Old 02-24-2004, 05:08 PM   #76
Subahaulic
Member#: 51163
02-5 02WRXwgn &05FXT
sedona & cayenne red
I wonder why crazyhorse got 600cc from the .5mm drill mod, while you got 720cc. The "circumcision mod" has resulted in several sets flowing 740cc vs. five sets @ 850cc. I am begining to think we are seeing a variance in machining or fuel pressure during testing; although, RG Eng. was the tester in most cases.
Anyone with ideas?
Subahaulic is offline   Reply With Quote
Old 02-24-2004, 05:35 PM   #77
crazyhorse
Member#: 19502
2010 Impreza with no
scoop. =(
I'm going to triple check the size of that bit first....
crazyhorse is offline   Reply With Quote
Old 02-24-2004, 07:23 PM   #78
Aaron'sWRX
Member#: 34150
02 WRX
Anyone with ideas?
The 740cc was the injector under 30psi, not the standard 43 psi for flow testing the injectors. So they are really 850cc injectors. It was just a difference in how much psi was ran doing the flow test..
Aaron'sWRX is offline   Reply With Quote
Old 03-10-2004, 10:52 AM   #79
geronimo66
Member#: 26929
2000 Impreza
with Gremilins
Does anyone have access to a machien shop that could make a simple jig and a repeatable result. That would be worth some $$ to people I think. Send you stockers in for a verified 600cc inj.
geronimo66 is offline   Reply With Quote
Old 03-12-2004, 10:13 AM   #80
Subahaulic
Member#: 51163
Just to update this discussion--I now have both WRX blue injectors and STi piink injectors that have been precisely examined microscopically, with the following results/ observations--and the news is not good.
The spray hole sizes are as follows: WRX=0.25mm
STi = 0.3mm
The bad news is that, aside from the very small aperature sizes, the Subaru/Denso engineers have designed these at severe angles to create a difficult to replicate fan-like dispersal spray. The STi pinks also have much steeper angles (=wider spray capability) than the WRX blues.
My conclusion is that realistically increasing the small aperature sizes by drilling the blues, combined with the requirement to slant them for dispersion, is not likely to be achieved by those of us that need between 440 to 700cc's/min of flow.
This in no way reflects on the efficacy of the "decapitation/circumcision mod" to get ~850cc's/min, which has now proven to be readily tunable by those requiring that much flow.
Old 03-12-2004, 02:16 PM   #81
blaznasn
Member#: 6750
nice info subahaulic, but if we drill the wrx inj. then we would get a different spray pattern, and if we switch to sti pinks we get a different spray pattern, so in both cases we get different spray patterns. Also does anyone know if they sell .3mm bits out there?
since .5mm seems to leave very little room for error.
blaznasn is offline   Reply With Quote
Old 03-13-2004, 02:35 AM   #82
ilivas
Member#: 56056
2004 wrx
T04R Turbo / 8k rpm 257
is there anyway we can buy STi caps to put on our blues?
ilivas is offline   Reply With Quote
Old 03-26-2004, 05:33 PM   #83
zacek
Member#: 19467
02 WRX
WR Blue
any updates crazyhorse?
I wonder to what extend does RC checks for the proper pattern.
zacek is offline   Reply With Quote
Old 03-26-2004, 05:56 PM   #84
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
That small is getting real tough to use for anyone who isn't trained, or has learned to deal with bits that small.
.3429mm .0135" #80
.3683mm .0145" #79
.3969mm .015625" 1/64"
.4064mm .016" #78
.4572mm .018" #77
.5mm .0197"
.508mm .02" #76
.5334mm .021" #75
.5715mm .0225" #74
.6096mm .024" #73
.635mm .025" #72
.6604mm .026" #71
.7112mm .028" #70
See: http://www.ehobbytools.com/index.htm...tml&lang=en-us
Old 09-16-2005, 09:55 AM   #85
vtt
Member#: 46094
so
how this story finished?
vtt is offline   Reply With Quote
Old 09-16-2005, 10:16 AM   #86
crazyhorse
Member#: 19502
scoop. =(
I never did flow test the injectors I had drilled.... Ended up buying an STi...
Old 09-19-2005, 10:52 AM   #87
spoolinsuby
Member#: 80182
Look ing for a GG
Wagon
I was looking forward to seeing if all 4 ended up spraying 600cc's
spoolinsuby is offline   Reply With Quote
Old 09-19-2005, 11:22 AM   #88
Crashman287
Member#: 94605
2005 Saab 9-2X Aero
Midnight Black
Ok, noob here with a question on this mod.
