Old 02-05-2004, 07:54 PM   #1
mcu81
Member#: 5796
2013 BRZ & 2004
WRX
Default Voltage troubles............
Ok so for some time now i have been having voltage troubles........it got to the point where even while driving and in gear, the car would only make about 11.5 volts, then eventually the battery died.
so i replaced it w/a optima red...........went great for about 2 months, now i got the problem again, when i first put the optima in, crusing was about 13.6 volts and idle about 12.0 but now just driving i was making 11.5 volts, so i turned off the heat, and the voltage went up to about 12.5 but in about 2 min settled back to 11.5, so i turn off the lights, same stuff.
any ideas, i do have GFB pulleys and a lightweight flywheel and a stereo system w/an amp, but its a 5 ch. mtx making about 500 watts and i have a monster half farad cap.
maybe a new alternator?, maybe a heavier duty alternator?
thanks guys
-mikey
mcu81 is offline   Reply With Quote
Old 02-06-2004, 01:06 AM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
It could be your voltage regulator in your alternator as well. Then again, 500 watts and pulleys probably aren't helping the matter any.
Brian
Old 02-06-2004, 10:43 AM   #3
Sparks
Member#: 16495
2013 BRZ
Sterling Silver Metallic
I have seen 2 cars with voltage problems related to the GFB pulley kit. It changes the design speed of the alternator.
Remove just the alt pulley and see what your voltage holds at cruise,
Shaun
Sparks is offline   Reply With Quote
programming voltage is 4.2 volts programming voltage is too ECU FLASH ERROR killa996 Commercial ECU Reflashes 21 03-16-2007 04:47 AM
Q's Trouble with catch can Extreme trouble moorebl Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-24-2007 09:37 AM
Help with Trouble-shooting Code 42 ABS Power Source voltage abnormal Sir_Xenon Service & Maintenance 0 12-22-2004 05:26 PM
('93-'01) Wide band O2 sensor voltage range jeffg Impreza Forum 5 06-05-2001 03:26 PM
voltage issues running big amps Billy Car Audio, Video & Security 10 02-17-2001 08:03 PM
