Old 02-04-2004, 10:52 PM   #1
Brian Broz
Member#: 13783
2008 2.5i Slow
Default 10psi at 3500 sometimes at 4000? What the?
Hi,
Sorry I can't post any logs (no laptop) but I have tried 3 different stage 4 maps (i have an SR40)...
For example running the TXS Base Stage 4 FMIC map (Closed loop) some days I get 10-12psi at 4000rpms in 3rd, and other days I hit 15psi at 3800rpms...same map!
Soes anyone have any suggestions where to start...Ok I need a laptop, but what should I look for...I know the SR40 is a bit of a slow spooler, but I have boost gain set at 45 and am using the ABC. I have an MBC (not installed)...should I switch to open loop and try that for a while?
Just looking for suggestions, as I'm taking my car in for service...I suppose I'll ask them to check the MAF and 02 sensor. Maybe we should check for leaks or a loose EGT bung.
It just seems to be worse lately....hoping someone can help a noob fool (ya that's me).
Cheers,
Brian Broz
PS- I have bottomed out on a couple driveways/park lot exits at low speed. Could this be enogh to knock something out of whack on the exhaust?
Brian Broz is offline   Reply With Quote
Old 02-05-2004, 11:26 AM   #2
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
Slow spool could be related to what you have already mentioned but typically it's down to running too rich during spool up. What are your AFR reading at the lower rpms and at lower boost?
If you are dropping to 10:1 during spool up then your turbo is going to fill laggy
mick_the_ginge is offline   Reply With Quote
Old 02-05-2004, 05:16 PM   #3
02WRX_BLUE
Member#: 13704
2006 EVO MR
Apex Silver
Here's my suggestion without looking at your map or logs...
-- Borrow Lap top and start logging.....
-- Change you boost map to 500 upto 3000 RPM and see what happens......... Reduce the 500 gradually upto 4000 RPM and set fixed value (whatever number that will give you max boost of your goal) all the way to redline from 4250 to 7000........ ( I am hoping that you will write down the boost level and alter accordingly...)
-- Alter Fuel Map based on the logs (knock occurences) from UTEC.... ( I am assuming you would write down the boost level of every RPM up to the FULL Boost and compare that with VF30 or whatever TXS map is based on. Then, if your boost level is less, Reduce the fuel as long as you don't get any KNOCK : I am thinking this will lean a little and help you spooil a little better...)
-- Alter Timing if necessary..........
02WRX_BLUE is offline   Reply With Quote
Rattling Noise at 3500-4000 rpms' HELP MaxedOutRS2.5 Normally Aspirated Powertrain 7 10-29-2006 01:16 PM
knocking sounds at 3500 and 5500 rpms Dimnd8 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-04-2005 05:09 PM
Rev limits at 3500 rpms kickitjp Normally Aspirated Powertrain 4 12-20-2004 12:56 PM
rattle at 3500 rpm ScoobyTime Normally Aspirated Powertrain 10 08-18-2003 12:49 PM
No air comes out BOV at 3500, help wReXeRw Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-07-2002 02:43 AM
