Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 02-06-2004, 03:19 PM   #1
Structure828
Member#: 50488
1999 GC8 ej20g!
Default EJ20G turbo options...I NEED YOUR HELP ALL!
Hey Guys,
I have been sticking with the EJ20G misfire posts and now I think
we found out what the problem was and I need some advice from you guys.
I have an EJ20G out of a 93 JDM legacy. I am putting it in my 99' 2.5rs
It should be pretty bad ass when its done. For a factory sized turbo, it
was pretty decent. Seemingly MUCH better then a factory WRX turbo US spec.
The turbo is bad we found out and needs to be replaced. What do you guys
reccomend and what turbos will bolt right up to it being that its JDM?
Obviously if I could find another 93 legacy turbo that is JDM that would work but
what else would? And what else would you guys reccomend?
Factory WRX one?
Next step up WRX turbo that is a bolt on?
What are my options...PELASE HELP
Structure828 is offline   Reply With Quote
Old 02-06-2004, 03:27 PM   #2
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Lightbulb
all the IHI Subaru turbos should be the same flange style
you can't rebuilt your turbo?
Scoobyslack1 is offline   Reply With Quote
Old 02-06-2004, 03:35 PM   #3
Structure828
Member#: 50488
1999 GC8 ej20g!
Is the VF8RHB52 JDM turbo a ball berring turbo or not?
Its the factory Legacy turbo from the JDM ej20g still....
Old 02-06-2004, 03:38 PM   #4
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
well you could go all the way .. gpmoto is about to make garret uppipe/down pipe combos .. they point to the side so they should work
*** i re-read your post
the factory turbos from a an early legacy turbo: vf-10 vf-11 and vf-12 .. all much smaller than the td05
i have never heard of a vf-8 tho
and no the stock turbo is not all that hot..
i have the same engine .. mine came with a vf-10 for which rebiuld kits are ~150 in parts
i don' t think and subaru comes factory with a BB turbo
the best power solution get an unmodified td05 from deadbolt
Old 02-06-2004, 03:45 PM   #5
Structure828
Member#: 50488
1999 GC8 ej20g!
cool, yea the mechanic said it was a VF8RHB52...im most likely going to get it rebuilt I guess...I guess that would be the best way to go? Its much better then a factory WRX us turbo.
I know there is MUCH better aftermarket stuff out there, but that should do it for now, all agree?
If it CANT be rebuilt and its toast? Which would be the best to go with? A vf10 someone said?
Old 02-06-2004, 03:45 PM   #6
Scoobyslack1
Member#: 2780
junk yards rule!
Exclamation
VF8 does sound real small
I'll have a USDM Legacy turbo soon (VF11 I think)
I don't think any came w/bb turbo either....maybe an STi, but not a Legacy
if the flanges are the same you can use any up/downpipe that a WRX uses
Old 02-06-2004, 03:47 PM   #7
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
first
it is not decently sized.. it is noticaly smaller than the td04L
factory RSs only ran 7 psi
although i have never seen a vf-8
there were legacy RS-RAs that may have had a differnt turbos
Old 02-06-2004, 03:49 PM   #8
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
(slap)alan..
the fanges are the same but it requires the upturned inlet
Old 02-06-2004, 03:54 PM   #9
Scoobyslack1
Member#: 2780
junk yards rule!
Lightbulb
I didn't say anything about the intake....
did the TT Legacys have two small turbos?
Maybe it's from one of those.
is this for turbo manifolds or NA?
I still need to get a 'new' turbo...Garret spool up quick
Old 02-06-2004, 03:54 PM   #10
Structure828
Member#: 50488
1999 GC8 ej20g!
So the Vf8 is small, but yet bigger then the USDM wrx turbo
Weeee, wow that must make that 1 really small.
Old 02-06-2004, 03:54 PM   #11
Scoobyslack1
Member#: 2780
junk yards rule!
Exclamation
no, smaller than the USDM WRX turbo
Old 02-06-2004, 03:55 PM   #12
Structure828
Member#: 50488
1999 GC8 ej20g!
Where could I get a TD05 turbo? What is it off of? Is it a DIRECT bolt up to the JDM ej20g? How much would it be?
Old 02-06-2004, 03:56 PM   #13
Structure828
Member#: 50488
1999 GC8 ej20g!
My mechanic, and Smacksube (who is working on it as well) both said it was obviously visually bigger then the US spec WRX turbo. That make any sense to anyone?
