Closed Thread
Old 02-07-2004, 06:11 PM   #1
BritSti
Member#: 38057
2010 IS-F
USB
Default Right ignition coil wire for tach sense on STi?
In the middle of a remote start install on my 04 Sti, looking to tap into a tach wire on the ignition coil harness below the window washer fluid reservoir.
Anyways, I've checked out Netz's explanation of which wire to go for, but it is not clear which coil I am looking at.
Below the washer I see to main conectors, the top one being brown, the one below being black. I do see a solid yellow wire which may be the ignition coil 4 pin 8 yellow wire for the tach, however, not sure this is correct, as the space is so tight pin numbers are not really available....
Any suggestions on this, or should I just go for the tach off the ecm...
Thanks.
S
BritSti is offline
Old 02-07-2004, 07:04 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You should be able to tap the tachometer output at the ECU rather than an individual coil.
Mulder is offline
Old 02-07-2004, 07:16 PM   #3
netZ
Member#: 5743
2007 Kia Optima
gold brick
yes, unfortunately some aftermarket alarm/remote starters have difficulty learning off the ecu's tach wire though. the ignition coil wires works best with the viper alarm/remote start systems.
netZ
netZ is offline
Old 02-07-2004, 07:22 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Ok, now that you're in this thread I'll go away
Mulder is offline
Old 02-07-2004, 07:24 PM   #5
netZ
Member#: 5743
2007 Kia Optima
gold brick
it's all good!
netZ
netZ is offline
Old 02-07-2004, 07:55 PM   #6
BritSti
Member#: 38057
2010 IS-F
USB
Default You guys are quick
Ahh, thanks for the responses guys, I would say right now I am more comfortable going for the coil wire at the ECU (B18 Yellow).. would you say this would be better than the tach (a23 green) at the ECU level or should I focus on the coil harness in the engine bay (Brown F60 - Thanks for the update on that NetZ).
S
BritSti is offline
Old 02-07-2004, 08:29 PM   #7
netZ
Member#: 5743
2007 Kia Optima
gold brick
brit,
it's really up to you, since i have to route wires for the hood pin, siren etc, i include the tach sense wire as well. also, since my hands are pretty small it's easy for me to tap into the ignition coil wire. i also try to reduce alarm/remote start wires from straying all over to keep the install neat and stealth.
in summary... either location is fine.
netZ
netZ is offline
Old 11-10-2009, 05:06 PM   #8
ZachSmithkl
Member#: 210937
2005 WRX
Red
I am also looking for which coil wire I should tap on my 2005 WRX for my viper 5901. Right now the remote start turns on but it sounds like the remote start isnt letting go of the starter
ZachSmithkl is offline
Old 11-10-2009, 07:48 PM   #9
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Please don't bump ancient threads, this one is five years old. Also this is not the proper forum, we have a Car Stereo and Security forum.
Mulder is offline
Closed Thread
WTB: Ignition Coil Pack for 2000 2.2L impreza ScubyMedic Private 'Wanted' Classifieds 1 06-08-2009 09:35 PM
WTB: Ignition Coil Pack for 2000 2.2L impreza ScubyMedic Tri-State Area Private Classifieds 0 06-08-2009 09:02 PM
WTB: WRX/STI ignition coil wiring suberdave Private 'Wanted' Classifieds 1 11-15-2008 12:46 PM
Need to identify right ignition coil wire for tach sense BritSti Car Audio, Video & Security 2 02-09-2004 06:10 PM
ignition coil wires Hawk296 Service & Maintenance 4 01-14-2003 01:31 PM
