Old 02-06-2004, 01:48 PM   #1
Bean75
Member#: 31282
2003 WRX
WRBlue
Default EGT gauge problems
The EGT has been installed for about a year. Its an autometer sport comp series.
I get in my car this morning and the gauge is pinned all the way to the right. This is just turning the car on. Its not just all the way to the right, the needle is basically pointing due south. I only have a 10 min ride to work, so I start the trek, taking it slow.
The gauge stays pinned the whole ride to work (all highway). I apply the brakes as I get ready to slow down for the off ramp and the EGT gauge jumps to 1400 F (which is what I am usually at for light highway driving. But as soon as I touch the gas again to accelerate off the ramp, the needle dips back down to due south.
Anyone had this problem or can think of what it could be? I'm hoping its a gauge related issue and that the probe is still fine. Any insight is appreciated.
Thanks
Bean75 is offline   Reply With Quote
Old 02-06-2004, 02:25 PM   #2
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Check to make sure you gauge is grounded good. Otherwise it kinda sounds like your sensor went bad. Be happy it's not a Defi sensor.
mbiker97 is offline   Reply With Quote
Old 02-07-2004, 03:52 PM   #3
awdman
Member#: 27962
2003 WRX Sedan
Blue, with more dings!
Default What he said ..
Also be aware that autometer makes different probes.
Typically the faster acting probes are shorter in lifespan.
ATM5249 Severe duty slow acting probe
ATM5244 Standard duty fast acting probe with open tip
ATM5245 Severe duty fast acting probe with open tip
ATM5247 Same as 5244
hope this helps!
awdman is offline   Reply With Quote
Old 02-14-2004, 02:38 AM   #4
NateDogg
Member#: 6467
1999 Impreza 2.5 RS
awdman,
do you know which probe comes with the phantom EGT kit? and why would there be two different part numbers for the same probe? also.. of all listed and not listed what are everyones thoughts on the best prode out there that will work with anautometer guage?
Nate
NateDogg is offline   Reply With Quote
Old 02-14-2004, 02:46 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Check the ground, but if you have had the gauge for more than 15k miles it may be shot. EGT probes must be considered a consumable item and to be replaced.
I have the 5249 on a Sport Comp gauge and I get needle movement within a second or so of starting my car and it reacts fast enough to be useful, IMO...it is also reccomended for turbo applications....no problems in 10k miles.
Old 02-14-2004, 02:37 PM   #6
awdman
Member#: 27962
2003 WRX Sedan
Default Sorry Nate!
I do not know what probe came with your gauge. I actually got that list from I-club! I am also perplexed as to the same probe having 2 numbers...
Call Autometer and see if they can tell you anything.
(815) 895-8141
I don't even see a # on my probe! I got a Z-series EGT...
Old 02-14-2004, 03:24 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
The 5247 and the 5244 are the same except for cable length the 5244 has a 10' cable and the 5247 has a 6' cable.
EGT Gauge problem WS6toWRX Engine Management & Tuning 11 09-21-2010 04:51 AM
Omori EGT gauge problem (long) BluSuby Electrical & Lighting 10 07-15-2005 02:13 PM
egt gauge problem STI DUDE Electrical & Lighting 5 01-17-2005 03:26 PM
Omori EGT gauge problem... mturmel Electrical & Lighting 9 05-10-2003 11:58 PM
Greddy EGT Gauge Problem mikev123 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-13-2002 08:41 PM
