Old 02-07-2004, 04:36 PM   #1
baddmojoii
Member#: 51663
Default Outback plug replacement?
Is there an "easy" way of replacing the spark plugs on my '99 Outback? I just bought it recently and there doesn't look to be much room to access the plugs. Is it just going to be a P.I.A., or is there a trick to it? Thanx,
Matt
baddmojoii is offline   Reply With Quote
Old 02-07-2004, 07:24 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
All the Legacies (and actually most "newer" Subies) are a bit of a pain to do plugs.
I find that dismounting the washer tank and the intake, it is a lot easier.
I also drop on the socket, then piece the extension and ratchet. This makes it easy as well.
Old 02-08-2004, 07:14 PM   #3
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
http://www.endwrench.com/current/summer03/H-4.pdf
Look at the bottom of page 4. Subaru has some recommendations to make the job a little easier; basically, pick out your U-joint and extensions in the right lengths.
I haven't tried this yet, but the next time I change plugs on an EJ25 I plan to try to make it a little easier by jacking the engine up on its mounts by an inch or so.
vrg3 is offline   Reply With Quote
Old 02-08-2004, 09:39 PM   #4
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Corolla GT-S Hachi Broku
Yeah... I'm 75% done with it as we speak (1999 OBS, 2.2L).
On the passenger side, I just removed the entire intake (except the torque chamber right before the throttle body).
On the driver's side, I took out the battery and unbolted the washer fluid tank. That way, you can manuever the tank out of your way (or at least to a better place than it is mounted) and the removed battery gives you lots of extra space.
-Ben
Soon2BturbodRS is offline   Reply With Quote
Old 02-12-2004, 06:38 PM   #5
baddmojoii
Member#: 51663
Thanx for all the advice... They sure made it a tight squeeze!
Replacing Spark Plugs - What else Compliments Spark Plug replacements? FIlters? jungleman Service & Maintenance 2 02-09-2009 03:45 PM
2003 Outback headlight replacement bajjisw Newbies & FAQs 1 01-30-2007 05:13 PM
'02 Outback stereo replacement help Patrick Olsen Legacy Forum 13 08-29-2003 03:41 AM
Outback foglight replacement gavin Legacy Forum 12 10-17-2002 01:01 PM
Spark Plug Replacement Procedure arejay SVX Forum Archive 2 08-10-2000 05:16 PM
Message Board Statistics All times are GMT -4. The time now is 12:36 AM.
