Old 02-06-2004, 04:35 AM   #1
Pete Holt
Member#: 12
2013 G37S 6spd sedan
Moonlight White
Question What is involved in installing STi injectors?
I am looking to add the Cobb VF34 upgrade to my '02 WRX and I think I can figure everything out, but I am curious if there is anything difficult or unusual about installing new injectors since this is one of the few things that I have not had to do in the past.
Thanks
Pete Holt is offline   Reply With Quote
Old 02-06-2004, 09:59 AM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Patience and about 2 to 3 hours. The '02s have green brackets that cover the injectors and fuel rails, you have to remove these and it takes a bit of finesse. They are named the "green brackets of death". Do a search you will come up with several hits with tips.
cdvma is offline   Reply With Quote
Old 02-06-2004, 11:54 AM   #3
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
I understand you are using a different vendor, but the TurboXS Stage 4 instructions might prove helpful.
Disconnect the fuel pump relay located in the passenger footwell. Run the car till it stalls and then crank it for a few seconds to remove as much of the latent fuel pressure as possible. For removing the GBODs, I strongly recommend having a 12mm gear wrench (mine is offset, straight one should work fine too). It is possible to remove the brackets without unplugging the TGV sensors, which is worthwhile since those sensors are spring-loaded and can't simply be plugged back in as-is. Everything else should be fairly self explanatory after looking at it for a bit--i.e., what to unbolt to give yourself more room, getting the rails disconnected from the head, and so on. If you end up leaving the brackets off (they would be a PITA to put back on, if you ask me), either cut off the ventilation system hard line on the rear of the driver side bracket, or go to the hardware store and find a method of connecting the hoses together.
Joel
Zola is offline   Reply With Quote
Old 02-06-2004, 12:30 PM   #4
RussB
Guest
Member#: 43667
is the process easier on an 03?
RussB is offline   Reply With Quote
Old 02-06-2004, 05:11 PM   #5
Pete Holt
Member#: 12
Moonlight White
The green brackets of death eh? Maybe this will be one mod that I will finally leave to the pros. Maybe I am getting old.
Old 02-06-2004, 05:13 PM   #6
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
I did this myself, and calling me a "pro" would require certifiable insanity. It is much, much easier than it sounds and/or looks.
Joel
Old 02-06-2004, 05:42 PM   #7
eightballrj
Member#: 18520
2005 L GT Limited
The technical skill required for this mod is not that great... It is the whole patience is a virtue thing that your mom taught you that will be tested. Green brackets of death are the DEVIL... not at much as the uppipe devil but almost as bad, hehe.
Good Luck,
RJ
eightballrj is offline   Reply With Quote
Old 02-06-2004, 10:42 PM   #8
Pete Holt
Member#: 12
Moonlight White
Well,
I guess it's worth a shot. I will test out my patience as long as there is a wall near by for me to throw things at when I lose my patience.
Old 02-09-2004, 12:37 PM   #9
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Toss the brackets at the wall, I gave mine a non-chalant toss onto the ground and out of sight when I yanked em off
Old 02-09-2004, 02:03 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Be careful throwing the green brackets at the wall!!!!
They BOUNCE
Pete....check your PM's
Old 02-09-2004, 06:03 PM   #11
motoxphil
Member#: 5094
11.96, 1.64, 115mph!
I suggest you start with the drivers side first since it is very straight forward. Less "death" involved on this side.
Now go have a drink and tell your self how easy that was and that these "internet" guys don't know what they are talking about.
Ok, now plan on it taking 3 times as long on the other side. It is much easier to do this side with the turbocharger and intercooler removed. From memory...you may need a crow foot and a swivel joint.
Don't forget to "clock" the injectors properly and make sure you do not accidentally pull the fuel pressure regulator boost source line.
Good luck!
Phil
motoxphil is offline   Reply With Quote
Old 02-09-2004, 07:55 PM   #12
Pete Holt
Member#: 12
Moonlight White
Thanks for the advice guys. Very funny, indeed. I will be sure to bring some single malt scotch to work the day I attempt this to make the passenger side go in easier. ha
Old 02-09-2004, 08:08 PM   #13
eightballrj
Member#: 18520
2005 L GT Limited
Hmm, scotch... now you want to be able to get to the other side. Ah well, just make a small drink. Dont wanna fall asleep between the two sides and have half of the injectors done, haha.
RJ
Old 02-09-2004, 10:47 PM   #14
motoxphil
Member#: 5094
Between the gas fumes and the scotch, I would give yourself 10 hours
Thanks,
Phil
What is involved in machining an 05 STI knuckle for a WRX? FromageTheDog Brakes, Steering & Suspension 6 11-09-2009 07:47 PM
What is involved in installing JDM HID's for a 2005 STI??? ONEQUIKSTI Electrical & Lighting 11 11-03-2005 05:20 AM
What is involved in turboing an RS? attitude Subaru Conversions 4 01-10-2005 07:24 PM
where can i find out what is involved in a 60k checkup? Canadian 2.5RS Newbies & FAQs 6 07-09-2004 12:42 PM
What is involved in removing the front grill? delectron General Forum Archive 2 08-31-2000 07:03 PM
