Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 02-01-2004, 07:24 PM   #1
b-o-b-s
Member#: 50148
2004 sti
jbp
Post high comp ratio
ok i posted this type of thread some where else. i am building a new combo for my obs, this is what it is. p2 2.5 block, p1 2.5 head gaskets, 2.2 dual port heads, borla header, custom 2.25" or 2.5" exhaust with no cats or resonater and decent muffler (havent decided what one) new upgraded subaru clutch, intake from a leagacy (no air horns) custom air box under r/f scoop, and 2.5 dohc fuel injectors. how does that sound. what do you people think about that setup. do you know about numbers that it will produce. any info would be cool thanks.
b-o-b-s is offline   Reply With Quote
Old 02-01-2004, 09:35 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
You have the EJ22 in the car right? or had they gone to the EJ25?
Take it easy, Micah
Old 02-02-2004, 04:21 PM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
At this point, it is purely guess work on that combination. You will have to identify head gasket thicknesses, displacement, bore, head volume, and possible valve interference. I have doubts you will be able to pull it past the stock 10.0:1 CR available on the MY00+ EJ25.
I would guess the performance will be marginally better than a stock EJ25. Have you considered tuning? The EJ22 ECU is not going to be expecting the kind of differences you are adding. I've heard a few reports that there are dual-port EJ22 heads out there, but I know mine were single-port. Don't know if they are a restriction compared to the EJ25 heads or not.
My suggestion: buy a complete EJ25 longblock and put it in. No need to complicate something with such little returns.
-Jon
higher comp ratio vs higher boost. stroker build azn2nr Built Motor Discussion 5 01-26-2007 01:50 AM
8.5:1 comp ratio the same psi on two diff motors? SBW Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-05-2005 10:49 AM
EJ257 with jdm ver.8 heads comp ratio oldbluwrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 03-31-2005 08:38 PM
High Comp vs High Boost zoomfactor Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-21-2004 11:46 AM
