Old 02-06-2004, 01:29 AM   #1
ESTCOASTSUPORTER
Member#: 34254
2003 WRX
WHITE
Default Utec Boost
i cant my boost to drop . i keep maxing out around 19-20psi nomatter where i adjust the boost controler that comes with the utec. the high boost is causing me knock. im trying to run stage 2 or 3
ESTCOASTSUPORTER is offline   Reply With Quote
Old 02-06-2004, 08:36 AM   #2
Cosmo
Member#: 31777
2003 Subaru WRX
Yellow
IM or e-mail me. Chances are it's an easy fix. But, I need more information to tell you what to change.
AIM - upfromtheskies
E-mail - chad&imprezafest.org - replace the & with @
Cosmo is offline   Reply With Quote
Old 02-06-2004, 09:57 AM   #3
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Open the ABC two turns then adjust the values in the boost map until you hit your target boost level. If you are running closed loop boost start with 200 and add 25. With open loop start at 90 and remove 10.
cdvma is offline   Reply With Quote
Old 02-06-2004, 01:06 PM   #4
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
It's been really cold out lately... I had similar problems. Where in the RPM range are you maxing out? 3k rpms?
Close your ABC all the way if you have to... mine's barely open (maybe 1 turn) and I can STILL overboost in higher gears.
You and me need to switch to closed-loop boosting, I think
rogue is offline   Reply With Quote
UTEC boost control, or UTEC combined with Profec B...advice needed... gills UTEC 9 04-01-2006 04:39 PM
utec question changing to MBC from utec boost trbowrx Engine Management & Tuning 8 06-28-2005 07:15 AM
UTEC, boost tuning, boost gauge vs map psi SJWWRX Engine Management & Tuning 2 07-09-2004 10:22 AM
utec boost V.S. electronic boost control SmoknWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-31-2004 11:33 PM
UTEC Boost control as good or better than other boost controllers? DocDetroit Engine Management & Tuning 0 02-04-2003 09:40 PM
