Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 02-03-2004, 01:51 AM   #1
crazyhorse
Member#: 19502
2010 Impreza with no
scoop. =(
Cool 600cc Injectors for free
Ok.. starting a different thread here because well... The other has gotten way too long.
Here's the deal:
740cc is just toooo much for me. My power goals are around 300whp and I'm running a 16G turbo (or will be very soon rather) So... I don't wanna pay $400 for injectors.. but I don't want too much fuel so the cutting off the cap method isn't for me. What do I do?
After nhluhr talked about the hole size and drilling it out a bit bigger I figured I'd give it a shot. (Was his idea originally not mine) Kingpin (awesome vendor!) was kind enough to send me a test set of injectors. So... I had one drilled and sent to RC for testing. Basically... all I had done was to have the original holes widened.
Drill bit size: .5mm
Looks a lil rough.. kinda scared me at first.. was done by hand by a very good goldsmith friend of mine. She's practically an artist with a dremel. Anyways.... I FINALLY got the results back from RC Engineering.
What size drill bit you ask? Well... I'm not sure yet. She's on vacation at the moment. I'll find out tomorrow and let you know. As you can tell by the picture, you can't go much bigger at the risk of going into the other holes. You could drill more holes, but that's a bit tougher and I'll leave that for someone else to test out unless I can get another set. It cost me $33 with shipping to get this one injector cleaned and flow tested. I plan on sending one more to make sure they match and then these puppies are going on my car.
crazyhorse is offline   Reply With Quote
Old 02-03-2004, 06:08 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....mmmm....I've got drills all the way down to #80.....ch...you may have solved my dilema of what to do with my 'blues'
Old 02-03-2004, 08:56 AM   #3
Subahaulic
Member#: 51163
02-5 02WRXwgn &05FXT
sedona & cayenne red
OK--let me be the first to provide the "mystery" values for the enlarged holes (i.e., drill bit size). I took crazyhorse's photo over to photoshop and digitally measured the enlarged image of the injector tip and the new holes. Given that the blue injector tip is 8.13 mm in diameter, the holes are now 0.49 mm diam. In our English system this equates to 0.32 inches = tip X 0.019 in. holes. These numbers are approximate, but should be pretty accurate.
Mark
Subahaulic is offline   Reply With Quote
Old 02-03-2004, 10:37 AM   #4
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Now it's a matter of drilling consistency to make 4 injectors with matching flow...
jblaine is offline   Reply With Quote
Old 02-03-2004, 10:51 AM   #5
crazyhorse
Member#: 19502
scoop. =(
Well.. the good news is.. if you use the same tip I don't see how you could mess it up. GOOD idea with photoshop!! I didn't even think of that. We'll see how close you are when I call her today!
Old 02-03-2004, 01:01 PM   #6
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
Well done man. way to take this to the nexy level. Keep up the good work. If I can help in any way please let me know. Thanks.
Kingpin is offline   Reply With Quote
Old 02-03-2004, 06:33 PM   #7
crazyhorse
Member#: 19502
scoop. =(
Damn good work with photoshop!! Just got off the phone with Terry...
The drill bit was .5mm
Old 02-03-2004, 08:07 PM   #8
hippy
Member#: 36528
2002 Impreza Wrx
Hey there, I hope noone kills me for this cause you all obviously think this is good an all but I have a question. If you can tune for 740cc injectors, then what's the harm in having injectors that are a little bugger then needed? Isn't the lower duty cycle a good thing? I mean, you already paid for the engine management, why pay for modified injectors when you can get one with lower duty cycles for less? Thanks,
hippy
Old 02-03-2004, 08:11 PM   #9
crazyhorse
Member#: 19502
scoop. =(
It's merely another option. Who said anything about paying?
600cc = easier to tune for. If you bothered to read the other thread there are concenrs about timing when tuning for 740s.
AND.. if you need more than 600 later.. well just take the cap completely off and the problem is solved.
Edited to not hurt Hippy's feelings
Old 02-03-2004, 08:34 PM   #10
hippy
Member#: 36528
2002 Impreza Wrx
What other thread? Eh, sorry to inch in on your thread I guess.
peace
Old 02-03-2004, 08:39 PM   #11
crazyhorse
Member#: 19502
scoop. =(
The 740cc thread. If you pull a ton of fuel out you run into timing concerns. This is a free mod too really... it's just a lil trickier and takes a steady hand.
Old 02-03-2004, 08:56 PM   #12
hippy
Member#: 36528
2002 Impreza Wrx
yeh, I have more concerns about drilling holes in the injector then what the ecu wants to do with the timing while my utec controls it. I dunno, I didn't mean to throw your thread off, I just thought people would get more consistent results by taking the cap off then by drilling holes in it. I know the concerns, I just don't get the difference between 740 and 600 when tuning(other then cold starts).....
Old 02-03-2004, 09:24 PM   #13
Scoobie Steve
Member#: 2289
1998 11.87@112mph
Subaru L Ver 6 STi Type R
That looks very shady to me. I would feel much better taking the disk right off. If you look at the original holes in the injectors closely you will see they arent holes at all. They have a shape to them that helps the pattern.(not that i feel the pattern means much at all) I would also be concerned about getting drill shavings behind the disk that might dislodge and plug a hole.
