Old 06-02-2009, 01:18 PM   #51
DS1
Vendor
Member#: 111780
If you grind the case you will weaken it severely.
-Dylan @ DS1
DS1 is offline   Reply With Quote
Old 10-05-2009, 08:42 PM   #52
inthenameofweez
Member#: 201374
2004 Broken down
slow ass wagon
Does anyone else have opinions on this subject? I've got an STi clutch and flywheel at my disposal. Very cheap. Low miles.
Going into a 2004 wrx.
Would it be easier to just buy the Exedy Stage 1? Are the power capabilities about the same?
inthenameofweez is offline   Reply With Quote
Old 10-06-2009, 08:36 AM   #53
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
I probably wouldn't waste my time for an OEM 6-speed clutch. An ACT Stage 1 would be sufficient for 99% of the people on the road.
If you HAVE to have a 6-speed clutch, just bolt the clutch to the flywheel, slide the clutch onto the input shaft, mark where it hits, and grind away! I think saying you'll "weaken [the case] severely" is overstated at best. You'll weaken it, but to no extent that your average person would notice. You'll break gears before you twist the bellhousing off the case.
Phil
Andrewtech Automotive
AndrewtechAutomotive is offline   Reply With Quote
Old 03-15-2010, 02:22 AM   #54
biggreen96
Member#: 12535
vf39 93 Legacy Wagon
92 Legacy Rally EG33'd
Bump. I'm curious about using a stock 6mt clutch disk with 5mt flywheel and 5mt PP. Going into a 5mt case. It looks like it will fit and work to me... just here for a confirm yes/no.
biggreen96 is offline   Reply With Quote
Old 03-15-2010, 11:11 PM   #55
02RexWI
Member#: 165141
Way to bump an ancient thread...
02RexWI is offline   Reply With Quote
Old 07-21-2010, 09:20 AM   #56
jm747200
Member#: 185418
1999 GC8
Blue 74F
It won't work as they don't have the same diameter. 230mm for the WRX disc and 240 mm for he STI disc.
Tou have to use complete STI kit (flywheel, disc, PP...).
That's what I'm intending to do: mount a 6 speed STI clutch in my 5 speed GC8 gear (with a KAAZ kit inside).
I've read this post with a lot of interest but I've been unable to see any picture of what to be ground in the bell house.
Thanks for pics!!!
jm747200 is offline   Reply With Quote
Old 09-12-2011, 01:42 AM   #57
rdrz14
Member#: 199004
04 WRX BuiltHybrid
Black & Gold
bumping an old thread.. anyone have any tips on where to grind the bellhousing?
rdrz14 is offline   Reply With Quote
Old 12-11-2011, 07:21 PM   #58
sdmideas
Possible Scammer - Buyer Beware
Member#: 280920
2003 wrx
white
Installed an act xt sti clutch today in my 2003 wrx. It was mentioned in this thread that aftermarket flywheel pp combos do not work. That information is not correct. It does work, it takes a little more grinding than per the oem clutch but it is manageable. Used the whole act/flywheel clutch kit, the feel is great! All the torque holding capability I need(I hope) and a much better pedal feel than the previous wrx clutch assembly.
sdmideas is offline   Reply With Quote
Old 06-19-2012, 11:14 AM   #59
maxouni
Member#: 231585
2004 Impreza WRX
Bump an old thread.
I have installed 6spd clutch assembly on my 04 WRX. There is no problem to grind bell housing if tarany is detached, but as 03GLHWRX mentioned - the top of the fork is too far forward. I made custom rod between cylinder and fork but it does not helps. When clutch pedal is fully depressed, TOB contacts transmission case, but PP remains slightly depressed and transmission were unshiftable.
Does anyone know how to resolve this problem?
maxouni is offline   Reply With Quote
Old 09-25-2012, 05:12 PM   #60
salvi
Member#: 188132
I was thinking of using an STI oem clutch/pp/fw, can anyone confirm that this works and why are other people having issues with the fork?
