Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 02-02-2004, 12:12 AM   #1
Member#: 52525
2000 RS/WRX swap
Default Timing Belt???
I have a 00 2.5rs. I was reading my maintainence schedule and at my mileage it says to check timing belt and replace if necessary. Actually right now i just passed 70k miles. Where and for what am I looking? I noticed some little plugs on the plastic cover on the front of the engine while I was installing my underdrive pulley. I suppose I'm suppose to look in there?
Also is the ej25 an interference motor? More importanlty, what happens if and when the belt breaks? Does the motor just stop or do I ruin valves? Any advice is appreciated!
tverdek is offline   Reply With Quote
Old 02-02-2004, 10:26 AM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
The belt in your car is scheduled for replacement at 105k, and if you go to the trouble of removing the covers, I honestly would just replace the belt. Thing to check for is the condition of the tensioner while you are in there- if there is oil leaking from the pressure cylinder, you should replace it. Pretty much every Subaru since about 1997 has been an interference engine, and yours is included. If the belt snaps, the car will likely just stop, but there is the potential to bend valves. For a heads up on how to do any/all of this, check here:
Timing belt cover and checking the timing belt Pinned Service & Maintenance 14 12-28-2015 12:09 AM
FS:Brand New OEM Timing Belt Tensioner & Timing Belt jsnm Engine/Power/Exhaust 5 04-06-2010 12:58 PM
Help Please! Timing belt cutting into timing belt cover behind A/C idler pulley Kansai Subaru Service & Maintenance 14 10-23-2008 04:05 AM
FS: Gates Racing Timing Belt NEW/ PE timing belt Keo Engine/Power/Exhaust 6 07-04-2008 03:15 AM
Instructions for taking timing belt cover off to inpect the timing belt? scoobbee Service & Maintenance 3 05-09-2005 06:33 PM
