Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 02-06-2004, 05:22 PM   #1
silvscorp
Member#: 28480
Default Sidemarker to turn signal conversion
i've read many posts regarding rewire the sidemarker and make it flash while the turn signal is on. My simple thoughts are just to wire the power and ground with the turn signal's power and ground in the headlight assembly.
However, many posts mentioned a relay and other complicated grounding. Are those just for the sidemarker to be on alone with parking light? I don't see the point of all these parking light function in the first place. So I don't care if they turn on while the parking lights are on.
So can anyone tell me if my thoughts will work? Basically I will cut the original whires and tape each one of them, then use two new wires to connect the sidemark's bulb and splice them to the turn signal in headlight assembly.
thanx
silvscorp is offline   Reply With Quote
Old 02-06-2004, 06:03 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
your idea should work.
my brain is fried right now, but if I where going to do it, thats the way I would.
Jay
Old 02-06-2004, 06:06 PM   #3
silvscorp
Member#: 28480
kewl thanx for the heads up.. I just need some one to confirm with that idea just incase I might has missed some other wireing problem. e.g if the blinkers are wired with some other bulbs in series.
Old 02-07-2004, 12:53 AM   #4
avk
Member#: 17252
'06 WX8
59E
To convert the marker into a blinker-only light, simply re-connect its positive wire to the positive for the turn signals, and keep the ground.
If you want it to operate both as a marker and a blinker, keep the positive wire to the blinker but disconnect the negative from the ground and splice it into the positive for the turn signals on that side.
avk is offline   Reply With Quote
2000 Impreza RS LED Front Turn Signal Conversion apkarian100 Interior & Exterior Modification 5 07-14-2009 08:58 AM
Fs Or Trade: 95 Clear Sidemarkers And Clear Turn Signals nmbwhitey 1993 - 2001 Impreza Specific Parts 6 03-08-2008 08:33 AM
Side marker to turn signal blinker convertion ObiWanJak Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 09-26-2001 04:33 PM
Wiring Fog Lights to Turn Signal carrata Interior & Exterior Modification 1 07-03-2001 05:21 AM
How do you connect corner lights to turn signals? jay25RS Interior & Exterior Modification 4 06-23-2001 08:00 AM
