Old 02-04-2004, 11:04 PM   #1
datwrx
Member#: 17821
2002 Subaru wrx
candy apple red
Default Need help with gauge readings
My egt gauge goes up and down. It's stays at 4 after I warm it up and then it goes up when I gas it. It's goes up to 7.
My oil pressure goes up when i gas it too. Are those gauges sappose to do that. What is a good reading from the egt and oil pressure gauge.
datwrx is offline   Reply With Quote
Old 02-05-2004, 12:45 PM   #2
datwrx
Member#: 17821
2002 Subaru wrx
candy apple red
The gauges are defi gauges. If that helps anything.
Old 02-05-2004, 12:52 PM   #3
awdman
Member#: 27962
2003 WRX Sedan
Blue, with more dings!
Default Yes.
You should be OK. Most people say their EGT temps are 800-900 degrees F. It sounds like you are speaking Celsius.
Oil pressure at startup is 100p.s.i Then after warmup at idle should be around 40p.s.i. On the road and warmed up, it should read 80-90 p.s.i.
The readings on both will climb as revs increase and decrease as revs fall. You will be producing more heat in the exhaust and more pressure from the oil pump.
Remember that the EGT may not change readings as quickly as oil pressure as you have to wait for it to heat and cool. Pressure will always change faster than temperature.
Also the quality of gauge can affect readings. Electrical vs. Mechanical and so on.
Just do a conversion on the temps from C to F and see what you got.Just remember you do not want to see the equivilent of 1600 degrees F. BAD things happen at tose temps!
awdman is offline   Reply With Quote
Old 02-05-2004, 01:24 PM   #4
datwrx
Member#: 17821
2002 Subaru wrx
candy apple red
The oil pressure is normally at 2.0 kp then it goes to 6.0 kp when I step the on the gas. It's looks like that should happen when you gas it. It's like when you gas it then the egt temp goes up. I just want to know if it was working correctly. I read something on the forum and it got me all confused.
Old 02-05-2004, 01:25 PM   #5
datwrx
Member#: 17821
2002 Subaru wrx
candy apple red
I wanted to know what is a bad reading. I mean like what is a bad egt temp or a bad oil pressure temp.
Old 02-05-2004, 04:22 PM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Your oil pressure readings should be ~100 PSI upon initial start-up (as awdman said). The pressure readings will eventually drop as the engine gets warm. What you will end up with is ~70-80 PSI @ cruising speeds (sometimes higher if your pushing it), & ~20-30 PSI @ idle. I would say anything below 20 PSI would be cause for concern (definitely anything lower than 15).
- Kean
Kean is offline   Reply With Quote
Old 02-05-2004, 08:26 PM   #7
datwrx
Member#: 17821
2002 Subaru wrx
candy apple red
Mine reads in 2.0 kpa. What is that. Trying to covert it to psi. Then it raises to 6.0 kpa when I step on the gas. Don't know much about gauges. Just trying to make sure my gauges are good or not. Unless I did something wrong.
Old 02-05-2004, 08:28 PM   #8
datwrx
Member#: 17821
2002 Subaru wrx
candy apple red
My egt temp is in celsius. It idles at 4 and it get to 7 or 8 when I gas it. Awdman did say atleast that sounds correct.
Old 02-05-2004, 09:17 PM   #9
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Everything you have seen to this point is normal. You can start to worry if your EGT readings go above 800 C for prolonged periods. This isn't terribly likely unless you have a manual boost controller and get a lot of part throttle full boost (which raises EGTs) or you're using engine management and have a poor tune.
Joel
Zola is offline   Reply With Quote
Old 02-05-2004, 09:24 PM   #10
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Your answers can be found here!
TADA!
Just go to the temperature section and convert between C->F and the pressure section and convert between Kilopascals -> psf and you'll get your answers.
As for whether you're in your nominal range or not, search, it's what the buttons are for.
AJ
PS: This'll work for your boost gauge as well
AJ711 is offline   Reply With Quote
Old 02-05-2004, 09:27 PM   #11
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Also, look closely at the face of your gauge. In all likelihood, your pressure measurements are x100 kPa.
2.0 kPa is only about 0.3 psi, whereas 200 kPa is 29 psi.
Old 02-05-2004, 09:33 PM   #12
datwrx
Member#: 17821
2002 Subaru wrx
candy apple red
Ya it is kpa x100. I have done some searching and most of it doesn't have answers I'm looking for. Must be searching wrong or something. Thanks for all the help. Sounds like the gauge is correct then.
Old 02-05-2004, 10:27 PM   #13
Kean
Member#: 25187
'08 Foz Prem TGM
Here's a nifty conversion tool you can download (only 152k). It's will convert just about any measurement: http://www.joshmadison.com/software/convert/dl.asp
- Kean
Old 02-06-2004, 01:45 AM   #14
datwrx
Member#: 17821
2002 Subaru wrx
candy apple red
Thanks alot guys. You guys been alot of help.
Old 02-19-2004, 06:07 AM   #15
zeki
Member#: 39631
04 impreza wrx
blue
can the egt gauge tell if the car is lean or rich? i think i read somewhere that if it is high temp then it is lean?
zeki is offline   Reply With Quote
Old 02-19-2004, 01:17 PM   #16
awdman
Member#: 27962
2003 WRX Sedan
Default Yep.
Most people here associate high EGTs with a lean condition. The fuel gets cut back and up the temps go.
Rich conditions not so much...So watch your gauges!
need help with gauges edel33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-18-2005 11:18 PM
Need help with gauges Pimp'n 2.5L Interior & Exterior Modification 11 05-21-2004 03:18 PM
need help with gauges wond3rxB0y Electrical & Lighting 8 02-07-2004 04:11 PM
need help with gauge digitalmethods Electrical & Lighting 1 01-25-2004 08:33 PM
Anybody need help with gauge install Speedwagon Mid Atlantic Impreza Club -- MAIC 3 11-17-2003 07:44 AM
