Old 02-05-2004, 01:03 AM   #1
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Default HIR bulbs
Just got this from Daniel today:
Quoted w/ permission:
Begin Quote:
Howdy, Peat, Daniel Stern here (note new address)
Hey, I thought I'd let you know the HIR1 bulbs are finally here.
These are the high-zoot replacements for 9005 high beam. Used as OE in Dodge Viper high beams.
The new bulbs are not some tinted or overwattage version of 9005 and 9006, but rather employ a relatively new technology called HIR, Halogen Infrared. The mechanical dimensions of the bulb are all virtually identical to the 9005 and 9006 bulbs, but the bulb glass is spherical instead of tubular, with the sphere centered around the filament. There is a "Durable IR Reflective" coating on the spherical glass. Infrared = heat, so the coating causes heat to be reflected back to the filament at the center of the sphere. This causes the filament to become much hotter (producing more light) than it can by passing electricity through it, *without* the shorter life or greater heat production that comes with overwattage bulbs (to say nothing of overwattage bulbs' incompatibility with stock wiring.)
Here's the comparison:
Low beam stock: 9006, 12.8V, 55W, 1000 lumens
Low beam new: HIR2, 12.8V, 55W, 1875 lumens
High beam stock: 9005, 12.8V, 65W, 1700 lumens
High beam new: HIR1, 12.8V, 65W, 2530 lumens
So you're looking at nearly 88 percent more light from the low beams and a grand total of 137% more light (49% of which from the high beam units, 88% of which from the low beams, which remain on with the high beams) on high beam. The beam pattern will not change, but there will be considerably more light within the beam pattern.
These bulbs are spendy - $39/ea - but their cost is worth
considering in context: Any number of companies will charge you more than this for a tarted-up 9005 or 9006 with blue colored glass (PIAA comes to mind) that doesn't produce more light and has a very short lifespan.
DS
End quote
I'm going to try a pair of the high beams in our Outback an see what happens. I'll report back. Please keep in mind, these are street legal bulbs but only in headlights originally designed for them, Stern will probably ask you what you're putting them in when you request these bulbs and might not sell them to you if you answer with a vehicle they don't originally fit,so tell him you have a Dodge Viper.
Peaty is offline   Reply With Quote
Old 02-05-2004, 01:07 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Where can I get them?
Old 02-05-2004, 01:16 AM   #3
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
I think at this time only 9005 and 9006 can be had. Daniel Stern has them here:
http://www.danielsternlighting.com/home.html
Old 02-05-2004, 01:19 AM   #4
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Old 02-05-2004, 01:24 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
Thanks, Peaty
Old 02-05-2004, 12:25 PM   #6
ursine
Member#: 51771
2000 Impreza GC6 SRP
1980 G2 Celica Rally Taxi
Do these produce a regular white light or are they cool blue or HID or does nobody know?
-Branden
ursine is offline   Reply With Quote
Old 12-03-2004, 02:45 AM   #7
ImPrEzZzZZA
Member#: 8252
Platinum Silver Metallic
hmm.. too bad they dont make them for 9007
ImPrEzZzZZA is offline   Reply With Quote
Old 12-03-2004, 03:14 AM   #8
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
I wonder if you can mod either of these to fit either an H1 or H7 bulb?
Rapid_Roo is offline   Reply With Quote
Old 12-03-2004, 07:13 AM   #9
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
-Branden
White not blue, blue is a bad colour as it's the major componant in glare and it will bounce back at you in the fog. It also is very annoying to oncoming drivers.
I have some info here:
http://www.scoobymods.com/forums/showthread.php?t=3122
Old 12-03-2004, 07:16 AM   #10
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
No they are very different bases.
Old 12-03-2004, 11:12 AM   #11
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
that's what I thought. thanks.
Old 12-03-2004, 09:05 PM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
Any new ones for me, Peaty????
Old 12-03-2004, 09:30 PM   #13
brunetmj
Member#: 8023
2004 2.5 RS
I have used them for three months now and they are excellent. They require a bit of a fit adjustment. The plastic round base of the bulb is a tad thicker than the stock base. I ended up removing the three small screws that holds the plastic retaining ring on the light housing. Then I inserted the bulbs, placed the retaining ring back on and screwed it back on.
I am not entirley sure if their specifiactions holds up to their reality. I found them to be only minimally better than the stock high beams on the STI.
But you can judge them for yourself. They were well worth it for me since I have the RS with no HID's.
brunetmj is offline   Reply With Quote
Old 12-03-2004, 09:50 PM   #14
engineerx
Member#: 42614
0405 WRX STi/S2000
AspenWhite/Silverstone
So,
For my '04 STi I would order the 9011 HIR1 for the High beams, correct?
Great mod for better visibility on those pesky dark evenings!!!
Oh yeah - Peaty, let me thank you for all your guides on Scoobymods!
The STi is my 1st Subaru - I has a Dodge Durango and a '86 Toyota 4x4 truck before I got the STi
Your guides have made owning my Subaru much more enjoyable!
engineerx is offline   Reply With Quote
HIR bulbs dont fit 2008?!? hybrid gti 2 Electrical & Lighting 3 04-15-2008 08:59 PM
OEM Front skid plate, rear diffuser kit, fender liners, and HIR Bulbs powerlabs Exterior/Styling 11 10-10-2007 09:10 AM
Who in DFW using HIR bulbs? salaki Texas Impreza Club Forum -- TXIC 0 12-15-2004 12:25 PM
Which HIR bulbs dudical26 Electrical & Lighting 3 10-11-2004 11:31 PM
If you own a 04+ you really need to try the 9011 HIR bulbs BIGSKYWRX Interior & Exterior Modification 11 10-11-2004 09:21 AM
