Old 03-10-2004, 08:16 PM   #26
mixup52
Member#: 39691
2002 WRX Wagon
So what is all included for that 300 price of yours kingpin?
mixup52 is offline   Reply With Quote
Old 03-10-2004, 10:00 PM   #27
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
$300 includes the clutchand the flywheel. Thanks.
Kingpin is offline   Reply With Quote
Old 05-23-2006, 01:01 PM   #28
rickeolis
Member#: 72134
2005 WRX Wagon
3" TB\UP-HT Springs-Rotas
Subaru Stars
Does anyone have pics of both a WRX (2004-05) and the STi clutch package for comparison?
I'd like to retain my lightweight flywheel if I could...
rickeolis is offline   Reply With Quote
Old 07-17-2006, 12:19 AM   #29
hotrex
Member#: 61924
Kingpin,
How has the case stood up?
Cracking etc or doing ok?
Thanks
hotrex is offline   Reply With Quote
Old 07-17-2006, 11:09 AM   #30
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
There have never been any issues with case stability or craking due to the material removed. The amount is minimal. Thanks.
Old 07-17-2006, 09:32 PM   #31
hotrex
Member#: 61924
Thanks for the reply,
1 more stupid one, you could still use the satndard 5 speed starter motor?
someone mentioned something about the teeth not meshing.
Thanks again.
Old 07-18-2006, 10:39 AM   #32
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
The starters are the same. Identical. Can use either. Thanks.
M
Old 07-23-2006, 08:09 AM   #33
hotrex
Member#: 61924
Anyone have any pics of how much they ground of the case?
or could you photoshop this pic with how much and where?
Also, any issues with changing gears etc? Somone mentioned issues, because the fork is a different shape and the clutch sits further away from the flywheel?
Any comments at all will be much appreciated as i don't want to start and find out it's no good.
Thankyou.
Old 07-28-2006, 09:41 AM   #34
hotrex
Member#: 61924
anyone done this and remember where and how much material they took off?
Thanks
Old 07-28-2006, 10:01 AM   #35
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
I did it personally. I would say about 1/2"-3/4". Thanks.
M
Old 07-29-2006, 12:50 PM   #36
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Make sure you use a stock STi PP. Aftermarket upgraded STi PP will not clear......failed for me.
CoolRex is offline   Reply With Quote
Old 08-12-2006, 10:05 PM   #37
hotrex
Member#: 61924
Have nearly finished the install, put the operating cylinder on and with the pin fully extended, it just touches the clutch fork.
Any ideas what is wrong.
THe fork is engaged etc
Thanks
Old 08-13-2006, 01:26 AM   #38
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Not sure what you are trying to say????
Old 08-13-2006, 05:54 AM   #39
hotrex
Member#: 61924
sorted.
Thanks
Old 11-03-2006, 08:07 PM   #40
MSo
Member#: 5008
2002 /06 STi GGA
SRP
Thanks
What was the problem?
Interesting on this swap!!!
Thanks
MSo is offline   Reply With Quote
Old 11-03-2006, 08:12 PM   #41
MSo
Member#: 5008
2002 /06 STi GGA
SRP
M
Hi!
Can you use Pic. of the tranny, to show where and how dip to grind ?
Thanks
Old 11-04-2006, 09:50 PM   #42
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
Make sure you use the 5MT clutch fork in the 5MT, even if you are using a 6MT clutch.
bluescoobywagon is offline   Reply With Quote
Old 11-05-2006, 08:35 AM   #43
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
Originally Posted by MSo View Post
Hi!
Thanks
Don't grind it all the way down. Just hack a good 1/2 of it off. The starter hole you need to be careful not to grind it down a lot as it's thin there but take a good chunk of the material off the top. And the bottom portion where the flywheel teeth hangs out at the bottom needs to be trimmed down a good 1/4 -1/2". You actually don't 'have' to do all the webbings but I figured better safe than sorry and not have to drop the tranny again. Shaving all of them isn't gonna hurt a thing.
Old 11-05-2006, 10:34 AM   #44
MSo
Member#: 5008
2002 /06 STi GGA
SRP
Many thank's Rex
MSo.
Old 11-05-2006, 11:04 AM   #45
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
No problem.
