Welcome to the North American Subaru Impreza Owners Club Wednesday August 20, 2014
Old 02-03-2004, 07:44 PM   #1
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Impreza GC8 '98 RS heagasket anything to worry about?
I'm looking at a '98 RS right now w/ ~70k. Just wondering whether this infamous headgasket leak I keep hearing about is really anything to worry about. Will I have to fix a headgasket if I buy the car, within the next ~50k or so? How much might this cost? Is it DIYable? Most importantly, should I spring for the '99+?
James
jamesfacts is offline   Reply With Quote
Old 02-03-2004, 08:10 PM   #2
Darshu
Member#: 1676
98RS w/ EJ207
2010 Mazdaspeed3
If the car remains stock, it's quite possible you'll never have the problem. If you track it or turbo it, it's just a matter of time. The motor has to come out the replace the headgasket though, so it requires a little more than a headgasket on an I-4 motor.
Darshu is offline   Reply With Quote
Old 02-03-2004, 09:16 PM   #3
liigod
Member#: 30512
01 2.5rs
black
Just spring for the 99, its that simple.
liigod is offline   Reply With Quote
Old 02-03-2004, 09:24 PM   #4
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
83K miles, and the only problem I've had was with my valve stem gasket, or something like it, I can't remember what the exact problem was.
Other than that, I haven't had a major failure yet, and that's with regular work commuting, spirited driving between, a few auto-x's and plenty of highway miles.
Though I do think there is a small leak by my #3 cylinder, it hasnt' amounted to anything huge yet, and I'm waiting to bring it back to my local place to get them to look at it.
Otherwise, I'm perfectly happy with mine.
AJ
AJ711 is offline   Reply With Quote
Old 02-03-2004, 09:28 PM   #5
jamesfacts
Member#: 51282
98 RS
We'll see. I might not be able to afford it. Depends on how the student loan situation works out, and I'd rather have a leaky '98 than nothing...
Old 02-03-2004, 09:52 PM   #6
leondal
Member#: 43114
1998 Legacy GT Turbo
Green
You will get mixed results from different people.
There seem to be head gasket problems with later models almost as much as with the '98s. The 98's have thicker head gaskets anyways.
If you have it non-turbo, there should be no problem. I don't think it matters a whole helluva lot whether you have the DOHC or SOHC. People are just really blowing this overboard in my opinion and the subject has been beat to death.
leondal is offline   Reply With Quote
Old 02-03-2004, 11:19 PM   #7
Those Meddling Kids
Member#: 4140
02 WRX
00 MR-S
Mine never blew in 84K. I have heard that turbo aplications and lots of abuse can blow it. (But, then again, that would probably blow the head gasket on any RS.)
At 70K I would be more worried about a) has the timing belt been changed? b) valve covers leaky? c) cam seals leaking? Check for any oil underneath the engine.
If the timing belt hasn't been changed, you should change every enginge seal you can while you are in there. You don't have to, but they will go at some point, so its cheaper to do it preventatively. At least my mechnic thinks so
TMK
Those Meddling Kids is offline   Reply With Quote
Old 02-04-2004, 02:44 AM   #8
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
if you are mechanically inclined, you can replace them yourself in your garage w/o pulling the motor. did it in 14 hours or so chillin.
supermoose is offline   Reply With Quote
Old 02-04-2004, 10:54 AM   #9
C-daleRidr
Member#: 18074
2008 Speed3
It's an issue that's started to come up with the later model GM6 as well. The way I look at it, though, not all of these cars are blowing HG's, so go ahead. You're taking a chance with any used car you pick up.
And, just to clarify, stock motors blow HG's too. You're kidding yourself if you think you have to turbo it to see a blown HG.
C-daleRidr is offline   Reply With Quote
Old 02-04-2004, 11:28 AM   #10
jamesfacts
Member#: 51282
98 RS
Thanks for the advice. I haven't actually seen this car yet, or had it inspected, but right now I'm feeling that I'd really like to buy it. I'm not sure everything will be in order, but if it is, I think that my overpowering desire for a 2.5 will win out. Might not be the most logical plan, but then, that's not what buying a fun car's really about anyway....
James
Old 02-04-2004, 12:16 PM   #11
Those Meddling Kids
Member#: 4140
02 WRX
00 MR-S
Exactly. They all don't do it, there is no way to tell if yours will, so don't sweat it.
TMK
Old 02-04-2004, 06:28 PM   #12
ilmaestro
Member#: 16004
1998 2.5 RS - Blue
Dreaming of Boost
Like the other guys said. Don't worry about the headgasket too much, unless you plan to go turbo. Just make sure there is no evidence of current leakage around the heads, timing and valve cover areas. As mentioned above, you don't have to pull the engine to swap the head gaskets, it just takes a while.
jonathan
ilmaestro is offline   Reply With Quote
If you're not doing anything wrong, you don't have anything to worry about. Corn-Picker Political Playground 7 07-24-2008 12:08 AM
Rear ended in parking lot...anything to worry about? RallyLegacy Service & Maintenance 5 04-18-2008 08:27 AM
is this sound anything to worry about? Brian204 'Old School' Subaru Forum 5 06-10-2004 05:15 PM
Getting 91 MR2 - anything to worry about? WRXVII Off-Topic 16 10-05-2003 01:50 AM
Anything to worry about...? XROLLER Brakes, Steering & Suspension 4 05-15-2002 12:04 PM
