Old 02-02-2004, 08:38 AM   #1
samh22a
Member#: 30710
04 STI
Default strange knock logging with UTEC.. ?
In the manual, it's says : The UTEC will flash the CEL if knock is detected only when the UTEC is in charge of the timing.
Does this also apply to log files ?
Check this out :
Code:
3138, -3.4,2.5, 14, 00,   01,  14.3,+34.6,  12.0,ECU. , -6.6,ECU.  ,2.5
3186, -2.4,2.9, 38, 00,   00,  15.2,+32.0,  20.0,ECU. , -6.6,ECU.  ,2.7
3284, -1.0,3.0, 45, 00,   00,  13.5,+30.6,  17.0,ECU. , -6.6,ECU.  ,2.8
3350, +0.8,3.1, 45, 00,   00,  14.6,+29.6,  20.0,ECU. , -6.6,ECU.  ,2.9
3508, +2.9,3.2, 46, 00,   00,  14.5,+28.9,  22.0,ECU. , -6.6,ECU.  ,3.0
3635, +4.7,3.3, 46, 00,   11,  14.2,+25.1,  24.0,ECU. , -6.6,ECU.  ,3.1
3858, +6.2,3.4, 44, 00,   11,  15.5,+22.8,  28.0,ECU. , -6.6,ECU.  ,3.2
3963, +7.4,3.4, 36, 00,   00,  14.4,+26.0,  27.0,ECU. , -6.6,ECU.  ,3.2
4070, +8.2,3.5, 29, 00,   00,  14.3,+25.4,  28.0,ECU. , -6.6,ECU.  ,3.2
4251, +8.2,3.5, 28, 00,   00,  15.2,+25.2,  32.0,ECU. , -6.6,ECU.  ,3.3
4426, +8.4,3.6, 28, 00,   00,  12.7,+23.9,  40.0,ECU. , -6.6,ECU.  ,3.3
4566, +8.2,3.6, 27, 00,   00,  rich,+23.3,  43.0,ECU. , -6.6,ECU.  ,3.4
4351, +6.2,3.3,  0, 00,   00,  rich, +9.0,  18.0,ECU. , -6.6,LCM.  ,2.9
samh22a is offline   Reply With Quote
Old 02-02-2004, 09:14 AM   #2
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
Weird. Did you notice that at the bottom line, second column from the right where it should say ECU it actually says LCM? I've never seen that on any of my logs.
wrx plus is offline   Reply With Quote
Old 02-02-2004, 10:13 AM   #3
t-kid
Member#: 24697
2002 wrx
black
Could this be because it has a internal all forged
t-kid is offline   Reply With Quote
Old 02-02-2004, 11:25 AM   #4
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
LCM, if memory serves me correct is Launch Control Mode
Here is a snippet of log with it in
6184 +18.8 4.5 105 100 00 rich +22.8 97.8 +26.0 -8.0 290.00 4.1
6337 +18.6 4.5 104 100 00 rich +24.3 98.7 +26.0 -8.0 290.00 4.2
6447 +18.6 4.5 104 100 00 rich +24.8 98.5 +26.0 -8.0 290.00 4.2
6587 +19.0 4.5 104 100 00 rich +24.7 97.4 +26.0 -8.0 285.00 4.2
6497 +19.4 4.5 104 100 00 rich +25.7 97.1 +26.3 -8.0 285.00 4.2
5973 +19.2 4.2 105 100 00 lean +24.5 80.4 +24.6 -8.0 LCM. 3.9
5232 +18.6 4.2 105 90 00 lean +23.8 75.5 +23.2 -7.6 LCM. 3.8
5012 +17.6 4.3 104 80 00 22.1 +18.4 84.6 +21.2 -7.1 LCM. 3.8
4728 +17.8 4.3 104 90 00 rich +14.0 86.4 +21.2 -7.5 300.00 3.8
4880 +18.6 4.2 104 100 00 rich +17.2 84.1 +22.0 -7.6 300.00 3.8
4945 +19.6 4.1 105 100 00 rich +17.6 84.3 +22.6 -7.6 300.00 3.8
4894 +20.6 4.2 104 100 00 rich +19.0 83.6 +22.8 -7.7 300.00 3.9
4916 +20.8 4.2 104 100 00 rich +18.9 83.6 +22.6 -7.8 300.00 3.9
But that has nothing to do with your knock.
