Old 02-06-2004, 07:35 PM   #1
ivrep
Member#: 53237
2006 sleeper wagon
black
Question Loose wires behind the fuse panel
It starts off with my car getting a cel the other day. I'm thinking its because of my up and down pipes causing a cat error. Funny thing is I installed the cel fix during the installation of the pipes?!
Ok so here is the problem I rest the ecu and while I was giving it time to sit I started poking around behind the fuse panel and found two wire connectors (green in color) with only one wire black and red, one black and blue. They looked like a perfect match so I plug them together. Perfect fit!!!!! I connect the battery and turn the key ....the car starts beeping, the fans turn on and I get a blinking cel.. so I take the key out and disconnect the wires as they were in the first place. Took the car for a spin, and everything seems fine. Does anyone know what that wire is for? Help!
ivrep is offline   Reply With Quote
Old 02-06-2004, 07:48 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The green connectors are only plugged together to activate a diagnostic mode for the ECU that is used by the factory or dealer. It's not something you would ever want to do as an owner, as you just found out the hard way.
I don't think I have to tell you never to do that again
Now, as for the CEL you didn't do the right thing to find out what was wrong. Rather than reset the ECU, which erases the code from memory so it can't be read, you should have had the car scanned and the code read out. That way you would know what caused the light to come on.
Since you didn't actually fix anything, it's highly likely the light will come on again soon. When it does, get it scanned. Unfortunately you're in CA so you can't go to an Autozone for this service like in other states, so you should check in your local forum for nearby members who have scanners.
Old 02-06-2004, 08:14 PM   #3
ivrep
Member#: 53237
2006 sleeper wagon
black
Your right I will never ever do that again . Thanks for your help on the wire and the cel I'll look into the scanner. Do you think Autozone in Arizona have scanners?
Old 02-06-2004, 08:27 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
AFAIK they will do it in any state other than CA, they stopped there because of legal issues.
Old 02-06-2004, 08:29 PM   #5
ivrep
Member#: 53237
2006 sleeper wagon
black
Thanks a ton.
Wire diagram for underdash fuse panel? vision.dynamix Electrical & Lighting 7 11-23-2008 11:43 PM
Wire insulation under main fuse panel stillhere Electrical & Lighting 0 05-03-2007 07:53 PM
Wiring MadDad V2 Boost gauge from fuse panel. Hooligan_22 Electrical & Lighting 6 07-12-2006 03:30 PM
What is the red wire with the pink fuse for in the HU wiring harness? Krelkor Car Audio, Video & Security 3 08-29-2002 11:05 PM
Template for behind the seat sub panel?? 25psi Car Audio, Video & Security 4 05-07-2001 08:20 PM
