Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 02-02-2004, 12:03 AM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default oil stain how do u clean it out?
had a huge spill on the garage floor the floor is cement. oil all over tried drying it best as I can. is there anything to get rid of the stain? the garage is rented so oil stain is no good
scobaru is online now   Reply With Quote
Old 02-02-2004, 03:24 AM   #2
Dnewbrough
Member#: 49010
2015 Impreza WRX STI
Crystal Black Silica
I know this sounds nuts but try Coke.... the drink, not the white powdery stuff.
Dnewbrough is offline   Reply With Quote
Old 02-02-2004, 07:56 AM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Goof-off works pretty well, as well as any of the concrete cleaners/etchants (which are usually muriatic acid) - however, for most of the things which will work, you need to be able to apply them, then hose the area down to wash them off.
Old 02-02-2004, 08:16 AM   #4
1DOWNCLOWN
Member#: 50287
02 WRX
use dish soap and water
1DOWNCLOWN is offline   Reply With Quote
Old 02-02-2004, 10:21 AM   #5
vile
Member#: 32371
'02 t-rex wagon
platinum
engine degreaser
or simple green if u clean it right after the spill
vile is offline   Reply With Quote
Old 02-02-2004, 10:47 AM   #6
gjhsu
Member#: 12329
2o15 WRX
Ice Silver
WD40, apply liberally, mop up.
gjhsu is offline   Reply With Quote
Old 02-02-2004, 03:17 PM   #7
gr8-wrx
Member#: 38411
2003 WRX Sedan
2001 Honda CR-V SE
Kitty litter. Grind it in with your shoes. It's pretty absorbant stuff.
gr8-wrx is offline   Reply With Quote
Old 02-05-2004, 01:40 AM   #8
electricpork
Member#: 9498
03 Bugeye
Junkyards are fun!
the hardware store will likely carry solvent thats designed to take oil stains out. Had to use some when an oil change went wrong (dont ask, windy day) at a friend's house. Usually comes in some kind of tin can.
I hear the "white powdery stuff" works well too, just gets expensive in a hurry.
electricpork is offline   Reply With Quote
Old 02-05-2004, 08:19 AM   #9
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
You can also spray brake/parts cleaner on the stain, then wipe with towels.
Old 02-05-2004, 03:31 PM   #10
shogunate83
Member#: 6006
thats what I do
shogunate83 is offline   Reply With Quote
automatic stub axle, how do you pull it out? breakfasteatre Transmission (AT/MT) & Driveline 1 12-31-2007 08:41 PM
How Do You Know if Knock is Real (and how do you kill it?) williaty Service & Maintenance 4 12-17-2007 12:45 AM
ECU Connector Lock Tab: How do you get it out? Pakin Subaru Conversions 0 09-15-2006 05:22 AM
Guys: how do you trim 'down there' and ladies: how do you prefer it? rex n effect Off-Topic 84 04-09-2004 09:21 AM
How do you clean puke out of the seat? EddieC168 Newbies & FAQs 10 03-26-2002 01:18 PM