I expect that the UTEC is detecting knock but when it is not controlling timing it is not correcting it.
Look at this section of log
You are very lean under these load conditions. Are you using a manual boost controller? I usually see this with an MBC. The ECU under 66% TPS or 5000 rpm is in closed loop fuel control. It's always going to target 14.7:1 or around that.
You may want to check your long term and short term fuel trims and force them to add some fuel.
mick_the_ginge is offline   Reply With Quote
Old 02-02-2004, 11:47 AM   #5
samh22a
Member#: 30710
04 STI
You're right on the LCM, lC is enable, and the 2-step limit is set very low for testing purposes.
Now, that's what I was also thinking since there's a EBC currently installed on the car.
Now, I could add some fuel in my 0% column, but how much ? I don't have any EGT or TUNA installed in this car.
Should I reset the ECU first ? and if I do so, how long should I wait for the ECU to switch to the low-det fuel map ?
Thanks
Sam
Old 02-02-2004, 11:54 AM   #6
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
You must be a stage 4 as your 0% is negative. You should do multiple things. Add some fuel in the 0% it's always better having the ECU remove a little fuel rather than adding it. Standard stage 4's that I see have something between -6 and -6.5 in the 0% above 1000 rpms. -4 to -5.5 in the very low rpms.
The issue is that the ECU is in closed loop fuel tuning mode so it's always going to correct....
Yes you should reset your ECU. Do that then do the IAM reset trick to force the ECU back into the aggressive map.
Reset ECU
Warm up car (must be fully warmed up)
In third gear or above drive the car with your foot on the brake and bring up the boost to around 10-14psi.
Do this 2 or 3 times and you should force the ECU back into the aggressive map. (If you have delta dash you can just monitor the IAM)
Use either DD or an OBDII scanner to monitor the ST and LT fuel trims, get them within -7 to +7 (I always like to be negative)
Old 02-02-2004, 11:57 AM   #7
samh22a
Member#: 30710
04 STI
will do.
Thanks
Sam
Old 02-02-2004, 12:43 PM   #8
CMJ
Member#: 39235
Looks like you are experiencing the MY04 open loop delay problem. You are reaching over 8psi @ 15.2 afr.
CMJ is offline   Reply With Quote
Old 02-02-2004, 12:48 PM   #9
samh22a
Member#: 30710
04 STI
this car has an EBC, so the problem here is PTFB.
Sam
Old 02-02-2004, 12:50 PM   #10
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Well spotted, I missed that piece of info in Sam's bio.
He is however under 60% TPS and 5000 rpm so the ecu will still be in closed loop fueling.
However you should contact TurboXS and see if you can get a early copy of 3.2 which is meant to resolve some of these issues.
Old 02-02-2004, 12:52 PM   #11
samh22a
Member#: 30710
04 STI
sorry guys if this is confusing, but I'm not tuning my car.
It's a 2002 WRX
I'l well aware of the problem with the 2004 ECU, and that's why I'm still waiting on my UTEC
Sam
Old 02-02-2004, 12:53 PM   #12
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Stick with what I said in the beginning then
Old 02-02-2004, 07:54 PM   #13
wrx plus
Member#: 42253
2003 RWD WRX
Well that explains LCM to me I havn't yet played with launch control.
Help with Knock, logs inside wrx21144 Engine Management & Tuning 11 10-15-2005 10:28 PM
Strange knock with UTEC stg2 cluck Engine Management & Tuning 12 08-05-2005 10:01 PM
Strange CEL stuff with UTEC dropmech Engine Management & Tuning 9 03-30-2005 11:57 PM
04 WRX fixed most of my Knock problems with UTEC. Just 2 problems now! kitbar Engine Management & Tuning 10 11-15-2003 11:23 AM
Yoshio ECU logged with Utec dwx Engine Management & Tuning 3 11-26-2002 02:21 PM
