Old 02-05-2004, 12:15 AM   #1
ReX_N
Member#: 22917
2002 Boro WRX (RIP)
aspen white
Default Confused on UTEC tuning
Ok im pretty much confused w/ how to tune the UTEC, i understand the concept of increasing fueling and/or retarding timing to prevent knock. But what my problem is, how do i do that for the UTEC, especially to fix the shift knock problem. See what my concern is, is that some people have negative values in their maps for portions of their fueling and/ or timing, as well as boost values of 300 - 425, in mine the Stg2(octane challenged map) my boost values are nowhere near that.
My current setup is Gruppe-S uppipe, HKS Downpipe, and Tanabe Catless Exhaust. So im fully catless
*Any help would be greatly appreciated
This is my current map:
[START][MAPGROUP1][MAPGROUP]
Map Name:-[STG2 NEW]
Map Comments:-[16.5 psi peak]
Fuel Map
[0] [0] [0] [0] [0] [0] [0] [0] [0] [0] [0]
[0] [0.5] [0.5] [0.5] [0.5] [0.5] [0.7] [0.8] [0.9] [1] [1]
[0] [1.5] [1.5] [1.5] [1.5] [1.5] [1.7] [1.8] [1.9] [2] [2]
[0] [0.5] [0.5] [0.5] [0.5] [1.1] [1.1] [1.1] [1.1] [1.2] [1.3]
[0] [0.2] [0.2] [0.2] [0.2] [0.2] [0.2] [0.3] [0.4] [0.5] [0.6]
[0] [0.3] [0.3] [0.3] [0.3] [0.3] [0.3] [0.4] [0.5] [0.6] [0.7]
[0.5] [0.5] [0.5] [0.5] [0.5] [0.5] [0.5] [0.6] [0.6] [0.7] [0.8]
[0.8] [0.8] [0.8] [0.8] [0.8] [0.8] [0.8] [0.9] [0.9] [0.9] [0.9]
[0.7] [0.7] [0.7] [0.7] [0.7] [0.7] [0.7] [0.8] [0.9] [1] [1.1]
[0.8] [0.8] [0.8] [0.8] [0.8] [0.8] [0.8] [0.9] [1] [1.1] [1.2]
Timing Map
[-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100] [-100]
[-100] [35] [35] [35] [35] [35] [35] [35] [35] [35] [35]
[-100] [30] [30] [30] [30] [30] [30] [30] [30] [30] [30]
[-100] [27] [27] [27] [27] [27] [27] [27] [27] [27] [27]
[-100] [25] [25] [25] [25] [25] [25] [25] [25] [25] [25]
[-100] [20] [20] [20] [20] [20] [20] [20] [20] [20] [20]
[-100] [20] [17] [17] [17] [16] [16] [15] [14] [14] [14]
[-100] [18] [17] [17] [17] [16] [16] [15] [14] [14] [14]
[-100] [20] [19] [19] [19] [18] [18] [17] [16] [16] [16]
[-100] [21] [20] [20] [20] [19] [17] [17] [17] [17] [17]
[-100] [21] [21] [21] [21] [20] [17] [17] [17] [17] [17]
[-100] [22] [22] [22] [22] [21] [19] [19] [19] [19] [19]
[-100] [23] [23] [23] [23] [22] [22] [22] [21] [20] [20]
[-100] [23] [23] [23] [23] [22] [22] [22] [21] [21] [21]
[-100] [25] [25] [24] [24] [23] [23] [23] [22] [22] [22]
[-100] [25] [25] [24] [24] [23] [23] [23] [23] [22] [22]
Boost Map
[0] [0] [0] [0] [0] [0] [0] [95] [95] [105] [105]
[0] [0] [0] [0] [0] [0] [0] [92] [92] [102] [102]
[0] [0] [0] [0] [0] [0] [0] [88] [88] [98] [98]
[0] [0] [0] [0] [0] [0] [0] [80] [80] [90] [90]
[0] [0] [0] [0] [0] [0] [0] [75] [75] [85] [85]
[0] [0] [0] [0] [0] [0] [0] [75] [75] [85] [86]
[0] [0] [0] [0] [0] [0] [0] [80] [80] [90] [91]
[0] [0] [0] [0] [0] [0] [0] [11] [11] [11] [11]
[END][MAPGROUP][0DED8][EOF]
ReX_N is offline   Reply With Quote
Old 02-05-2004, 12:16 AM   #2
ReX_N
Member#: 22917
2002 Boro WRX (RIP)
aspen white
Here is a map that i am comparing mine too:
And this is a map found on here, Stg2wintr(93oct):
Map Name:-[Stage 2 93 Octane]
Map Comments:-[Winter Map]
Fuel Map
[0] [-0.4] [-0.4] [-0.4] [-0.1] [0] [0.2] [0.3] [0.4] [0.5] [0.6]
[0] [-0.3] [-0.3] [-0.3] [0] [0.3] [0.5] [0.6] [0.7] [0.8] [0.9]
[0] [-0.3] [-0.3] [-0.3] [-0.1] [0.2] [0.4] [0.5] [0.6] [0.7] [0.8]
[0] [0.1] [0.1] [0.1] [0.2] [0.2] [0.4] [0.5] [0.6] [0.7] [0.8]
[0] [0.2] [0.2] [0.2] [0.2] [0.2] [0.4] [0.5] [0.6] [0.7] [0.8]
[0] [0.4] [0.4] [0.8] [1] [1.1] [1.2] [1.3] [1.4] [1.5] [1.6]
[0] [0.8] [0.8] [1.8] [1.8] [1.8] [1.8] [1.8] [1.8] [1.8] [1.8]
[0] [0.8] [0.8] [1.8] [1.8] [1.8] [2] [2] [2.1] [2.1] [1.9]
[0] [0.8] [0.8] [1.8] [1.8] [1.8] [2] [2] [2] [2] [1.8]
[0] [0.8] [0.8] [1.8] [1.8] [1.8] [2.1] [2.1] [2.1] [2.1] [1.9]
[0] [0.8] [0.8] [0.8] [0.8] [0.9] [0.9] [0.9] [0.9] [0.9] [0.8]