salvi is offline   Reply With Quote
Old 09-25-2012, 11:01 PM   #61
sdmideas
Member#: 280920
2003 wrx
white
I've had no issue with my 2003 5sp ground out to fit the act sti clutch...I love it
Old 10-25-2012, 11:27 PM   #62
2.5rsti_rolling
Member#: 295107
00 2.5RSTI
wht
Im having some issues with the amount to grind also. cant get the Competition PP to clear ahhh!! Can someone please post some damn pictures that work lol but seriously
2.5rsti_rolling is offline   Reply With Quote
Old 01-10-2013, 08:53 AM   #63
EE06STI
Member#: 124580
I'm doing a hybrid swap on my 04 WRX wagon. I have a bunch of STi parts laying around, including a good clutch and flywheel. I decided to fit a clutch in there this week while I'm waiting for the heads to come back. It took a few tries, but I think I have it here:
I basically kept taking off a little, then grinding it down. I haven't bolted it all together yet, but I will definitely spin the motor by hand before re-connecting everything to be 100% sure it's ok. The tricky part is the depth required around the starter. It doesn't come close anywhere except where you can see the bright spots. This took a total of 20 minutes with a flapper wheel. Most of the time was spent R&R the clutch.
Edit: Fitment was for an Exedy stage 1 clutch for a 2005 STi using a stock STi flywheel
EE06STI is offline   Reply With Quote
Old 01-10-2013, 11:01 AM   #64
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
If you use clay like from the kids section of Wal-Mart or any art clay, just place it on the bell housing ribs and you'll know
FuJi K is offline   Reply With Quote
Old 01-10-2013, 12:42 PM   #65
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Play Doh.
xluben is offline   Reply With Quote
Old 01-10-2013, 02:09 PM   #66
EE06STI
Member#: 124580
I did use clay, but the tolerance is loose enough between the pilot bearing and the shaft that you can tilt the assembly a couple degrees, which translates to a little more than 1/4" at the perimeter. It's not possible to know the final location without having the flywheel bolted to the engine. I think I'm pretty close using the flywheel/clutch combo lined up with the pilot bearing to guess.
Old 01-10-2013, 02:49 PM   #67
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
So that's the reason my JDM 6-speed feels so much smoother on engagement from a stop than my 5MT did. I'll vouch for that heavier flywheel right now!
Dave D. is offline   Reply With Quote
Old 01-24-2013, 09:03 AM   #68
EE06STI
Member#: 124580
Update: I put the motor in last night and spun it by hand, only to find that it was rubbing here:
40 minute R&R with some grinding, and it went back together with no problems. The clutch seems to be working properly.
Old 05-03-2013, 09:18 AM   #69
Daddyx20
Member#: 355153
1998 Legacy Outback
White/Grey (two tone)
Doing this is more a pain in the a$$ Than anything.. Takes away from your housing of the five speed. Those fines are there for a reason in the bell housing its for heat transfer. If you just go with an upgraded 5 speed clutch and flywheel you wont have any issues!!
Daddyx20 is offline   Reply With Quote
Old 08-01-2014, 12:12 PM   #70
beatyab
Member#: 378522
2002 WRX Impreza
Im about to jump into this with my 5spd trans. Any updates EE06STI?
beatyab is offline   Reply With Quote
Old 03-01-2015, 12:42 PM   #71
2.5rsti_rolling
Member#: 295107
00 2.5RSTI
wht
I've successfully done this about 4 times with different wrx transmissions. Spray paint the inner bellhousing after a decent grind and slap it all together (loosely) spin by hand and remove the transmission to search for score marks in the paint...when found, these areas will be where needs more grinding (Rinse,lather, repeat lol)
I'm currently working on a simple "how to" but I won't be back from Brazil for a few weeks.
Old 07-19-2015, 11:40 PM   #72
eco-mod
Member#: 313932
'12 WRX
WR Blue
Old post bump! Pulling my engine and trans from my 02 and have a newer(2014?) STI clutch and flywheel Id like to throw in. Any consensus on the release arm issue or is this kind of hit or miss?
eco-mod is offline   Reply With Quote
WTT: 6SPD STI Tranny for a 5SPD WRX Tranny crav3s2k MAIC Private Classifieds 30 09-10-2009 12:08 PM
06 clutch/flywheel in 02 wrx Boarder325 Transmission (AT/MT) & Driveline 2 11-04-2008 08:35 PM
06 Sti swap on a 5spd wrx tranny AlmirWRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 05-04-2008 12:36 AM
sti 6 spd clutch &flywheel in 5spd wrx trans ECUtuneOne Transmission (AT/MT) & Driveline 9 09-06-2006 08:34 PM
6spd clutch/flywheel in 5spd transmission OneArmedScissor Transmission (AT/MT) & Driveline 1 12-21-2005 01:05 AM
