Old 02-01-2004, 03:55 PM   #1
tellravi
Member#: 40409
Default 02 WRX Exedy Clutch and Flywheel noise - Help
I recently installed the Hypersingle Exedy clutch and flywheel kit. I started noticing noise right below my shifter. Here are the symptoms
Cruising along the highway, let of the throttle off, I hear a noise right below the shifter. The noise will go away if I press the clutch or push the throttle. Its a hissing noise.
Part of this swap was changing the tranny oil. We could not find the stock 75w90 GL-5 oil, so we went with 80w90 GL-5 Non synthetic oil. We also noticed a little play in the Kartboy shortshifter near the tranny.
Questions
Could this be normal noise with the clutch/flywheel kit?
Could this be syncro noise with the different oil, but why would it not come when I step on the gas or clutch?
Could this be because of the shifter play?
Any ideas ?
Thanks
tellravi is offline   Reply With Quote
Old 02-01-2004, 04:28 PM   #2
JMP781
Member#: 42488
Default Noises also
I have the Toda clutch and flywheel on my 02 and have the same noises you are describing. Took it back to the install shop twice just to check and same results both times. Nothing wrong. I contacted someone at Toda and they said that many people using this setup are having the same issues and it is due to the "fingers" of the clutch rubbing the flywheel when you let off of the throttle. Nothing to worry about just have to listen to the noise.
Justin
JMP781 is offline   Reply With Quote
Old 02-01-2004, 04:29 PM   #3
tellravi
Member#: 40409
That makes sense, considering they have pucks.
Thanks
02-05 wrx stage 2 Exedy clutch and flywheel 06REXtr Drivetrain 14 11-24-2007 06:11 PM
02-05 wrx stage 2 Exedy clutch and flywheel 06REXtr SWIC Private Classifieds 13 11-06-2007 12:04 PM
WTB: Urgent - 02 WRX stock clutch and flywheel- going back to stock bouchon Mid Atlantic Impreza Club -- MAIC 11 11-03-2005 09:05 AM
FS: Exedy clutch and flywheel, and more Crash477 Private 'For Sale' Classifieds 8 03-16-2005 04:47 PM
Installed Exedy clutch and flywheel in GC8 now deceleration noise! cpu77 Transmission (AT/MT) & Driveline 1 09-19-2002 12:40 PM
Message Board Statistics All times are GMT -4. The time now is 07:28 PM.