From what I'm gathering after reading this, are you guys drilling out your stock injectors to increase the bore size? It sounds like it should work in theory, but it also sounds kinda sketch. Let me know if thats what you're doing or if I just have my head up my ass.
Crashman287 is offline   Reply With Quote
Old 09-19-2005, 09:21 PM   #89
wrxpeed
Member#: 49958
'03 Cobra DSG
SOLD '02 WRB WRX
its more a matter of taking off a restricting endcap more than it is "boring" it out. The end cap is cut off ever so slightly at the weld.
wrxpeed is offline   Reply With Quote
Old 10-18-2005, 03:47 PM   #90
quadturbowrxgtr-s
Member#: 57515
04 WRX Ver. 8 swap
/87 FJ60 /Hewes Redfisher
any update?
quadturbowrxgtr-s is offline   Reply With Quote
Old 10-18-2005, 07:25 PM   #91
checque
Member#: 68562
RIP Edwin
I read 4 pages of posts, hoping to add another page to my book of tricks, only to learn he bought an STi. Where was the commitment at at bettering the community?!
Well, congrats on the STi and I hope your finger gets slammed in a door for not following through.
checque is offline   Reply With Quote
Old 10-18-2005, 07:27 PM   #92
crazyhorse
Member#: 19502
scoop. =(
It's an evil plot for me to sell more cars actually And now I'm thinking about ditching the 04 for an 06 STi!
Old 10-19-2005, 04:28 AM   #93
darksands
Member#: 75122
2005 Impreza WRX
Crystal Gray
One question I have is if enlarging the holes will have any affect on the ionization of the gas. I know that removing the cap gives you more cc's but another issue with that is that the gas doesn't ionize properly reducing gas efficiency. Will enlarging the holes have the same effect and reduce efficiency?
darksands is offline   Reply With Quote
Old 10-19-2005, 09:57 AM   #94
ahains
Member#: 28823
2004 WRX Wagon
I think I would much prefer to cut off the end caps, if sticking with the stock ECU.
The stock ECU has a value in the programming that specifies injector size. You just change this as appropriate and you're good to go - no crazy timing due to lying about the air flow.
I guess if you are using piggybacks then that is a drawback in this case.
-Adrian
ahains is offline   Reply With Quote
Old 10-19-2005, 10:48 AM   #95
quadturbowrxgtr-s
Member#: 57515
04 WRX Ver. 8 swap
it is a problem with Ecutek as well.
Old 10-19-2005, 01:37 PM   #96
ahains
Member#: 28823
2004 WRX Wagon
Why would it be a problem for Ecutek? Can't they just adjust the injector scaling values as well?
Thanks!
Adrian
Old 10-21-2005, 11:42 PM   #97
quadturbowrxgtr-s
Member#: 57515
04 WRX Ver. 8 swap
IDK but when I spoke with my "tuner" and mentioned doing the "cap cut" he said they have had problems with a few they have done as far as idle goes.
Old 10-28-2005, 08:26 PM   #98
quadturbowrxgtr-s
Member#: 57515
04 WRX Ver. 8 swap
Update?
Old 10-28-2005, 08:33 PM   #99
crazyhorse
Member#: 19502
scoop. =(
Update is I bought an 06 WRX Wagon.... No idea where those injectors ran off to
Old 10-29-2005, 10:45 AM   #100
quadturbowrxgtr-s
Member#: 57515
04 WRX Ver. 8 swap
oooh '06 wagon with the corazon kit would be sex on wheels!
or the dolphin kit that's nice too!
740CC injectors for free? Kingpin Engine Management & Tuning 801 09-18-2013 11:26 AM
Ultimate Racing 600cc injectors, td04, stock WRX injectors jnait Engine/Power/Exhaust 17 12-15-2007 10:55 PM
Helix 820cc injectors and UR 600cc injectors CHEAP!!! ilivas Engine/Power/Exhaust 24 06-08-2007 01:03 AM
attn to whoever sent me injectors for free modification nhluhr South East Region Forum 0 07-03-2004 11:15 PM
TX: UR 600cc Injectors for sale Justin962 Private 'For Sale' Classifieds 12 04-10-2004 02:55 PM