[0] [0.8] [0.8] [0.8] [0.8] [0.6] [0.5] [0.5] [0.5] [0.5] [0.8]
[0] [0.8] [0.8] [0.8] [0.8] [0.4] [0.2] [0.2] [0.2] [0.2] [0.8]
[0] [0.6] [0.6] [0.5] [0.5] [0.3] [0.2] [0] [0] [0] [0.4]
[0.7] [0.7] [0.7] [0.6] [0.6] [0.5] [0.4] [0.1] [0.1] [0.1] [0.4]
[0.7] [0.9] [0.9] [0.8] [0.8] [0.6] [0.6] [0.2] [0.2] [0.2] [0.5]
[0.7] [0.9] [0.9] [0.8] [0.9] [0.7] [0.7] [0.2] [0.2] [0.2] [0.5]
[0.7] [0.9] [0.9] [0.8] [0.8] [0.6] [0.6] [0.2] [0.2] [0.2] [0.4]
[0.7] [0.9] [0.9] [0.7] [0.7] [0.5] [0.5] [0.1] [0.1] [0.1] [0.3]
[0] [0.3] [0.3] [0.3] [0.3] [0.3] [0.3] [0.3] [0.3] [0.3] [0.3]
Timing Map
[-100] [35] [35] [35] [35] [35] [35] [35] [35] [35] [34]
[-100] [30] [30] [30] [30] [30] [30] [30] [30] [30] [29]
[-100] [28] [28] [28] [28] [28] [28] [28] [28] [28] [27]
[-100] [25] [25] [25] [25] [25] [25] [25] [25] [25] [24]
[-100] [23] [23] [23] [23] [23] [23] [23] [23] [23] [22]
[-100] [18] [18] [18] [18] [18] [18] [18] [18] [18] [17]
[-100] [16] [16] [16] [16] [16] [16] [16] [16] [16] [15]
[-100] [18] [18] [18] [18] [18] [18] [18] [18] [17] [16]
[-100] [19] [19] [19] [19] [19] [19] [19] [19] [18] [17]
[-100] [20] [20] [20] [20] [20] [20] [20] [20] [19] [18]
[-100] [21] [21] [21] [21] [21] [21] [21] [21] [20] [19]
[-100] [22] [22] [22] [22] [22] [22] [22] [22] [22] [21]
Boost Map
[0] [0] [0] [0] [0] [0] [0] [425] [425] [425] [425]
[0] [0] [0] [0] [0] [0] [0] [360] [360] [360] [360]
[0] [0] [0] [0] [0] [0] [0] [340] [340] [340] [340]
[0] [0] [0] [0] [0] [0] [0] [320] [320] [320] [320]
[0] [0] [0] [0] [0] [0] [0] [300] [300] [300] [300]
[END][MAPGROUP][0F6AF][EOF]
Old 02-05-2004, 12:26 AM   #3
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Run, don't walk, run to your computer. Download the UTEC manual. Read it. Then read it again. It will explain such things as open and closed loop boost control (the difference you noticed between the two boost maps). Maps you see with negative fuel values are almost certainly intended for cars with larger-than-stock injectors.
Another good read is mick_the_ginge's UTEC Tuning Guide, which you can download from http://www.wrxhackers.com
Don't fiddle with the UTEC until you've read those and start to understand them.
Joel
Zola is offline   Reply With Quote
Old 02-05-2004, 05:02 PM   #4
02WRX_BLUE
Member#: 13704
2006 EVO MR
Apex Silver
Rex_N: Since you said you know the concept, I am going to be brief.. If you are getting the knock between the shift, write down the BOOST level right after where you saw knock, RPM, & number of counts.
First try to add a little more fuel into +- 250 RPM range. If adding a little more fuel did not cure it, drop a timing...
FYI - You will notice that the boost level will vary based on how you shift.. In my case, I had a minor knock if I am heavy on the gas and slow on the clutch... Too much boost initially, Fuel simply was not there enough...
Also, use [100] Map zone as your defense again DET. Use this column for boost level that are beyond your goal.. Add considerably more fuel and less aggressive timing in case it does happen (Over boosting)...
I hope this helps........
02WRX_BLUE is offline   Reply With Quote
Old 02-05-2004, 05:47 PM   #5
ReX_N
Member#: 22917
2002 Boro WRX (RIP)
aspen white
Thanks guys for the help, im straight on everything now.
Advance Utec user Help with Timing. Knocks! Confused on Fuel/Timing Knock. bluesube2000 Engine Management & Tuning 8 11-21-2005 02:08 AM
Killer Deal on UTEC+Tuning bluestone Mid Atlantic Impreza Club -- MAIC 8 08-18-2005 01:59 PM
so wait, passing out on the toilet is on topic, but LOCAL (drunk) utec tuning isnt?? Davenow Off-Topic 2 01-14-2005 10:42 PM
confused over utec tuning accessories dashiet Engine Management & Tuning 3 08-27-2004 04:16 PM
Any updates on UTEC tuning locally? Brian Broz Vancouver Impreza Club Forum -- VIC 9 05-18-2004 02:10 PM