Old 11-27-2006, 10:27 PM   #46
03GLHWRX
Member#: 30369
03 WRX SW
Default Help I still don't get it
I'm putting a STI clutch, pressure plate, and flywheel into a WRX also. It has been a frustrating process. The problem has been touched on above but I'm still unsure how to correct it. I've tried with both a STI fork and a WRX fork and in both cases the top of the fork is too far forward and the cylinder is near full extension just to contact the fork. The WRX fork is better but unworkable. I am using the WRX to bearing in all cases, and its definitely snapped in. I see that the STI clutch assembly is thicker than the WRX or Exedy 2P clutch assemblies that I have (measuring from crankshaft to tob mounting ring) so this is definitely the cause. What is the cure? The cure can't be as simple as using the WRX 5MT fork because the tob is in a more rearward position than it would be in a normal WRX. It would make sense that a STI tob would be thinner but from the info I've found on NASIOC this doesn't seem to be the case. Help Please! Kingpin? Hotrex? -I think the answer is in Hotrex's comment "Sorted", but I don't know how to sort!
http://forums.nasioc.com/forums/show...1#post16130955
Mark
03GLHWRX is offline   Reply With Quote
Old 11-27-2006, 10:31 PM   #47
03GLHWRX
Member#: 30369
03 WRX SW
Default 5MT case grinding tip
Tip: Grinding the ribs out of the case is easiest if you have the trans apart and you can gring half of the case at a time. This allows good visibility behind the clutch assembly to see where grinding is needed. You'll first need to measure the distance from the engine / trans mating plane to the crankshaft flange then put the clutch assembly to this position for your trial fittings. Once this position is established then leave the clutch assembly on the shaft and remove / replace the shaft when grinding / fitting. Of course this is only useful if you have other reasons to have the trans apart. With a full transmission I think that clay / caulk may be helpful in determining where grinding is necessary.
Old 03-23-2007, 06:53 PM   #48
03GLHWRX
Member#: 30369
03 WRX SW
Default Follow Up Feedback
I'm writing this four months later for the benefit of anyone putting a STI clutch setup in a WRX trans. I had the troubles described above (quoted below). I never did manage to get that clutch setup to work in the WRX trans despite multiple remove / change / replace cycles. I talked with Kingpin ( think it was him, its been months - or else someone else that does these every day) and he couldn't diagnose what was incorrect in my setup, but suggested that I *might* heve a Tribeca clutch instead of a STI clutch. In the end I used an aftermarket WRX clutch and PP along with a WRX flywheel and had no issues. A few months later the WRX trans died its final death (unrelated issues) and I installed a 6MT. I put the troublesome STI (Tribeca?) clutch, PP, FW, TOB in with the 6MT and it worked perfectly. So I think it was a STI clutch and I think It legitimately wouldn't work (unless I'd made a custom shift fork). Lesson for you: Somtimes it works for some people and sometimes it doesn't. Dunno why. Ya takes some chances if you're going this way.
Mark
Mark
Old 01-09-2008, 09:06 PM   #49
unclemat
Member#: 114530
2005 LGT 6MT wagon
Tribeca is slushbox only....
unclemat is offline   Reply With Quote
Old 06-02-2009, 01:03 AM   #50
myburbsbigger
Member#: 143338
03 WRX
Default Pics
Anybody still have pics of were to grind that aren't dead? Iv'e got the general idea just want to be sure. Thanks
myburbsbigger is offline   Reply With Quote
WTT: 6SPD STI Tranny for a 5SPD WRX Tranny crav3s2k MAIC Private Classifieds 30 09-10-2009 11:08 AM
06 clutch/flywheel in 02 wrx Boarder325 Transmission (AT/MT) & Driveline 2 11-04-2008 07:35 PM
06 Sti swap on a 5spd wrx tranny AlmirWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 05-03-2008 11:36 PM
sti 6 spd clutch &flywheel in 5spd wrx trans ECUtuneOne Transmission (AT/MT) & Driveline 9 09-06-2006 07:34 PM
6spd clutch/flywheel in 5spd transmission OneArmedScissor Transmission (AT/MT) & Driveline 1 12-21-2005 12:05 AM
