Old 02-05-2004, 06:26 PM   #1
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Question EDM heavy duty wiring harness problem
I just assembled a heavy duty wiring harness using (3) 40amp dual-87 relays, a couple 9005 connectors, and then the H1s for the lowbeams.
The problem I'm having is after i've turned on the headlights, and then try to turn them OFF or turn off the car, the hi-beams just come on.
This is the wiring diagram I used:
What is my problem?
nhluhr is offline   Reply With Quote
Old 02-05-2004, 06:49 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
Dejavu
i say ditch the three realy system, as its not realy needed. just do a normal 2 realy system. one realy for the high beams, and one for the lowbeams. more then enough relay for the power being used.
Shane
PARANOID56 is online now   Reply With Quote
Old 02-05-2004, 06:54 PM   #3
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Originally posted by PARANOID56
Dejavu
Shane
how does that work? could you maybe sketch a diagram?
Old 02-05-2004, 07:00 PM   #4
PARANOID56
Member#: 22035
2003 Brocoma DCab
something like this
Old 02-05-2004, 07:08 PM   #5
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
but i thought the impreza had switched grounds instead of switched + so that diagram won't quite work
I know daniel stern's site mentions the switched ground approach, but it doesn't really give much detail on it...
Old 02-05-2004, 08:10 PM   #6
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
so does this look correct then?
I'll go ahead and make this right now if it's right....
Old 02-05-2004, 08:26 PM   #7
PARANOID56
Member#: 22035
2003 Brocoma DCab
well, i have a better pic, but my server is down, can you host a pic for me?
Shane
Old 02-05-2004, 09:07 PM   #8
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Hmmm...and I was just at Radio Shack tonight shopping for parts for a relay setup. I was also going to do the three relay setup because I wanted to retain proper functionality--working flash-to-pass and lows turn off when highs come on.
Joel
Zola is offline   Reply With Quote
Old 02-05-2004, 09:51 PM   #9
PARANOID56
Member#: 22035
2003 Brocoma DCab
on my system, i can still do all that, i just converted it to a normal dual relay system.
SHane
Old 02-05-2004, 10:03 PM   #10
PARANOID56
Member#: 22035
2003 Brocoma DCab
here you go,
Old 02-05-2004, 10:20 PM   #11
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
so that works? Only using one of the 9007 connectors like that? is that how you've done it?
I'd really prefer to use only one connector, because my driver-side connector is melted on the edge from a long time ago when I was a dumbass and I put in some of those gay blue bulbs... basically, it makes a very intermittent connection...
I've rebuilt the harness now but i would just need to splice in one more wire in to have it like yours - i actually haven't wired in the driver side connector, yet...
Old 02-05-2004, 10:57 PM   #12
PARANOID56
Member#: 22035
2003 Brocoma DCab
this is how i have mine set up, and it works great, i have over a volt increas at the headlights now. you only need to use one conector, since they are both doing the dame thing.
Shane
Old 02-05-2004, 11:52 PM   #13
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
ok thanks a lot for the help!!
and also thanks a lot to Daniel Stern with whom i've exchanged several emails tonight!
Old 02-06-2004, 12:11 AM   #14
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Would you mind sharing the reasons why the three relay setup doesn't work (if known)? Was your HID kit the issue? Mine are and will remain halogen, so would the three relay setup work? As I understand it, the only difference between the method in your original post and what Shane posted is the fact that the two relay setup gives constant power to the headlights. I assume the safety concern is pretty minor.
If two relay constant power is not a big issue and the three relay doesn't work, then I guess I know what I'll be doing.
Joel
Old 02-06-2004, 12:35 AM   #15
PARANOID56
Member#: 22035
2003 Brocoma DCab
well the way i set it up, is like most american cars OEM head light set up. of corse they dont use the realys that close to the headlights. I have run this set up in my truck for over 5 years, and in my scooby for a year. its safe
Shane
Old 02-06-2004, 01:07 AM   #16
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Joel
I am 100% positive that the HID kit wasn't the problem because I put the stock H1 bulbs in place to test it out... still the same problem...
Anyway, avatarr and I did some discussion on it and we think maybe the polarity of the 86/85 coil circuit may have something to do with it. could be the current was flowing the wrong way through the relay coil thus triggering the 30-87 circuit at odd times. no idea, really.
Old 02-06-2004, 07:29 AM   #17
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Relay coils are not polarized. Some relays do have internal diodes across the coil to prevent voltage spikes when the coil is energized/de-energized, but the automotive relays generally don't have them. If there was a diode and you connected the voltage the wrong way you'd know it- the relay wouldn't work and it would appear shorted.
Have you pulled the main DRL module?
Old 02-06-2004, 07:54 AM   #18
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
yeah the main DRL module under the dash AND the fat resistor pack under the hood are both non-existant in my car.
I re-wired the harness in the fashion that PARANOID56 posted above, as per recommendation from Daniel Stern and it works flawlessly.
So this is the simplest, most surefire way to wire up an H/D harness:
Old 02-06-2004, 08:48 AM   #19
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
So what you did with that circuit is to flip the headlights from a switched ground system to switched power, using the switched grounds for relay control. The first circuit, while unnecessarily complicated with the three relays, should have worked, but there was probably voltage backfeeding from other components in the headlight wiring that aren't accounted for in the diagram (i.e. the fog light system). Have you done the fog light mod or is that wiring stock?
Old 02-09-2004, 02:32 PM   #20
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Yes i have done the "foglight mod" if you mean re-wiring them so they can be on anytime.... but then i changed that later so that the fog switch controls the driving lamps and they only come on with the highbeams... so... there's some weirdness external to that circuit, apparently.
Old 02-09-2004, 02:39 PM   #21
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
one more question - if I want to have my lowbeams always on, even with hibeams, will this diode crossover thing work?
Old 02-09-2004, 03:05 PM   #22
avatarr
Member#: 14010
'04 APS-ified STi
TopSpeed Tuned - Black
yes, that should work. make sure, however, that the diode is rated for the calculated current.
-Jason
avatarr is offline   Reply With Quote
Old 05-14-2004, 05:22 AM   #23
Genner
Member#: 18372
what that diagram with the diode,
I have the edm sti's is it safe to run both left and right headlights with low beams and high beam on at the same time from one single headlight harness?
Will that draw too much current from just one harness?
Genner is offline   Reply With Quote
FS SoCal: Subydude EDM/JDM Headlight Wiring Harness Lazyxturb0 Exterior/Styling 25 04-20-2007 11:13 PM
Subydude EDM/JDM Headlight Wiring Harness *NEW* Lazyxturb0 SCIC Private Classifieds 23 04-20-2007 11:12 PM
WTB: stock driver-side bugeye headlight; EDM STi projector wiring harness Butt Dyno Private 'Wanted' Classifieds 3 03-23-2005 01:07 PM
What do you think of this heavy duty headlight harness? garface Interior & Exterior Modification 0 10-14-2001 03:27 PM
Rex wiring harness problems! ObiWanJak Car Audio, Video & Security 3 10-09-2001 08:12 AM
