Old 02-02-2004, 10:09 PM   #1
sgilbert
Member#: 40179
2002 2.5 RS
Lightbulb Screw light on bumper
I was thinking about installing a light bar on my RS but since I couldn't decide how I was going to do it I just left the idea and will probably think about it this summer (I had the rally innovation bar in mind). But a couple of days ago as I was walking in front of my car I just saw those holes where you can install a licence plate so I thought to myself... Maybe I can get lights and install them onto the bumper for now and move it back to the bar when the time comes.
So the question is : Does anybody have any experience installing lights with the screw holes from the licence plate? Will it be strong enough? Looks like the holes are platics only... I'll probably have to build some metal corner to install the lights on and screw the corner onto the bumper, but that's only details. BTW I won't rally my car, it's my daily driver and daily fun.
edit : a picture worth a thought words
sgilbert is offline   Reply With Quote
Old 02-04-2004, 12:59 PM   #2
tk_1971
Member#: 20904
2012 CT200h
I miss my bugeye
Uhhh...
I think the holes in question are only on the plastic bumper cover. I recently had to go to bigger screws because the old ones backed out too easily and the plate started to move at high speeds.
tk_1971 is offline   Reply With Quote
Old 02-04-2004, 02:31 PM   #3
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
I wouldn't recommend using those to mount anything that would need to support weight. There isn't anything solid back there to mount to, unless you consider foam solid.
It also depends on the lights you want to mount. little bitty ones could probably mount using wall expanders (the ones you would use to mount something heavy to drywall).
I would go with the www.rallyinnovations.com bar, but I am partial to them, they are making me something custom for my lights.
RR
Rapid_Roo is offline   Reply With Quote
Old 02-05-2004, 07:22 PM   #4
sgilbert
Member#: 40179
2002 2.5 RS
Impreza WRX STi the famous rally innovations bar
I've just check the holes tonight to finally see that they end in foam has you said. Well, I think I'll forget about that. I've already saw the great bar from rally innovations but do you know if they ship in Quebec? I've check their distributors and none of them seems to take orders online. That's definitely the best way to do it... and to be able to expand to 4 lights later on! Well, thanks for your tips guys.
Old 02-06-2004, 01:18 AM   #5
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
I am sure they would ship to you. Or contact John directly and he can help you out. Here is a discussion in the Vendor Forum on NASIOC.
http://forums.nasioc.com/forums/show...hreadid=481979
RR
pictures available here: http://forums.nasioc.com/forums/show...hreadid=494659
Old 02-06-2004, 05:29 AM   #6
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
i've had a set of very small driving lamps (Hella FF75) "bolted" to the plastic bumper cover for a long time and they are plenty stable...You just have to use a good fat washer on both sides of the plastic to securely clamp onto the plastic surface.
but anything bigger than those and I'd want more stability.
nhluhr is offline   Reply With Quote
Old 02-06-2004, 10:54 AM   #7
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
You might try the inner holes as they are the metal. Just look for the larger of the two holes. I am not sure why they are there, but if you drilled into that, you would be going into the bumper beam. In theory it should work
Shane
www.paranoidfabrications.com
PARANOID56 is offline   Reply With Quote
Old 02-07-2004, 03:11 PM   #8
blagon
Member#: 30789
2006 impreza
dark blue
Just a liittle note.
I am selling a Cascade Motorsport light bar that bolts right in.
P.M. me if interested, please.
blagon
blagon is offline   Reply With Quote
Old 02-07-2004, 05:19 PM   #9
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
Thumbs up
I have had no problems running this way for over a year now. Check it out.... I've had them up high and down low, depending on which way I rotate them.
Since they're driving lights they work better up high.
Samirr76 is offline   Reply With Quote
Old 02-08-2004, 05:09 PM   #10
sgilbert
Member#: 40179
2002 2.5 RS
I think I'll go and buy my lights and install them as Samirr66 said until I get a bar.
Old 02-09-2004, 08:18 PM   #11
Samirr76
Member#: 4835
2003 Baja 5MT
If you cant see the pictures and onyl see red Xs, here is the album link....the pics are towards the end of the album
http://www.imagestation.com/album/?id=4292294705
Old 02-11-2004, 10:26 AM   #12
Safir
Member#: 3873
. Paradise is
like Disney with hookers
my old light mount:
this was meant to be very temporary and was screwed into the holes in the bumper cover. The lights fluttered like all hell, but it was better than nothing. We did a similar install on a WRX with similar results.
I now have a "proper" light bar that attaches to the front crossmember under the car and the upper radiator support, very solid, even with the (much) larger lights on it now.
Safir is offline   Reply With Quote
Old 02-12-2004, 05:09 PM   #13
yogi's wagon
Member#: 41787
2004 WRX Wagon
Here's what i did for my car. I know that it's not the same year as yours, but I think it could give you some good ideas.
And if the picture doesn't work, here's the link :
http://www.imagestation.com/album/?id=4287715843&idx=7
yogi's wagon is offline   Reply With Quote
Let's trade! My 03 tail lights and bumper for your 04+ lights and bumper Imprezanator Private 'Wanted' Classifieds 0 02-03-2005 11:33 PM
quick question: screw size on WRX fog lights? fastfood Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 01-21-2004 02:58 AM
Canadian RS bumper signal lights on eBay. alexs001 Vancouver Impreza Club Forum -- VIC 0 07-17-2001 05:49 PM
Need: pic of fog lights on Ver. 4 bumper Mikey Interior & Exterior Modification 4 06-13-2001 11:24 PM
('93-'01) Need: pic of fog lights on Ver. 4 bumper Mikey Impreza Forum 1 06-13-2001 02:47 PM
