Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 02-02-2004, 11:15 PM   #1
samh22a
Member#: 30710
04 STI
Default Trouble spooling a VF-34..
This is weird
Running the Std FMIC Stage 4 Map from TurboXS. Trouble is, we're getting 10 psi @ 4000 RPM and 16 PSI @ 6500 rpm.
We're not using the ABC, the car is equipped with an HKS EVC boost Controller. ( I'm not familiar with this type of EBC)
Here's a UTEC loc :
Code:
                   Load Knock                     Mod   Mod         Mod
 RPM   MAP  MAF TPS Site Count  AFR  Ign#1  Inj#1  Ign   Fuel Boost  MAF
       psia  V   %                    deg   duty   deg    %   (OL)    V
 2318  -4.7 2.3  11  00    00   14.4 +36.5    8.0 ECU.   -6.6 ECU.   2.1
 2332  -4.7 2.3  11  00    00   14.4 +36.4    8.0 ECU.   -6.6 ECU.   2.1
 3153  -5.5 2.8  44  00    00   rich +32.0   13.0 ECU.   -6.6 ECU.   2.7
 3171  -2.2 2.9  97  10    00   15.5 +31.5   22.0 ECU.   -6.7 ECU.   2.8
 3242  +0.8 3.1 102  20    00   rich +28.3   24.0 ECU.   -6.9 280.00 3.0
 3330  +2.9 3.1 101  30    00   rich +26.1   26.0 ECU.   -6.2 280.00 3.1
 3408  +4.9 3.3 101  40    00   rich +21.8   30.0 ECU.   -6.1 280.00 3.2
 3494  +6.6 3.4 102  40    00   rich +22.1   32.0 ECU.   -6.0 280.00 3.3
 3546  +8.0 3.4 101  50    00   rich +21.2   34.0 +17.0  -5.2 280.00 3.2
 3627  +9.0 3.5 101  50    00   rich +20.7   36.0 +17.0  -5.1 280.00 3.2
 3691  +9.6 3.4 101  50    00   rich +21.0   38.0 +17.0  -5.1 280.00 3.4
 3907 +10.2 3.5 101  50    00   rich +20.7   39.0 +17.1  -5.0 280.00 3.4
 3889 +10.2 3.6 101  50    00   rich +20.0   41.0 +17.6  -5.0 280.00 3.4
 3977 +10.2 3.7 102  50    00   rich +20.7   42.0 +18.0  -5.0 280.00 3.5
 4079 +10.0 3.6 101  50    00   rich +20.2   45.0 +18.0  -5.0 280.00 3.5
 4203  +9.8 3.8 102  50    00   rich +19.0   48.0 +18.0  -5.0 280.00 3.5
 4278 +10.2 3.7 101  50    00   rich +18.1   51.0 +18.0  -5.0 280.00 3.5
 4351 +10.6 3.8 101  50    00   rich +15.2   54.0 +19.0  -5.1 280.00 3.6
 4438 +10.8 3.8 101  60    00   rich +15.0   55.0 +19.6  -5.0 280.00 3.6
 4504 +11.3 3.9 101  60    00   rich +15.1   56.0 +20.2  -5.2 280.00 3.6
 4649 +11.7 3.9 102  60    00   rich +16.3   58.0 +20.7  -5.2 280.00 3.6
 4796 +12.3 3.9 101  60    00   rich +17.2   60.0 +21.2  -5.4 280.00 3.7
 4880 +12.1 4.0 101  60    00   rich +18.8   63.0 +21.5  -5.7 280.00 3.7
 4945 +12.1 4.0 101  60    00   rich +19.6   64.0 +21.8  -5.8 280.00 3.8
 5012 +11.9 4.0 101  60    00   rich +22.7   67.0 +22.0  -6.3 280.00 3.8
 5216 +11.5 4.0 101  60    00   rich +24.1   69.0 +22.0  -6.0 280.00 3.9
 5200 +12.1 4.1 101  60    00   rich +23.0   71.0 +22.0  -5.8 280.00 3.8
 5274 +12.1 4.1 101  60    00   rich +22.6   73.0 +22.0  -5.7 280.00 3.9
 5446 +12.7 4.2 101  70    00   rich +22.5   76.0 +20.6  -5.5 280.00 3.9
 5518 +13.5 4.2 101  70    00   rich +22.6   77.0 +21.0  -5.5 280.00 4.0
 5592 +14.3 4.3 101  80    00   rich +22.7   78.0 +21.2  -5.5 280.00 4.0
