Old 02-17-2004, 12:55 PM   #51
ChristophWRX
Member#: 19009
2005 M3/WRX by clark
silver/white
I think i might try this....
CZ
ChristophWRX is offline   Reply With Quote
Old 02-19-2004, 09:17 AM   #52
Rickyh
Member#: 40453
I would LOVE to do this but I don't think I have a steady enough hand for it.
Rickyh is offline   Reply With Quote
Old 02-19-2004, 10:35 AM   #53
Teh Legacy
Member#: 9853
to keep your mouth
shut.
not a bad idea! I may have to try this on a spare set of injectors (knowing me i'll bork it up)
Teh Legacy is offline   Reply With Quote
Old 02-19-2004, 03:28 PM   #54
subieworx
Member#: 47769
I think the injector suplier companies are pissing their pants right now!
subieworx is offline   Reply With Quote
Old 02-19-2004, 04:12 PM   #55
ChristophWRX
Member#: 19009
silver/white
LOL
Old 02-19-2004, 04:27 PM   #56
Aaron'sWRX
Member#: 34150
02 WRX
Post
If you guys dont want to mod your injectors, Crazyhorse can send them off to terry to get them drilled. Look at it this way, you can pay for professional service or chance at having to buy new injectors if you mess up.
If you do it yourself, buy at least 2 drill bits. I found that 1 drill bit goes dull after 2 injectors.
Aaron'sWRX is offline   Reply With Quote
Old 02-19-2004, 05:02 PM   #57
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I bought 8 ...better use lots of bits and get nice clean holes every time.
No coffee, get laid, relax, sit down and have at it
Old 02-19-2004, 08:18 PM   #58
blaznasn
Member#: 6750
anyone try and see if any machine shop will do this?
blaznasn is offline   Reply With Quote
Old 02-23-2004, 05:59 PM   #59
saggioWRX
Member#: 18994
08 GTS
10 CTS W
Does anyone know how to convert, GPH (Gallons Per hour) into cc?
Besides:
1 Gallon = 3785.412cc
I flow tested a stock injector that I modified, and it flowed 175 Gallons Per Hour.
I'm trying to calculate that into cc terms.
So cc is Cubic Centimeters.... but at what rate?
Thanks
saggioWRX is offline   Reply With Quote
Old 02-23-2004, 06:10 PM   #60
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I don't know how you would convert it...sort weird how one has time involved and the other doesn't...go figure
unless you were to go by weight or by volume but they aren't even close
try playing with this
http://www.turbonetics.com.au/ATS_info_estfuel_flo.htm
Old 02-23-2004, 06:15 PM   #61
crazyhorse
Member#: 19502
2010 Impreza with no
scoop. =(
You gotta use lbs/hr
CC/MIN = LBS/HR X 9.71 OR LBS/HR = CC/MIN X .103
crazyhorse is offline   Reply With Quote
Old 02-23-2004, 06:22 PM   #62
saggioWRX
Member#: 18994
08 GTS
10 CTS W
so whats 175 GPH converted to cc?
Old 02-23-2004, 06:25 PM   #63
crazyhorse
Member#: 19502
scoop. =(
Wait a minute.... 175 GPH... that can't be right. There's just no way.... lol *scratches head*
Old 02-23-2004, 06:25 PM   #64
Homemade WRX
Member#: 33782
96 bastard child
well how much does a gallon of gas weigh?...then plug it into the formula
Old 02-23-2004, 06:47 PM   #65
saggioWRX
Member#: 18994
08 GTS
10 CTS W
http://www.freebuck.com/tools/calculators/units.htm
plug 175 in the "Gallon" box at the bottom it comes out to .662
So does that mean it's a 662cc ?
"Wait a minute.... 175 GPH... that can't be right. There's just no way.... lol *scratches head*"
^^^ Thats what I was thinking...
Old 02-23-2004, 07:37 PM   #66
Homemade WRX
Member#: 33782
96 bastard child
gasoline ways between 5.8 and 6.5 lbs...so we'll take the average at about 6.15 lbs...which would equal about 1076.25 lbs of gasoline in an hour(weight of gallon of gas times the number of gallons per hour)...right?
so each lb of gas is equal to 615.51415 cc using value you gave above... so multiply that with number of lbs an hour and divide by sixty minutes...right??
some on check me on this please because my number is way off the scale....11040.785 cc/min
where did you get this test done? and are you sure it is gph?
Old 02-23-2004, 07:40 PM   #67
Homemade WRX
Member#: 33782
96 bastard child
I know that a Ford lightning's injectors are only like 43 lbs/hour
about 6.99 gph
Old 02-23-2004, 07:40 PM   #68
crazyhorse
Member#: 19502
scoop. =(
You're not way off... his number is... Think about driving your car and going through 175 gallons in an hour... that's a BIG injector
Old 02-23-2004, 07:41 PM   #69
Homemade WRX
Member#: 33782
96 bastard child
OK just glad I'm not going insane or sucking at math....that is bad for an engineering student
Old 02-23-2004, 07:54 PM   #70
blaznasn
Member#: 6750
here's what i got 175G/H(1L/.264G)(1000ml/L)(1cc/1ml)(1H/60min) = 11047.95cc/min, haha, someone want to check that
edit: just saw a post above with a similar answer
Old 02-23-2004, 08:30 PM   #71
Homemade WRX
Member#: 33782
96 bastard child
so what was the weight of your gallon of gas? or did you do it by volume?
Old 02-23-2004, 11:13 PM   #72
blaznasn
Member#: 6750
did it by volume
Old 02-24-2004, 12:13 AM   #73
Homemade WRX
Member#: 33782
96 bastard child
yeah I did weight...
Old 02-24-2004, 11:11 AM   #74
saggioWRX
Member#: 18994
08 GTS
10 CTS W
Sorry for the confusion. This place I had it tested at, must of did it totally wrong!
That's way to much fuel!
Old 02-24-2004, 01:49 PM   #75
Aaron'sWRX
Member#: 34150
02 WRX
Post
I got my results from RC today. Using a .5mm drill bit and having mike (local goldsmith) do the work, resulted in two 720cc injectors and two bad ones. (they leak) Under magnification, the holes look great on every injector. So, its possible that I had two bad injectors to start with or two injectors were drilled too deep. Mike says that drilling the holes were easy and that hitting the bottom wasnt an issue. Who knows?? Crazyhorse should have his results in a week or so.
740CC injectors for free? Kingpin Engine Management & Tuning 801 09-18-2013 11:26 AM
Ultimate Racing 600cc injectors, td04, stock WRX injectors jnait Engine/Power/Exhaust 17 12-15-2007 10:55 PM
Helix 820cc injectors and UR 600cc injectors CHEAP!!! ilivas Engine/Power/Exhaust 24 06-08-2007 01:03 AM
attn to whoever sent me injectors for free modification nhluhr South East Region Forum 0 07-03-2004 11:15 PM
TX: UR 600cc Injectors for sale Justin962 Private 'For Sale' Classifieds 12 04-10-2004 02:55 PM
