Old 02-05-2004, 10:39 AM   #1
Womble407
Member#: 51734
02 WRX Sedan
Default HKS SS BOV adjustment ?
I just installed my HKS SS BOV on my 02 WRX. Other relevant mods include TurboXS FMI, VF30 and I'm running between 14 and 18 lbs of boost. (all necessary fuel and intake mods also)
Concern is that the BOV sounds and feels like it is not releasing pressure consistantly. Instead of one solid rush of air upon release or partial release of throttle - the BOV "stutters." (i.e. instead of one shush it is multiple shushes). When just pulling back on the throttle and this happens you can actually feel the surges in the engine/boost. This happens at anything less than full boost with a quick release of throttle.
I don't think this is normal so is it a simple BOV adjustment? If so is the valve too tight or too loose? Or is there a chance I am loosing pressure somewhere else?
Sorry if this is a basic question - I'm just learning as I go.
Thanks
Womble407 is offline   Reply With Quote
Old 02-05-2004, 01:03 PM   #2
Kitt
Member#: 24621
2006 Legacy GT
2015 WRX STi
Is your HKS bov brand new? If so can you please tell me how many threads are exposed on the adjustment screw, I'm curious to see if my bov is set near the HKS setting. If you loosen the adjust screw all the way, then turn it in again you will notice it will start to touch the spring inside. I have mine set to 1/2 a turn in from the flush setting and no problems.
Kitt is offline   Reply With Quote
Old 02-05-2004, 10:56 PM   #3
Womble407
Member#: 51734
02 WRX Sedan
Kitt - I'll take a look and let you know. W
Old 02-06-2004, 04:59 PM   #4
Kitt
Member#: 24621
2006 Legacy GT
2015 WRX STi
Thanks Womble, Did you try to make any adjustments?
Old 02-11-2004, 01:57 PM   #5
Womble407
Member#: 51734
02 WRX Sedan
Default Answers
Kitt - The HKS SS BOV tuned from the mfg. has three threads showing when looking down on the side with the HKS logo.
There is a raised line where the threading starts, then two obvious threads and the third thread is just beyond (1 mm) the outside edge of the lock nut - almost even with it. Hope that helps.
To answer my own question - I called HKS tech support and they are great. The sound of the SS BOV is different than other, non-SS BOVs. There is the primary valve (high pitched) and secondary valve (low pitched) that you can hear. With anything less than full boost and release of throttle the SS BOV secondary valve "chatters" to release spurts of pressure, instead of total release, to retained as much pressure as possible during the gear change.
WTT - Blitz bov for a HKS ss bov spankmeplz700 Private 'Wanted' Classifieds 0 05-18-2004 01:44 PM
Brand new HKS Purple Insert for HKS SS BOV Diversion Private 'For Sale' Classifieds 13 01-20-2004 03:06 AM
HKS SS BOV and TXS V1 vs. SS BOV and Stock IC JayGold Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-11-2003 05:52 PM
HKS SS BOV or Racing BOV? MiXer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-01-2002 09:29 PM
hks ss bov vs blitz ss bov grandmasterchan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-12-2001 09:42 AM