 5757 +14.9 4.2 101  70    00   rich +24.2   79.0 +21.5  -5.5 280.00 4.0
 5787 +14.7 4.3 101  70    00   rich +23.9   81.0 +22.0  -5.4 280.00 4.1
 5952 +14.5 4.3 101  70    00   rich +21.3   82.0 +22.0  -5.4 280.00 4.1
 6038 +14.1 4.3 101  70    00   rich +21.7   84.0 +22.0  -5.4 280.00 4.1
 6207 +14.5 4.4 100  70    00   rich +21.6   84.0 +22.1  -5.4 280.00 4.1
 6385 +15.1 4.4 101  80    00   rich +23.9   86.0 +22.0  -5.4 280.00 4.1
 6373 +15.7 4.4 101  80    00   rich +26.7   85.0 +22.6  -5.4 280.00 4.1
 6548 +15.9 4.4 101  80    00   rich +26.6   85.0 +22.7  -5.4 280.00 4.2
 6447 +15.5 4.4 101  70    00   rich +27.1   86.0 +23.0  -5.4 280.00 4.1
 6640 +15.1 4.4 101  70    00   rich +27.5   86.0 +23.0  -5.4 280.00 4.1
 6734 +14.7 4.4 101  70    00   rich +28.2   85.0 +23.0  -5.4 280.00 4.1
 6761 +15.1 4.4 101  80    00   rich +28.4   85.0 +23.0  -5.4 280.00 4.1
 6844 +15.3 4.4 101  80    00   rich +28.4   86.0 +23.0  -5.4 280.00 4.1
samh22a is offline   Reply With Quote
Old 02-02-2004, 11:52 PM   #2
hippy
Member#: 36528
2002 Impreza Wrx
either you have a serious leak(like the egt poping out of the bung) or you need to bleed more air with the boost controller.
Old 02-03-2004, 12:06 AM   #3
samh22a
Member#: 30710
04 STI
Any quick and ez way to spot a leak ??
Thanks
Sam
Old 02-03-2004, 12:06 AM   #4
supermarkus
Member#: 6971
2008 WRX STi
SSM
Soapy water or if you're checking the intake tract, some carb cleaner.
supermarkus is offline   Reply With Quote
Old 02-03-2004, 12:17 AM   #5
hippy
Member#: 36528
2002 Impreza Wrx
it really doesn't look like a leak to me. It looks like your boost controller is keeping the boost down at the lower rpms..... I'd start by trying to adjust the boost controller better.
peace
Old 02-03-2004, 12:19 AM   #6
samh22a
Member#: 30710
04 STI
any1 knows how to tweak an HKS EVC ??
Old 02-03-2004, 12:51 AM   #7
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
do you have it set for poppet or swing valve?
mattjk is offline   Reply With Quote
Old 02-03-2004, 08:58 AM   #8
samh22a
Member#: 30710
04 STI
Do you mean internal or external WG ?
Old 02-03-2004, 10:39 AM   #9
WRX Jim
Member#: 22321
If your usin the utec why not use the ABC... set up a few maps then you have the same thing as the boost controller.
WRX Jim is offline   Reply With Quote
WTB: vf-34 , vf-39, or vf-43 ng_wrx_05 Private 'Wanted' Classifieds 4 07-14-2007 03:57 PM
VF-34 Spool Point... BlackEyeII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-11-2005 06:52 AM
vf 28, vf 30, vf 34 mcornale Tri-State Area Forum 4 12-07-2004 05:58 PM
Are you guys using your heat shields after installing your VF-22, VF-30, VF-34 turbo? blitz01 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-26-2003 12:04 AM
VF-35 vs VF-34 vs VF-30 schnoog Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-31-2002 11:13 PM
