Old 02-07-2004, 12:10 PM   #1
DAC17
Member#: 14096
2011 Outback 2.5i
Pearl white
Default UTEC v. Stock computer upgrade
OK, I'm not a techie, but I'm confused about how the UTEC (basically piggyback computer) compares with say, a Cobb stock ECU upgrade. Is the biggest difference the programmability of the UTEC? I'm interested in low-RPM torque and around town driving, not max power for track use, and I'm not computer-savvy enough to change the programming on my own. Does that mean I'm better off going with a Cobb Stage 1 (or something similar)?
I hope some of that makes sense.
Thanks
DAC17 is offline   Reply With Quote
Old 02-07-2004, 12:53 PM   #2
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Well, the Cobb product costs about $400 at the moment, while the TurboXS UTEC costs over $1000. Much of what you are paying for with the UTEC is, as you surmised, the ability to alter multiple maps and tune as you see fit. So if you have no interest in learning how to take full advantage of the user tuning capability, or don't need maps for different scenarios (summer, winter, street, track, etc), I would not recommend their product.
The advantage of reflashed ECU products is that they are "set and forget" solutions for people who don't want or need to tune multiple maps. However, you do encounter the possibility of "outgrowing" your reflashed ECU if you continue to make modifications that require different parameters than what your ECU has, in which case you might end up paying a second time for a new reflash. I believe in the very near future Cobb is offering a companion product to allow users to do these subsequent reflashes themselves (AccessPort).
Joel
Zola is offline   Reply With Quote
Old 02-07-2004, 12:57 PM   #3
el~sharko
Member#: 29735
2011 JSW TDI - DSG
2008 EVO X MR
utec has a great knock monitoring system.
el~sharko is offline   Reply With Quote
Old 02-07-2004, 03:04 PM   #4
03WRXMA
Member#: 35081
2012 WRX
Well said above,
The reflash, set and forget
The UTEC, you will need to play with it.
And, this has been covers 1,000,000,000,000 tims in the past
The ECU comparo sticky at the top is a good read
03WRXMA is offline   Reply With Quote
Old 02-08-2004, 08:57 AM   #5
kenchan
Member#: 15106
The problem with the ECU upgrade is you can't go back to
stock mode on the fly as you can on the utec. Plus, if you
live in extreme cold areas in the winter, i think you'll want
the ability to change parameters now and then.
kenchan is offline   Reply With Quote
Computer upgrade leftover: memory blowout rukkie Private 'For Sale' Classifieds 1 10-24-2004 12:18 AM
n00b computer upgrade question. Bonzo Off-Topic 9 09-27-2004 01:59 PM
anyone in need of a computer upgrade? mofugga Private 'For Sale' Classifieds 1 09-26-2004 01:18 AM
computer upgrade advice needed rukkie Off-Topic 28 08-18-2004 05:55 PM
Computer Upgrade? Otaku Normally Aspirated Powertrain 0 01-23-2001 11:07 AM
Message Board Statistics All times are GMT -4. The time now is 10:47 AM.
