Old 02-05-2004, 02:55 AM   #1
Hopper
Member#: 50829
Default EJ22 intake manifold work on a EJ25
Will a EJ22 intake manifold work on a EJ25 motor? Or will it work on a EJ20 motor?
Hopper is offline   Reply With Quote
Old 02-08-2004, 01:12 AM   #2
masiolli
Member#: 35840
1999 Blue RS-t
22t & Hydra
should...
masiolli is offline   Reply With Quote
Old 02-08-2004, 01:54 PM   #3
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
why...
RS_to_WRX_swap is offline   Reply With Quote
Old 02-08-2004, 11:00 PM   #4
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
which EJ22? It depends on year. The older phase I EJ22 manifolds, like on the EJ22T's will not line up with the bolt pattern.
Give more detail, like specific year of EJ22 and year of EJ25 (DOHC and SOHC) are different. What are you really trying to do?
Old 02-09-2004, 01:16 AM   #5
Hopper
Member#: 50829
It might be a 95 EJ22. I have a EJ25 DOHC with no intake. I also have a WRX EJ20 with no intake. I thought this intake might work, have not seen it.
Thanks
Old 02-10-2004, 12:44 AM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
Unless the EJ20 heads are pre-'96, you are SOL on that EJ22 manifold for either one. Hit the private sale classifieds. There have been a few manifolds floating around recently. I may also have one soon, but it is still a few weeks off. Drop me a line if you are still shopping at month's end...
EJ22 Intake Manifold gryphon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-17-2015 06:20 PM
ej22 intake manifold, tb, coil mr. m Private 'For Sale' Classifieds 7 07-01-2004 08:40 AM
EJ25 Intake Manifold fit on EJ20? FatCatTurbo Subaru Conversions 6 01-24-2004 08:29 AM
EJ22T vs EJ22 intake manifold ChicksDigWagons Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-09-2002 06:50 AM
Will the WRX intake manifold fit on the ej25 heads? Impreza Rider Normally Aspirated with bolt-on Forced Induction Powertrain 25 01-20-2002 12:33 AM
