Old 02-03-2004, 02:14 AM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default front clip help
Well I got the front clip and its a lot more work than I relized. what my brother and I want to do is put jackstands on the engine crossmember and tranny crossmember unbolt everything and then lift up the shell of the clip off so whats left is the engine and tranny sitting on the jacks.
another thing whats the best way to remove all the wiring off of the clip. i'd prefer if we were able to push it though the fire wall in to the engine comparment so once the clip is off its all of it is connected.
and whats in the engine bay of the jdm clip that I won't be using on my usdm car?
scobaru is offline   Reply With Quote
Old 02-03-2004, 03:35 AM   #2
vinster02
Member#: 7888
02 wrx
WR Blue
The wiring harness is a PITA. As far as lifting the shell off thats how I did it. Good luck the fun has only begun, wait till your putting that harness into your donor car or figuring the fuel problems, Then there is the whole hydrolic clutch issue.not to mention the steering rack swap. This is just the stuff that i've been hearing about. i havent yet started the install. i'm still collecting the extra parts needed. If you come across a wiring diagram for the JDM cars Send me a link. Later, Vince..
vinster02 is offline   Reply With Quote
Old 02-03-2004, 12:04 PM   #3
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
what year do you need? soon as I get home I can send u a link to wiring for after 97 I'm not sure how much help that is to you . I still need diagrams for usdm where did you get yours?
also how did you get the wiring out of the clip as far as what was in the interior?
Old 02-04-2004, 02:04 AM   #4
pitcrew
Member#: 45715
1995 2.?L miami vice
Heavy Metal
If your front clip is damaged in the front...cut the top and bottom of the rad support out and it will be easier to slide the engine out...or slide the shell off.
For your wiring.:
You will need to unclip a few harnesses to get the wiring out of the car intact. I just took all of the wiring out of a 99RS. Label everything and take pics if you can to remember how things were--you may not need to but it is easier to do it...than to wish you had.
Only disconnect things if you NEED to. There is no reason to cut anything.
The harness will push through the firewall...just put some pressure on rubber grommets until they push in. Use your head: follow the harness from where it enters the engine bay until you reach a clip...then label and unclip. Repeat this 4 or 5 times and you should have a disconnected harness to push through the firewall. The wiring for the main relays under the hood should run from inside the car out under the fender and back in at the nose to the relay box. You can unhook the wiring at the box and push it out through the fender.<<<This harness also continues down and around the front of the car to the other side for lights/foglights and ABS(if you have it).
You will need to remove the dash(EVERYTHING) to access the interior harness. The wiring runs along the inside of the firewall which is behind your heater. The heater is a pain because it will stick to the floor(tar sound-deadening) just get all of the bolts off and start to tug. Remember how it comes out because you'll be taking it out of your project car soon.
Take your time...do it right.
Good Luck
pitcrew is offline   Reply With Quote
Old 02-04-2004, 04:16 AM   #5
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
if you gots skills, you can strip out the entire clip (sans pulling the motor) in about 5 hours. see if you can beat me on it. not a thing cut either :P
radiator, lights, front end, hood, everything. entire interior and wiring harness pulled out. the real deal
2 guys with hand tools......
raarf!!
supermoose is offline   Reply With Quote
Old 02-04-2004, 12:09 PM   #6
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
mine was stripped already no front bumper no grill headlights all there was were dented fenders no dash too just gauge cluster with stero and junk wasn't to happy but I bought the clip for really cheap. and got the rear diff
wtb: jdm ver8 front clip or 2004 sti front clip ej_trbo_si_eater Private 'Wanted' Classifieds 1 06-05-2009 11:26 AM
WTT 04 WRB front clip for 02/03 WRB front clip shamrock 05 MWSOC Private Classifieds 3 06-27-2008 11:54 PM
help me decode my JDM front clip supermoose Transmission (AT/MT) & Driveline 8 12-30-2005 10:41 PM
need help with front clip search 2.5RS-GC8 Texas Impreza Club Forum -- TXIC 7 05-29-2004 05:01 AM
Scooby mechanics: little help needed taking apart my jspec Rex front clip... annointed Tri-State Area Forum 32 11-19-2001 08:46 PM
