Welcome to the North American Subaru Impreza Owners Club Friday November 28, 2014
Old 02-04-2004, 05:38 PM   #1
Hawk296
Member#: 14555
1995 Impreza L
Baja
Default Location of VSS
Where is the Vehicle Speed Sensor located on my 95 Impreza L??
P.S. I have located a wiring diagram, and it says "Vehicle speed sensor 2" and looks like its in the guage cluster. Is this correct? ANd if so, is there another one?
thanks a lot.
Hawk296 is offline   Reply With Quote
Old 02-04-2004, 08:05 PM   #2
vile
Member#: 32371
'02 t-rex wagon
platinum
not familar w/ur make and model, but the vss is usually plugged into the tranny.
vile is offline   Reply With Quote
Old 02-04-2004, 09:05 PM   #3
Hawk296
Member#: 14555
1995 Impreza L
Baja
I just have a speedometer cable plugged into the transmission.
Old 02-04-2004, 09:29 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Your vehicle speed sensor is basically a small gear affair at the end of that cable.
Brian
Old 02-04-2004, 11:37 PM   #5
Hawk296
Member#: 14555
1995 Impreza L
Baja
Small gear affair at the guage end? Sorry for being dumb.
Old 02-04-2004, 11:57 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
most likely on the driverside rear of the trans, look for the speedo cable comming out of the firewall and follow it down to the side of the transmission, the sensor will be on the end of the cable.
Jay
Old 02-05-2004, 12:59 AM   #7
Hawk296
Member#: 14555
1995 Impreza L
Baja
this is a 5 speed manual trans. The speedo cable comes from inside, through the firewall and into teh passenger side of the trans. the cable plugs right into the hole in the trans and screws down locking it in place.
This means the cable plugs directly into the trans. I know where the cable on the transmission side goes, and there is nothing there unless its internal inside the trans.
Is the 95 and older different than the newer ones?
I am getting more and more confused, Any one have any pics?
Old 02-05-2004, 10:11 AM   #8
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Sorry . Tranny side .
Brian
Old 02-06-2004, 11:58 AM   #9
Hawk296
Member#: 14555
1995 Impreza L
Baja
Ok. The only thing I can think of that you guys are talking about is the newer vehicles with the electronic speed sensor either off the front differential or the left rear by the tailshaft.
As I have said I have a 95 L with a 5 speed manual. It has neither of these. The speedometer cable plugs into a hole on the front/center passenger side of the transmission. this cable mates up with a small shaft which connectos to a gear inside the transmission. that is all. On the speedometer end the cable comes up through the firewall and plugs directly into the back of the combination meter driving the speedo head.
Its a stadard speedometer, the cable turns a magnetic disc, and there is anotehr one that the needle is connected to. Immediatly next to this rotating magnetic disc is a small glass tube, looks to be a magnetic switch or or sensor of some kinda, it has two leads that connect to contacts on the combination meter, one looks liek a ground and one goes somewhere else. It looks like this is the sensor that the wiring diagram labels "Vehicle speed sensor 2"
On an old 95' impreza L, 1.8 liter 5mt AWD is there another speed sensor or is this the only one? the newer cars have have a sensor in the guage also but it reports to the custom CPU which drives the digital odo and trip meter. The dealer does not sell just this part or just a speedo, they sell a whole combination meter for $600.
I find it kinda hard to beleive this is THE speed sensor.
Does anyone have a wiring diagram or service manual for a 95 L?
This all started because my car started running like trash and threw a CEL which when i jumped the wires blinked 33 comparing to VSS. Im really frustrated. My car is really running bad and i need to fix it any new ideas? THanks guys for all the previous help too!
Old 02-06-2004, 03:21 PM   #10
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
Vehicle Speed Sensor #2 is located in the Speedo Head. The cable drives the Speedometer and the movement of the Speedometer drives a Reed Switch creating an On/Off signal to the ECM to indicate speed.
The M/T does not have a SS#1. It is called SS #2 only to keep continuity of terms with an A/T vehicle which has SS#1 located at the Tailhousing. On a A/T vehicle, there is a SS#1 and SS#2 regardless if it is FWD or AWD.
SubyTechMaster is offline   Reply With Quote
Old 02-06-2004, 05:56 PM   #11
Hawk296
Member#: 14555
1995 Impreza L
Baja
EXCELLENT! thank you very much!
Old 01-05-2008, 02:50 PM   #12
<<M>>
Member#: 123884
So to get to the speedo cable (the instrument cluster end) did you have to remove the cluster or just reach up from underneath the dash?
<<M>> is offline   Reply With Quote
Old 08-12-2008, 05:00 PM   #13
Hawk296
Member#: 14555
1995 Impreza L
Baja
Had to remove the cluster. Wow this is an old thread!
location of VSS wire twostep Car Audio, Video & Security 11 01-31-2008 07:44 PM
location of vss wire in 05 wrx theBrick714 Car Audio, Video & Security 3 09-29-2006 07:31 PM
Location of all of the cats? vsboxerboy Newbies & FAQs 6 02-21-2004 03:37 PM
Need Location of Tach Wire for WRX Autostart hman Car Audio, Video & Security 6 05-11-2001 10:35 AM
Location of Speed Sensor Wire tsdrally North West Impreza Club Forum -- NWIC 1 04-29-2001 11:46 PM
