Old 02-05-2004, 08:27 PM   #1
Rickyh
Member#: 40453
Default safc 2 install and initial impressions
Let me preface this by saying that I know that this is not an ideal setup. Of course a utec would be much, much better, but I got a good deal on an safc 2 and decided to try it out. Anyway, the install is simple enough, and it does look cool (if the bling factor is important). I don't have a wideband yet so I have only leaned everything out by 1 or 2% on the low end. My egt's haven't gone over 760, so I feel ok about it. It pulls a good bit harder than before(I was using a txs stage 2 unichimp), and drives a LOT smoother(no more part throttle hesitation). I wish there was a 4 wheel dyno in Louisiana so that I could get some measurable results. Anyway, when I get a wideband, I will get a little more aggressive with it (vf22and injectors waiting to be installed). I have been driving around for about 6 days and haven't had any trouble with the ecu learning around it yet.
txs up, helix dp, nurspec catback, blitz sbc-id, safc, hacked intake.
Rickyh is offline   Reply With Quote
Old 02-05-2004, 09:55 PM   #2
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
i bet itll a fun wait till you get your bigger injectors in, thats when you'll get full potential on your device.
STi-Nismo Dood is offline   Reply With Quote
Old 02-05-2004, 10:54 PM   #3
cronic
Member#: 9749
Doesnt the V2 have a option for a knock sensor?
cronic is offline   Reply With Quote
Old 02-05-2004, 11:29 PM   #4
Rickyh
Member#: 40453
Yeah. It just taps into the stock knock sensor. It just gives a number value based on the voltage from the knock sensor. It doesn't offer any sort of correction.
I need some Stg 2 Install and Tuning Advice BazeenerSTi Newbies & FAQs 2 02-09-2010 08:26 AM
Tokico D-spec install done--Initial impressions Acostafan Brakes, Steering & Suspension 18 05-09-2006 10:00 PM
Vishnu Stage 2 install and tune at Dyno4mance rich728 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 10-04-2004 03:04 PM
TurboXS stage 2 installed. Initial impressions and possible problems BOP Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 05-18-2002 12:19 AM
how much 2 install and paint? mickey finn Canada Region Forum 2 06-14-2001 08:35 AM
