Notices
Old 02-01-2004, 10:52 PM   #1
Kyguy
Member#: 38705
'95 GM2 Rally Car
& '08 WRX
Question noise when going over bumps!
When I go over bumps, the front right tire makes some noise, maybe I can even record it on my digi cam, but basically it just sounds like wreeewraah. (hah!) Any suggestions?
I've jacked up the car, looked under it but I don't see anything bad. I went over a curb in the snow () but that was a while back.
Suggestions? Everything is stock and it's only when I go over speed bumps.
Kyguy is offline   Reply With Quote
Old 02-02-2004, 01:52 AM   #2
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
My car does the same thing, but mine happened after I installed a 22mm swaybar up front. In my case, I think its the sway bar mounts. I was told to use graphite grease or white lithium grease and even wrap the bar with teflon tape where it meets the mounts. Possibly the same in your case even though you are still stock up there.
StarDogChampion is offline   Reply With Quote
Noise when going over bumps! ( no clunk) SubbyPAT Brakes, Steering & Suspension 5 03-31-2007 11:04 AM
Bad clunking noise from front pass side when going over bumps? (05 STi) Optimus Prime Brakes, Steering & Suspension 16 06-24-2006 10:18 PM
rattling or clunk noise when going over bumps hilfiger4you Service & Maintenance 1 08-07-2005 11:06 AM
Noise when going over speed bumps and up/down driveways Evaider Brakes, Steering & Suspension 10 05-23-2002 03:14 AM
