Old 02-06-2004, 12:04 PM   #1
elsanto
Member#: 34832
1989 M3
Default ECU question. Ecutek vs UTEK?
I'm trying to compare the Utek vs the Ecutek reflash that shiv does.
I like this aspect of the UTEK from turboxs website and wanted to make sure that the reflash from vishnu will do the same things..
from turboxs
UTEC enables complete programmable control over ignition timing, fuel, and boost, while allowing the factory ECU to maintain control over tedious and mundane functions that make the car drivable on a daily basis._ Functions like cold start, hot start, intake temperature compensation, AC compensation and closed loop fuel control signals are all managed by the factory ECU reducing your tuning time significantly while enhancing daily drivability._ Spend your tuning time doing what we all like to do making your WRX faster!
sorry if this is a basic question I can't find much info from vishnu's site and know there are alot of really smart people on here!
THANKS!
elsanto is offline   Reply With Quote
Old 02-06-2004, 01:36 PM   #2
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The Utec (not Utek) only alters the signals that the factory ECU sees. ECUtek remaps the factory ECU with new values (fuel, timing, boost).
They are different means to the same end. I prefer ECUtek, but that is because I don't have to change my maps anymore since I like the power I have. Tsis is the main benefit to the Utec. You can change your maps along your upgrade path to make the most of your mods.
mbiker97 is offline   Reply With Quote
Old 02-06-2004, 01:39 PM   #3
PunKidd
Member#: 8533
2002 2.5 RS-T
LudeSpeed S. III W/ FMIC
ECUTek keeps all the factory controls in tact. In fact all ECUTeck does is change the factory maps so that it runs the AFR and advance that you need for your mods. ECUTeck does not add anything to interfere w/ the operation of the ECU, so the ECU runs the same as stock, just w/ different maps.
-Jared
PunKidd is offline   Reply With Quote
Old 02-06-2004, 01:40 PM   #4
elsanto
Member#: 34832
1989 M3
Ok so with the ecutek I need to have someone that knows what they're doing remap it, and with a Utec I can mess it up myself.. thanks for the clarification I definitely understand it better now.
Old 02-06-2004, 02:49 PM   #5
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
Just don't assume someone knows what they're doing just because they purchased ECUTek's DeltaECU tuning product :-)
Macabre is offline   Reply With Quote
Old 02-06-2004, 02:59 PM   #6
elsanto
Member#: 34832
1989 M3
haha thanks, I'm getting tuned by shiv, and from what i hear he knows a thing or 2 about these cars. im just thinking farther along when i do a turbo if hes not coming back for a while I'd have someone modify it slightly.
Old 02-06-2004, 03:17 PM   #7
nmyeti
Member#: 4980
The UTEC does not alter any signals related to boost or timing to trick the stock ECU. The UTEC offers full standalone timing and boost control, and soon will stop using piggyback fuel control.
-Nathan
www.turboxs.com
nmyeti is offline   Reply With Quote
Old 02-06-2004, 03:33 PM   #8
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
-Nathan
www.turboxs.com
Yeah sorry 'bout that. It only modifies the MAF right?
Old 02-06-2004, 03:59 PM   #9
nmyeti
Member#: 4980
The only signal manipulation of the current UTEC is for the MAF sensor. In the near future the UTEC will handle the fueling directly.
-Nathan
Old 02-06-2004, 04:16 PM   #10
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Sweet. That will definately be a great feature. The best of both the piggyback and standalone worlds.
Old 02-06-2004, 04:19 PM   #11
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
Utec is great if you will be making changes to your car over time. it's cheaper in the long run than getting reflashed.
Ecutek is great for set it and forget it. You put everything into the engine then get it tuned and dont touch it again.
Either way, as long as you get a good tuner to work on the car, you'll be happy.
MikeWRX-NJ is offline   Reply With Quote
Old 02-06-2004, 07:32 PM   #12
03WRXMA
Member#: 35081
2012 WRX
-Nathan
Nathan -
will current UTEC users be able to flash the firmware to get this feature as in the past?
-Dave
03WRXMA is offline   Reply With Quote
Old 02-06-2004, 08:16 PM   #13
Delicious Tuning
Member#: 1990
Just to let you know there are many companys that say they tune EcuTek's. There are definitely recommended shops as suggested by many people on the boards.
I would do some research on who are recommended tuners and who is not. there are definitely well know tuners that do good work, such as Vishnu, Cobb or I-Speed USA.
Yeah I had to get my 2 cents in,
Bill Knose
www.i-speed.us
Delicious Tuning is offline   Reply With Quote
Old 02-06-2004, 10:11 PM   #14
nmyeti
Member#: 4980
Originally posted by 03WRXMA
Nathan -
-Dave
Every UTEC we've ever sold will be able to get the free firmware update that will enable this feature.
-Nathan
Old 02-06-2004, 11:52 PM   #15
Delicious Tuning
Member#: 1990
Nathan,
When is the expected release date of the new ECU. From the sounds like it, it will be a pretty good unit.
Cheers,
Bill Knose
www.i-speed.us
Old 02-07-2004, 01:15 AM   #16
elsanto
Member#: 34832
1989 M3
haha yes absolutely Im going with Shiv on this one. thanks again for all the input the turboxs sounds like a great unit, but probably more than i need..
also if i go with an ecutek and want to go back to stock.. how do you go about reflashing it?
Old 02-07-2004, 08:15 PM   #17
nmyeti
Member#: 4980
Originally posted by skywalker
Nathan,
Cheers,
Bill Knose
www.i-speed.us
Bill the new firmware is in beta testing now. I hope to have a preliminary version of this software out sometime in the next two weeks, but obviously it has to pass the beta test first.
-Nathan
www.turboxs.com
Old 02-07-2004, 10:02 PM   #18
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
elsanto don't forget about Cobb's AccessECU or AccessPort. You do the flashing yourself with their maps, and if you have to go back to stock, you do it yourself. Eventually they will have a tuning setup available which will give you full control of the ECU.
Used UTECs = HIGH resale value
Used AccessPORT = HIGH resale value (ok i know they aren't out yet but I'm smart and I know these things)
Used custom ECUTek ECU = hard to sell and low resale value.
mexicanpizza is offline   Reply With Quote
Used Ecutek ECU Questions compressro Commercial ECU Reflashes 2 05-01-2009 10:52 PM
WTD 04 STi ECU with EcuTEK for stock ECU typer_126 Bay Area Impreza Club Forum -- BAIC 0 10-19-2005 07:14 PM
Ecutek vs. Utec vs. AP vs. Other Inprogress Engine Management & Tuning 23 02-28-2005 06:01 PM
Xede vs Cobb vs Utek... serious inquiry Padge Engine Management & Tuning 7 01-12-2005 01:01 AM
ecutek vs. utek SLowery Engine Management & Tuning 28 02-19-2003 01:22 PM