Old 02-06-2004, 03:58 PM   #14
Scoobyslack1
Member#: 2780
junk yards rule!
Arrow
nope
Old 02-06-2004, 04:02 PM   #15
Structure828
Member#: 50488
1999 GC8 ej20g!
Isnt TD05 the wrx turbo? I dont want to sound defensive guys, and I really am looking for your opinions/facts, but Scooby Slack, didnt u just say you never saw a vf8? Are you POSITIVE its smaller then a us WRX one? Because 2 people said it looked bigger that were holding it.
EEEK what should i do.
Old 02-06-2004, 04:21 PM   #16
Scoobyslack1
Member#: 2780
junk yards rule!
Lightbulb
if they have it in there hands & can compare it then fine, I'm just saying that it doesn't make sense to me because of the car it came off of
The USDM WRX has a TD04......the TD05 came on some JDM WRX's
Old 02-06-2004, 04:29 PM   #17
Structure828
Member#: 50488
1999 GC8 ej20g!
OK, a subaru mechanic in Tampa just sait the FV8 is basically about the same size, maybe a tad bit smaller then the US WRX turbo. he said it was built stronger, but its a slight bit smaller. I guess I am in search of a TD05, for best case senerio now. If anyone knows where I can get 1, or has another turbo of similar size, let me know. Il pay for it now, and have it overnighted to me
Old 02-06-2004, 04:40 PM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Subaru part number:14411AA030, IHI part number RHB52XW VF8
This was the turbo used on Legacy turbos in the early 90's in Japan. The best information I can find would put it less powerful that a TD05, but more powerful than the VF-10's and VF11's on USDM Legacies.
A higher VF number does not mean a bigger more powerful turbo. Look at the VF-22's and 23's. They are definitely more powerful than a VF-28 or VF29. I'll see what else I can get you. I am on a new computer and don't have all my tech files in order yet. I think I have the flow for it around here somewhere...
Old 02-07-2004, 11:24 AM   #19
Puckaveli
Member#: 1518
00 2.5RS
Look on Scoobynet there are guys selling the side-entry TD05's all the time.
Puckaveli is offline   Reply With Quote
Old 02-07-2004, 11:34 AM   #20
Structure828
Member#: 50488
1999 GC8 ej20g!
OK, so the FV8 RB52 turbo that is blown that I have is more powerful then the US VF-10's and VF-11's but SLIGHTLY less powerful then the US wrx TD04 turbo. A TD05 which was found on JDM wrx's and some sti's would be the best direct replacement to pop on, and would be a small gain, but better then the WRX TD04. So it sounds like I can use a TD04 without a problem, but the TD05 would be better if I can get one. I will check Scoobynet for 1 Puckaveli, and TY Matt Monson, it sounds like you know your stuff.
Old 02-07-2004, 11:35 AM   #21
Structure828
Member#: 50488
1999 GC8 ej20g!
Puckaveli, what is the scoobynet URL pls?
Old 02-07-2004, 01:08 PM   #22
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
Old 02-07-2004, 03:33 PM   #23
Structure828
Member#: 50488
1999 GC8 ej20g!
Anyone in the FL area got a td04 or td05 for sale? I need it this weekend
Old 02-08-2004, 02:10 AM   #24
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Your gonna need a different ECU if you bolt up that TD05/04 to your engine!!!
DuoMaxwell is offline   Reply With Quote
Old 02-08-2004, 10:03 AM   #25
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
I though I saw someone on these forms selling a Td05 try a search for TD05 see if anyone still has it
scobaru is offline   Reply With Quote
ej20G turbo options marc l Pre-2002 Factory Turbo Powertrain 20 09-19-2009 10:46 AM
Turbo gurus I need your help! fastwrx006 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 08-22-2005 07:08 PM
Turbo guys: Garrett needs your help! (quick survey) SR20DETg20girl Off-Topic 22 02-01-2005 12:56 PM
Turbo Knowledged Guys... need your help omahasubaru Mid West Subaru Owners Club Forum -- MWSOC 7 01-20-2001 09:00 PM
Calling all turbo tech experts: I need your help... Rich L Technical Forum Archive 10 09-27-2000 02:34 PM
