 05:30 PM
