Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 02-04-2004, 06:25 PM   #1
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
Default Picking up an EJ22T in a FEW DAYS. What EXTRA parts do I need from it?
I will be picking up an ej22t in a few days out of a wrecked '91 Legacy to be put into my '98 RS( i blew my engine )
What parts should I snag from the car to make everything complete?
I already have some parts from my wrx turbo kit on my 2.5(crossmember, upipe, turbo,downpipe, manifold, fuel pump)
I am getting the complete engine assymbly. Is there any pumps, lines or anything else I should snag when I am in there?
How do I make sure I have the complete wiring harness?
Also, do I need the ECU unit since I will be splicing the harness into my car?( I am assuming you just use my factory ecu with the legacy harness)
Thanks!
FatCatTurbo is offline   Reply With Quote
Old 02-05-2004, 09:04 PM   #2
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
Bump.
Old 02-06-2004, 07:55 PM   #3
sime
Member#: 45275
2007 wrx
98 2.5rs,89 & 95 240sx's
I woudl grab the oil pump since the turbo model oil pump should move more oil. Also I believe if you use the wrx crossmember you need to use the wrx swaybar also. No you need to use the ej22t ecu. what you splice is the the engine side harness into the cars harness then splice in the ecu plug into car's harness and plug in ej22t ecu. I would maybe grab the ej22t up-pipe since it has not cat and def the turbo too. My theory would be take as much as they will let you take as you can always sell it later.
sime is offline   Reply With Quote
Old 02-06-2004, 11:11 PM   #4
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
Good advice. Thank you.
Old 02-08-2004, 02:11 AM   #5
masiolli
Member#: 35840
1999 Blue RS-t
22t & Hydra
untill they want a core exchange for the turbo...
masiolli is offline   Reply With Quote
Old 02-10-2004, 02:28 PM   #6
serious
Member#: 22879
Just take the entire car minus any body parts/$hit you don't need. That way you know you have everything that you need and can take your time taking it apart instead of freezing in a junkyard. You can always sell bits and pieces to gain your money back and probably will come out ahead money wise if you do this.
Brent
serious is offline   Reply With Quote
Old 02-10-2004, 02:40 PM   #7
Puckaveli
Member#: 1518
00 2.5RS
To get the bulkhead harness complete your going to have to get the dash off and unplug everything under there and uplug it from everything in the engine bay and pull it into the car through the firewall.
Are you getting it from Fox?
I'll give you a call and give you the rest of the cabbage for those tires. I still might take those gauges if you still have them.
Puckaveli is offline   Reply With Quote
Old 02-10-2004, 04:01 PM   #8
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
Well, I had a deal lined up with a guy in PA but he won't return any emails now after I requested a phone number from him. I am calling everywhere now to locate an ej22t.
Gauges are gone(sowwy)
Good advice on the harness.
Old 02-10-2004, 05:05 PM   #9
Puckaveli
Member#: 1518
00 2.5RS
I would call Fox and see if they can locate one. They are getting a lot more Subaru's these days. Even the owner is driving a WRX he rebuilt from a couple wrecked ones.
foxautosalvage.com
Old 02-10-2004, 06:15 PM   #10
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
I did. The only thing he said he had was a 2.5L 6 Cylinder WRX engine.
I got off the phone after that.
Old 02-11-2004, 02:48 PM   #11
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
It may have been a 2.7 liter 6 cylinder
Old 02-11-2004, 02:52 PM   #12
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
In a WRX?
Old 02-11-2004, 03:10 PM   #13
ciper
Member#: 15543
90BJ Legacy LS ABS
No, he may have confused WRX with XT6.
Old 02-12-2004, 06:06 AM   #14
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
FatCat-
Wanna sell that blown 2.5? I think 98 is the best year for me. I'm looking to drop a 2.5 in my Brighton. Of course, I'm cheap. Thinking a blown 2.5 might be fun to do a few things to as well. How blown is it? Blown means lots of things.
Streetman is offline   Reply With Quote
Old 02-12-2004, 03:11 PM   #15
masiolli
Member#: 35840
1999 Blue RS-t
22t & Hydra
last i heard... there was a hole in the block... but i'll let fatcat answer...
Old 02-12-2004, 06:53 PM   #16
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
Here is a link to some pictures and what happened:
http://www.lersoc.com/viewtopic.php?t=1772&highlight=
You might be able to weld that peice on depending on how talented you are. I'm not really sure what caused it to blow. You are welcome to take it off my hands.
Old 02-13-2004, 12:25 AM   #17
Streetman
Member#: 8243
97 Brighton 2.5!
the REAL red
Uhhhh...that's blown. Don't expect me to show up anytime soon.
Old 02-13-2004, 01:15 AM   #18
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
Hey, you asked.
Doing an AT fluid swap in a few days...do i NEED to change the filter? kaisersouse Normally Aspirated Powertrain 8 08-30-2005 11:14 PM
having an alarm installed here in a few days, what to do first White 2.5rs Car Audio, Video & Security 4 10-17-2004 11:23 PM
Picked up an impreza. few questions for the gurus. lyrikz Impreza Forum 2 09-01-2004 08:06 PM
Picked up an EJ22t RallyColtTurbo Subaru Conversions 7 08-28-2004 07:51 PM
