Old 02-06-2004, 12:48 PM   #1
ezatnova
Member#: 10877
2007 BMW 335 Coupe
Space Gray with Coral Red
Question TXS stage 2 Unichip vs Cobb Stage 2 Access ECU
Anyone made the switch or have experiences with the two?
I have the Unichip setup and it's OK, but I have occasional knock in cold weather despite the ABC being closed fully (running 16 psi). I also have the prerequisite hesitating acceleration and occasional P0420 codes.
Anyone ever get cold weather knock with the Cobb stage 2?
I imagine the power gain is not far off between the two, but is there a real difference? (It wouldn't be accurate to just compare the TXS web page dyno plots to those on the Cobb)
Thanks!
Jeff
ezatnova is offline   Reply With Quote
Old 02-06-2004, 03:29 PM   #2
KJR
Member#: 16879
if you have the revision 3 board with the unichip then you need to see THIS . this will help with the low rpm hesitation. i have also heard of many people experiencing detonation with the Cobb stage 2 reflash. you can probably do a search and find some more info about that. i have a TXS stage 2 and am having it custom tuned for my extra mods. i have only experienced knock with it when i installed samco hoses with the stock IC. i installed a V2 txs tmic and it went away. gotta watch out for too much air=lean condition! (IE: open element intakes and high flow tubing).
KJR is offline   Reply With Quote
Old 02-06-2004, 03:44 PM   #3
ezatnova
Member#: 10877
2007 BMW 335 Coupe
I waited for the Rev. 4 board so I could adjust where full boost hits. I have it way up around 65 - 75% throttle.
Old 02-08-2004, 06:05 PM   #4
rotorbaru
Member#: 22493
2003 Impreza WRX
Silver Cobb stg 2
I have Cobb stage 2 and have not had any knocking in any weather, nor have I seen many posts about knocking and Cobb stg 2.
rotorbaru is offline   Reply With Quote
Old 02-08-2004, 06:16 PM   #5
mouserWRX
Member#: 48960
2006 TL
Anthracite
I believe the dyno that Cobb used dynoes pretty high, but I still think it's a great deal and you get some good gains from it.
mouserWRX is offline   Reply With Quote
Old 02-09-2004, 08:40 AM   #6
ezatnova
Member#: 10877
2007 BMW 335 Coupe
Turns out my knock was cured by some Sunoco 94. I'm almost leaning towards a bad batch of 93 Mobil gas as the problem. Hard to believe that if the 93 were fine, I'd have lots of repeatable knock, then NONE when I fill up 2/3 tank with one octane higher.
Anyway, on Mouser's note, I believe I remember Cobb mentioning that TXS tends to be overzealous with their dyno charts, which to me means they are more conservative.
I was hoping someone could chime in with direct experience going from a TXS S2 to a Cobb S2 as far as power. I have heard that teh Cobb is so much smoother (especially more than Unichip) that it FEELS slower because everyting is more progressive rather than an on/off boost feeling.
Old 02-09-2004, 08:46 AM   #7
rotorbaru
Member#: 22493
2003 Impreza WRX
Silver Cobb stg 2
Hello Ezatnova,
Your "bio" states you have a WRX with TXS stg2, is that still the case?
Old 02-09-2004, 08:50 AM   #8
ezatnova
Member#: 10877
2007 BMW 335 Coupe
Originally posted by rotorbaru
Hello Ezatnova,
Yep.
Old 02-09-2004, 08:54 AM   #9
rotorbaru
Member#: 22493
2003 Impreza WRX
Silver Cobb stg 2
Yep.
I wish I could give you a better comparison between the TXS stg 2 and cobb stg2. I know my cobb stg 2 is very smooth and linear, which may make it appear to "feel" slower. I have never been in a TXS WRX to compare smoothness.
09 WRX. Perrin stage 2 vs Cobb stage 2 map. Liquidr1 AccessPort 10 02-22-2010 09:05 PM
Cobb stage 2 (w mods) VS. Cobb stage 2 (w mods) Happy_Days Proven Power Bragging 7 11-28-2004 04:25 AM
Vishnu stage 0 package or Cobb Stage 2 with TXS Stealthback and uppipe. OvRclockR Proven Power Bragging 0 10-02-2003 10:46 PM
WTB: TXS Stage 2 Unichip or Vishnu Stage 1 for $350 shipped WRXVII Tri-State Area Forum 2 03-08-2003 12:27 PM
Will pay $350 for TXS Stage 2 unichip or Vishnu Stage 1 w/ PNP WRXVII Tri-State Area Forum 0 03-04-2003 11:32 PM
