Welcome to the North American Subaru Impreza Owners Club Saturday May 30, 2015
Old 02-07-2004, 06:10 PM   #1
BritSti
Member#: 38057
2010 IS-F
USB
Default Need to identify right ignition coil wire for tach sense
In the middle of a remote start install on my 04 Sti, looking to tap into a tach wire on the ignition coil harness below the window washer fluid reservoir.
Anyways, I've checked out Netz's explanation of which wire to go for, but it is not clear which coil I am looking at.
Below the washer I see to main conectors, the top one being brown, the one below being black. I do see a solid yellow wire which may be the ignition coil 4 pin 8 yellow wire for the tach, however, not sure this is correct, as the space is so tight pin numbers are not really available....
Any suggestions on this, or should I just go for the tach off the ecm...
Thanks.
S
BritSti is offline   Reply With Quote
Old 02-07-2004, 07:13 PM   #2
netZ
Member#: 5743
2007 Kia Optima
gold brick
Default Re: Need to identify right ignition coil wire for tach sense
you can learn tach off any of ignition coil wires i've listed. you can meter this wire by setting your meter to AC, ground the black probe and use the red to test the wire. have someone press the accelerator to vary the rpm and the values should increase and decrease appropriately.
the connector is brown f60 under the windshield washer reservoir.
netZ
Thanks.
S
netZ is offline   Reply With Quote
Old 02-09-2004, 06:10 PM   #3
b0n3z
Member#: 37289
04 WRX STi Silver
91 MR2 Black
BritSti - so you know I have a 04 STi also. NetZ's info is awesome. I used the tach of the ECU for a Compustar. It worked perfect the first time. Just make sure to use a diode and test the wire first. I'm no professional at installing... but I take my time and get it done as perfect as possible (running wires, soldiering etc). When your looking at the ECU harness - just make sure your looking at it from the correct side. If you look at it from the one side the numbering of wires is backwards.
-Ken (aka b0n3z)
Download this for wire diagram
b0n3z is offline   Reply With Quote
Right ignition coil wire for tach sense on STi? BritSti Electrical & Lighting 8 11-10-2009 07:48 PM
WTB: Ignition Coil Pack for 2000 2.2L impreza ScubyMedic Private 'Wanted' Classifieds 1 06-08-2009 09:35 PM
WTB: Ignition Coil Pack for 2000 2.2L impreza ScubyMedic Tri-State Area Private Classifieds 0 06-08-2009 09:02 PM
WTB: WRX/STI ignition coil wiring suberdave Private 'Wanted' Classifieds 1 11-15-2008 12:46 PM
ignition coil wires Hawk296 Service & Maintenance 4 01-14-2003 01:31 PM
