Old 02-04-2004, 08:16 PM   #1
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Corolla GT-S Hachi Broku
Default Hardcore Bogg & Other Problems...
I've been talking to the guys in the NA forum, but I think this forum might get me the answers...
Anyways, heres the link (EJ22 Problem)
I've got a '99 OBS w/ 109,400miles and I'm throwing 2 CEL codes...
P0170 - Fuel Trim Malfunction (Bank 1)
P1325 - Knock Sensor Circuit Low Input
I've had people suggest bad MAF sensor, bad O2 sensor, old timing belts, and everything else, basically. I don't have the money to take the car in (fearing the dealer will find multiple things wrong) and don't really have money to fix the problem (I will have some soon)...
Thanks in advance for the help
-Ben
Soon2BturbodRS is offline   Reply With Quote
Old 02-04-2004, 08:32 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Your P0170 is at least 1/2 the cause of your bogging. From the code, it is likely your front air-fuel sensor, not the rear O2 sensor. Your car is having trouble deciding what the air/fuel mixture of your exhaust is, so the ECU is having trouble maintaining a good mixture. The knock sensor on your car is famous for going bad, and is the likely cause of the other 1/2 of your problems. Your knock sensor tells the ECU if it is hearing detonation; if it is, it will retard timing to keep the engine from destroying itself. The two malfunctioning together will make for a very unhappy motor .
Brian
Old 02-04-2004, 08:34 PM   #3
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Well........ Thank you. I knew I'd get help here.
THANK YOU
-Ben
Old 06-08-2005, 12:33 AM   #4
eastbaysubaru
Member#: 4110
04 FXT
I just got a P0170 in my wife's '00 RS. When you mention the front air/fuel sensor, are you referring to the front O2 sensor?
-Brian
eastbaysubaru is offline   Reply With Quote
Old 06-09-2005, 10:02 PM   #5
eastbaysubaru
Member#: 4110
04 FXT
Bump
-Brian
Old 06-13-2005, 06:41 PM   #6
eastbaysubaru
Member#: 4110
04 FXT
Well, that sucks. Guess it's time to take it in for service. So much for a quick answer
-Brian
Old 06-13-2005, 07:44 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....the p0170 code as described above, and the front o2 sensor go together...
Old 06-13-2005, 11:59 PM   #8
eastbaysubaru
Member#: 4110
04 FXT
Hmm...thanks. Is there any way to check the sensor to see if it's malfunctioning?
-Brian
Stock 06 WRX bogging & boost question hedwagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 06-16-2009 02:26 PM
Baja T hesitating & other problems ez bturbo Baja Forum 5 02-15-2006 06:16 PM
Problem w/ Kumho MX's out of round & other questions BIGSKYWRX Tire & Wheel 4 03-02-2005 08:33 PM
kartboy shifter & shift knob & other misc for sale SQC120 Private 'For Sale' Classifieds 17 02-24-2005 11:21 PM
How are 04 Tranny & clutches? & other questions PinnacleChronos Transmission (AT/MT) & Driveline 1 06-15-2004 07:22 AM