Scoobie Steve is offline   Reply With Quote
Old 02-03-2004, 09:27 PM   #14
hippy
Member#: 36528
2002 Impreza Wrx
that's what I'm saying. All this and having to get them flow tested just because some people have concerns about tuning and timing? I just thought the origional concept was amazing and this is a little much(course I'm just trollin).....
Old 02-03-2004, 09:37 PM   #15
crazyhorse
Member#: 19502
scoop. =(
Uh guys... RC Engineering knows more about injectors than anyone here... If they tell me my spray pattern is excellent.. I'm going to believe them. But.. if you don't want to do it.. then don't.
Simple fact... it works. I got 600cc's and that was my goal. RC Engineering says the spray pattern is Excellent.. and since the injector has been flowed... It's pretty obvious that there are no shavings in it. Not like it would be hard to clean it out yourself with some carb cleaner or something.
This isn't rocket science... and our engines are not super delicate pieces of machinery. The sooner people get that through their heads the better off the community will be in general. Time to try something new instead of just doing whatever the next company that comes out says is the way to do it.
Old 02-03-2004, 09:41 PM   #16
Templar
Member#: 483
2010 RSV4
Aprilia Racing Black
Not only is it about time someone said it, it was well said.
Templar is offline   Reply With Quote
Old 02-03-2004, 09:58 PM   #17
hippy
Member#: 36528
2002 Impreza Wrx
I'm glad you got your injector to flow the right amount, but do you think all four will? If all four do, do you think it's worth paying to get all them flow tested when the origional mod required no flow testing? If you haven't tried tuning 740cc injectors, why do you think they would be so much harder then tuning your 600's? I don't see the logic in making a cost free carefree mod into a test of how well someone can hold a drill and if the injector will flow the right amount.......
Old 02-03-2004, 10:18 PM   #18
crazyhorse
Member#: 19502
scoop. =(
Hippy... When you know something about tuning.. then come back and get on my case. Until then... Keep your ignorant comments to yourself please. I have a very good friend running 740s and I've helped him on some of his maps so yes, in fact, I have worked with the 740s. I have NO need for 740s and it's more trouble than it's worth for me to run them. So... troll elsewhere. If you want to run 740s.. go cut the caps off. This thread is for people interested in running slightly less than that.
And for the mentally challenged in the group... If you drill out holes with a .5 mm drill bit.. and use the same size drill bit for each hole.. Naturally... the holes will be the same size. So... they're going to flow the same. There is no test as to how well Terry can hold a drill. She's a qualified professional and does incredible work.
Also... I'm the only person putting up my own money to have the injectors flow tested to ensure the mod works. After that you can drill them yourself or whatever works for you. This is simply another option. Now... have I explained that enough times for you to get it through your head? I hope so because I'm done trying to explain.
Old 02-03-2004, 11:01 PM   #19
hippy
Member#: 36528
2002 Impreza Wrx
I'm interested in 600cc injectors, and am not experienced like you are in tuning, that's why I ask. I don't need 740cc injectors either, but it's nice to know that we can keep everything peaceful. Also, I must be mentally challenged, cause when I drill a hole in something, the hole usually gets bigger when I pull the bit out. I'm not a jeweler and don't know the ins and outs of drilling a perfect hole, but I don't really think it can be done by hand(could be wrong). On a realistic note, I'd like to know when you have finished tuning a car with these injectors and if it was any easier then your friends car(this is what I wanted in the first place but you have to be....). Ya think there will be a wave of people with 1 or 2 cylinders leaning out? "I swear it's stock".....
Old 02-03-2004, 11:36 PM   #20
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
wow spray pattern excellent!!!
Old 02-03-2004, 11:40 PM   #21
crazyhorse
Member#: 19502
scoop. =(
I can spray with the best of'em
Old 02-03-2004, 11:53 PM   #22
cronic
Member#: 9749
Did you get the results on the second one? I am curious if they both tested the same..
BTW nice going.
Dave
cronic is offline   Reply With Quote
Old 02-03-2004, 11:56 PM   #23
crazyhorse
Member#: 19502
scoop. =(
Sending it out this week... I was still waiting for the paper on the 1st one. I'll probably send all 3 in for flow testing. I'm not sure that I want to spend the $24 each to have them cleaned.. I can clean them myself... but we'll see. $100 is still cheap for 600cc's I suppose. Remind me again why I turned down the offer for donations?!
Old 02-04-2004, 12:07 AM   #24
cronic
Member#: 9749
I couldn't figure out that either Well anyway you slice it $100 is a steal for 600's
Dave
Old 02-04-2004, 03:43 AM   #25
Uncle Scotty
Member#: 16200
OK buy Nates beans
Well....that damn 0.5mm bit is tiny.....
740CC injectors for free? Kingpin Engine Management & Tuning 801 09-18-2013 12:26 PM
Ultimate Racing 600cc injectors, td04, stock WRX injectors jnait Engine/Power/Exhaust 17 12-15-2007 11:55 PM
Helix 820cc injectors and UR 600cc injectors CHEAP!!! ilivas Engine/Power/Exhaust 24 06-08-2007 02:03 AM
attn to whoever sent me injectors for free modification nhluhr South East Region Forum 0 07-04-2004 12:15 AM
TX: UR 600cc Injectors for sale Justin962 Private 'For Sale' Classifieds 12 04-10-2004 03:55 PM
