Old 02-06-2004, 06:49 PM   #1
FlyingFishSandwich
Member#: 54228
2005 Impreza PSM
rice bad, sleeper good
Default Headlights cause noise when sterio is on?
I've searched for this problem and couldn't find it. Sometimes when its cold out and I turn on my lights, this steady tone comes out of my sterio. I have the stock cd player and I've done nothing to my headlights. I've heard something about grounding kits somewhere. So my question where could I find one of these grounding kits, is that what I need and/or how do I go about fixing this without one? I am very electronically inclined so that area is not a problem. I have access to a soldering iron if I require one and I'm not afraid to use it.
FlyingFishSandwich is offline   Reply With Quote
Old 02-06-2004, 07:59 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Is the tone really steady or does it vary in frequency with engine RPM? It may be alternator whine caused by the additional current drain when you turn on the lights.
This isn't normal, so if it's indeed alternator noise the alternator itself may be bad. It would be a good idea to have the electrical system checked out, both alternator and battery. A weak battery can cause something like this also by making the alt. charge more heavily.
As for grounding I doubt this is your problem, but if you want to experiment forget about the $$ fancy grounding kits and just get some decent wire, 10 gauge or better, crimp or solder on the proper ring terminals, and run a connection from the battery negative terminal to the grounding point on top of the driver side intake manifold. See if that makes any difference.
While you're at it check both battery terminal connections and be sure they are clean and tight.
Old 02-07-2004, 12:30 AM   #3
FlyingFishSandwich
Member#: 54228
2005 Impreza PSM
It doesn't change with the RPMs, its just when I turn on the lights and it comes from the speakers. Thanks for the advice though.
Weird 'Blowoff' Noise when AC is on. Drumboy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 05-06-2010 04:43 PM
Squealing noise when AC is turned on... Advice? nxwrxfx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-08-2006 07:44 PM
Wierd noise when compressor is on. progresr Service & Maintenance 4 02-26-2004 07:13 PM
Clutch noise when car is on. LESLIEx317537 STi Forum Archive 5 08-07-2003 04:21 PM
weird noise when heater is on mofoporn General Community 3 03-08-2002 10:56 PM
