Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 02-07-2004, 11:56 AM   #1
Boost4U
Member#: 16459
1998 2.5RS
Default Car Is Running!
I fired up my WRX swaped, TEC-2 powered, 98RS for the first time last night. She started and idled well, thanks to a map from a fellow EJ20 Tec-2 borad member. She drove well until there was a funny drivetrain noise...? It should be known that there is an entire WRX drivetrain in my car including a rear subframe. Second, there was a burning coolant smell and some smoky issues under the hood....but what can I expect having done all the work by myself! Thanks to my buddy Rob, the Tec-2 intstall is almost finished off perfectly....just need to clean up some wires, and figure out how to get the speedo to work, along with the coolant gauge. I think I damage the fuel level sensor when I installed my Walbro pump?? Its been a long and involved project...but I heard my BOV for the first time last night...IT WAS SWEET MUSIC TO MY EARS!!! Thats all for now.
-Chris
Boost4U is offline   Reply With Quote
Old 02-07-2004, 01:07 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
was that my map?
Old 02-07-2004, 01:35 PM   #3
Boost4U
Member#: 16459
1998 2.5RS
nope, it was donated to me by a gentleman named
Yu-Pong Lam.
It is really stable and conservative....a great start for the EJ20
Old 02-10-2004, 01:09 AM   #4
RS22b
Member#: 5413
#15 2-Subaru
Rally Cars !!! Fiesta!
Hey let me know when you get all your gauges to work.
I have a TEC 3 and none of my gauges work either. So i am in need of getting them to work while i go ahead and relace the block that i just killed in the first day of driving the car.
let me know
thanks
Billyqua
rally driven......................
RS22b is offline   Reply With Quote
Old 02-10-2004, 01:15 AM   #5
Boost4U
Member#: 16459
1998 2.5RS
Sorry to hear about your block.....what are you running as a setup? I will keep you up to date on my progress with the gauges. My tach works, and my CEL, because they are both wires directly to the TEC-2. The coolant gauge seems nautoriously problematic. The fuel gauge I'm sure is my fault...did something to it when I put the Walbro pump in....hopefully the float is stuck or something. The speedo I haven't tried wiring yet, but I don't think there will be a problem. I will let you know how I solve everything though. I also swapped the AT out of my RS in place of a WRX 5MT. That had a bit of its own wiring issues to deal with.
-Chris
My check engine light is on but car is running fine. Ripper Normally Aspirated Powertrain 27 09-24-2001 11:59 AM
How to activate factory while the car is running? hkwan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-20-2001 08:23 PM
Activate alarm while car is running - how? hkwan Car Audio, Video & Security 0 07-20-2001 12:48 PM
('93-'01) car is running rough!....help, quick! nav Impreza Forum 10 04-14-2001 08:20 PM
How Do U Know if Your Car is Running Lean? Xscreamer General Forum Archive 7 08-29-2000 09:45 PM
