Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 02-07-2004, 06:20 PM   #1
kosoku
Member#: 51373
2008 Nissan Titan
04 SV650, WSMC #606
Default Benefits of a wider rim?
I was just wondering if there is any REAL benefit to getting wider wheels on the WRX. For example 17X7.5 compared to a 17X8.5. I'm actually debating on buying some Volk TE37s 17X8.5 +50 offset or the 17X7.5 +48 offset and I am concerned about rubbing on any parts of the suspension if i got the 8.5. I plan on putting 235/45 or 235/40 size tires on them. I dont really care if i have to roll the rear fenders, its not really much of a problem. I would like NOT to mess with the camber too much to make them fit.
kosoku is offline   Reply With Quote
Old 02-07-2004, 07:02 PM   #2
Razlak
Member#: 7209
2005 WRX STi
World Rally Blue
The benefit is better sidewall stability and more direct handling. You can also safely run a wider tire. Sedans shouldn't have too much trouble up to a 245ish wide or so depending on your camber settings. Its pretty impossible to say exactly what would fit considering all the different suspension setups out there. Search through the Motorsports forum for Red Rocket's 255/40 setup, he's done quite a bit of documentation on how it fit up.
Razlak is offline   Reply With Quote
Old 02-08-2004, 04:32 PM   #3
caldweb
Member#: 52577
95 BMW M3
8.5 is optimal if you want to run 245 or larger. The difference between 7.5 and 8.5 won't be as big on 235's.
caldweb is offline   Reply With Quote
Help: Wider rims or lighter rims? Pete Holt Tire & Wheel 11 08-08-2007 12:41 AM
Benefits of running a wider pair of front tires... Pacobeagle Motorsports 10 09-06-2006 02:01 PM
quantified benefits of wider tires? mr. m Tire & Wheel 21 01-06-2006 10:49 PM
what are the benefits of an 18inch rim? BUDLoNG Brakes, Steering & Suspension 39 02-09-2003 03:44 AM
If you could fit a 2" or 3" wider rim on your car, how would it affect handling? Gravel-Fun Brakes, Steering & Suspension 6 12-13-2002 06:48 PM
