#1 |
Member#: 36754
Vehicle:2008 2.5i Rally Blue |
I'm planning to buy a 97 or 98 legacy GT wagon and I'd like to know if a ej20t from japan would fit in there and what do I need to do this conversion and if it's not the best idea what would be an easy engine conversion for this car.
#2 |
Member#: 43916
RMIC
Vehicle:2001 Impreza 4.7 Blue Ridge Pearl |
i know that it is possible, but the wiring may be a little different. the forreter is a taller impreza, and the legacy is basically a streched impreza. if you really want to do the conversion, talk to the people at www.i-speed.com and www.rallispec.com. they are by far the best at swaps and wiring. another option is the leagacy twin turbo engine from japan. i found one somewhere, ill try to look. the wiring may be more of a hassle though
good luck. |
#3 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
Actually the headers on the TT LEgacy engines will have fitment issues because of our LHD steering rack. It would require custom headers to drop in there. BUt the EJ20-T is put in the Lgecay in other workd markets and will fit, In fact in Australia and the UK, a Legacy GT is an EJ20 powered car. It would be no different than any other EJ20 swap, The only difference is you would need ot convert the Legacy wiring over to WRX wiring. If you have the wiring diagram from both the donee and donor, you should be able to wire it up. And like a WRX conversion on an Impreza, plan on spending a lot of hours doing the wiring if you haven't done anything like that before...
#4 |
Member#: 36754
Thanks for alll the info, I knew the ej20tt wouldn't fit cause it's mada for a RHD. My plans would be to put a ej20t then but tje other thing is about the rear differential. The ratio being different on a wrx and a legacy and me knowing nothing about it what do I have to do? Fit a wrx differential or keep the legacy differential?
#5 |
Member#: 38400
Vehicle:2004 WRX Wagon DRZ400SM |
I'm no expert but I don't think it would matter if you're not changing the transmission.
#6 |
Member#: 2181
SCIC
Vehicle:2008 SpecB DGM |
All I can tell you is that a buddy of mine from Switzerland had a '90's Legacy wagon that came with a single turbo EJ20, supposedly the same motor as the WRX...
| Thread Tools | |
| Display Modes | |
| 98 Legacy GT EJ25T swap - need hood | sk8erord | Legacy Specific Parts | 27 | 05-04-2006 05:51 PM |
| 1.6L to 2.0L Legacy GT Engine Swap | The_Bang | Normally Aspirated Powertrain | 4 | 10-06-2005 10:55 PM |
| Legacy GT 5EAT Swapped into WRX? | Shikamaru | Transmission (AT/MT) & Driveline | 0 | 06-04-2004 10:18 AM |
| 2.5 Legacy GT Engine Swap Lots of help needed please! | funkadellic69 | General Community | 3 | 11-08-2002 02:12 PM |
| WRX Wagon and Legacy GT Wheel Swap! | idunoy | Brakes, Steering & Suspension | 7 | 04-14-2002 10:49 PM |
