Old 02-05-2004, 01:12 PM   #1
THE ONE
Member#: 43918
2002 Scooby Wagon
Default UTEC Question
I have read the stickies and not seen the answer I need. I have a 2003 WRX and I need a UTEC. I have found a couple, but they are from a 2002 WRX. Will it still work fine on my 2003 WRX? I know one of them is a ver. 3 from a 2002 WRX. Please help, I need to buy one to run my car safely!
THE ONE is offline   Reply With Quote
Old 02-05-2004, 03:54 PM   #2
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
UTECs are backwards compatible, not forwards compatible. Therefore, a UTEC meant for a MY02 car will only work on a MY02 (actually, I think with some wiring modifications it can be made to work on a MY03, not for sure). A UTEC for a MY03 will work on either a MY03 or a MY02.
Call up TXS, I'm sure they will be happy to tell you which revision you need. Contact info is at http://www.turboxs.com
Joel
Zola is offline   Reply With Quote
Old 02-05-2004, 04:08 PM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
"Zola Rex" is correct..... You will get a fuel sensor code if you run a 2002 UTEC in a 2003 WRX. (That's what I run) You can get around this with a simple wire mod.
Next time I pull the carpet up I will look at the wiring for you. It's just two wires if I remember correctly. I won't be able to get around to this for a while.
You can run the car with this code.
Have a look on wrxhackers as their was a thread a long time ago on the same subject.
mick_the_ginge is offline   Reply With Quote
Old 02-06-2004, 12:43 AM   #4
THE ONE
Member#: 43918
2002 Scooby Wagon
Okay, as long as it does not affect it in a bad way I'll just get the next one I can. Thanks.
Old 09-04-2004, 03:40 PM   #5
WrXaWd
Member#: 53627
2009 WRX
BLING BLING
so if i have a 03 WRX and put a 02 ECU in it, along with the UTEC for a 02 would that work fine better. Will the 02 ECU in a 03 mess up the car at all??????
WrXaWd is offline   Reply With Quote
utec question changing to MBC from utec boost trbowrx Engine Management & Tuning 8 06-28-2005 07:15 AM
snowboard question and UTEC question i_heart_boost Newbies & FAQs 6 12-11-2002 12:30 PM
Another UTEC question DiMensionX Engine Management & Tuning 26 10-01-2002 03:03 AM
Utec Question? GT2WRX Engine Management & Tuning 7 09-07-2002 03:30 PM
Very specific UTEC questions for users/experts. davidm_sh Engine Management & Tuning 22 09-02-2002 11:27 AM
