Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 02-03-2004, 05:31 PM   #1
tux
Member#: 40949
2015 fxt
bl ack
Default wrc replica (the cheap 150$ ones)modification
has anyone put hella optilux lamps in their wrc replica headlights?
i was thinking of putting them in and putting HID in the low beam and keeping the regular lamps for high.
also i was wondering if it was possible to get a signal indicator like the morettes or the ominari wrc replica's to fit in the "cheap" wrc replica's (the ones for like 125$)
thanks
tux is offline   Reply With Quote
Old 02-03-2004, 06:42 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
i want to know if anybody has put these into those cheap housings. these are the same ones that prodrive and some other make use. and only about 50bucks a piece.
PARANOID56 is online now   Reply With Quote
Old 02-03-2004, 06:50 PM   #3
superg
Member#: 3385
I put the Hella units in fiberglass accurate replica WRC bezels that I bought from RHR Performance (originally from Rallytech UK.) The units fit fine after swapping the hi and low beams relative to the Prodrive UK300s. I covered the fiberglass bezels with carbon fiber and resin, as I knew that paint would not last long under fire of Colorado sandblasting. Nice lights, nice WRC appearnace.
Superg
superg is offline   Reply With Quote
Old 02-03-2004, 07:38 PM   #4
PARANOID56
Member#: 22035
2003 Brocoma DCab
Do you have any pictures of your setup?
Thanks
Shane
Old 02-04-2004, 09:49 AM   #5
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
These technically are not the ones Prodrive uses in their UK300 setup. The ones you have pictured are Hella H9 90mm units while the Prodrives are Hella H7 90mm units. The H7s are units based out of Germany and seem to produce a bit more light from what I've heard. But everyone says that the H9s are plenty bright and that the cost increase of the H7s compared to the H9s is not really worth it.
If you haven't already, check out the following site for really good info on headlight retrofitting:
http://faq.auto.light.tripod.com/
Hank3 is offline   Reply With Quote
Old 02-04-2004, 10:31 AM   #6
tux
Member#: 40949
2015 fxt
bl ack
how much were you're bezels?
but this is a bit off track. The 90mm units will fit. i was really wondering if anyone was able to fit the optilux 2500 lights and able to aim them. Also i was wondering about the signal light.
What happened to the cheap borla replicas? swede978 Normally Aspirated Powertrain 14 01-03-2008 09:33 PM
New Sparco Prodrives for the WRC Replica Subaruman5 Interior & Exterior Modification 20 08-16-2006 02:51 PM
Why are the WRC headlight so cheap?? JAMES_WRX03 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-16-2003 10:12 AM
v5 replica wing or wrc replica on 01 sedan subaimprez01 Interior & Exterior Modification 1 05-08-2001 01:45 AM
Prodrive WRC Replica Wing? bratmantlz Interior & Exterior Modification 1 03-06-2001 01:52 AM
